R50/53 R50/R53 12V Power in Boot (trunk), '02 and '03
Hello all,
I have an '03 MCS. It would be nice to have a 12V power outlet in the boot. My MINI has a dummy plug instead of a power outlet (or cigarette lighter, if you will).
I stumbled across this thread: https://www.northamericanmotoring.co...nk-bonnet.html
In that thread, there are those that state that '02 and '03 did not have a power outlet in the boot but instead had a dummy plug. There was also a statement that there is a wire going to a location behind the plug. There was an open question as to whether a retrofit was possible in order to install a power outlet in the boot. I have searched the forum but I can find no reference to whether this retrofit was ever achieved.
Has anyone installed a power outlet in the boot on an '02 or '03 MCS or Justa?
My 04 has it and I use it to charge batteries when I am flying my UAVs / Drones. The hardest part (making it look neat) has been done for you since there is a dummy plug there. The rest is making sure that your ground is as short as possible and WELL insulated - and making sure that your run to power is well insulated as well so it never contacts the body. There is some science around the guage of the wire - but if you like I can pull the panels on mine and tell you what they used. Stereo shop is great alternative if you don't like wrenching.
Since it is an S...
THIS POST took longer to write than wiring it up....
As long as you are OK with an always on plug....
The battery is only 2 feet away.....lots of metal for an ground....the hole is already there....add the wire, a fuse, a plug in the hole, connect the ground....done.
If you are not comfortable or do not understand DC power, get some help from a friend, but this is perhaps the simplest wiring job I can think of in a mini. I would not try to fish a wire from the front fusebox...too much work.......
Since it is an S...
My question really relates to, are there already a hot lead and ground lead present within the harness that goes to the boot from the fusebox, already put in place by MINI? There would be no need for me to hack in something if they have already put the infrastructure in place, if you know what I mean. I believe that in the thread I referenced, some said that the feature existed for some '02s. If so, it seems possible that the harness already has the wiring for the circuit in place. Really, that is what I want to find out.
Anyone know whether the wiring is already in place for a power outlet in the boot for an '03?
Baby J, if you could look and let me know wire gauge, color and marking, that would be helpful Thanks!
I am sure brown is ground, in any event... I will need to tear into it to see whether there are any loose wires wrapped in the loom/harness but I would think the would be at a minimum taped/capped or possibly connectorized. I didn't see any obvious connectors in there. Just thought I'd poll people out in MINIland (small world?)
MINI removed the power socket to save money. Most of the cost comes from installing the wiring. It's very unlikely they would have left the wiring.
Hi the six pin connector was the only one that was not connected to anything, which is why I am guessing it is for a rear fog, which as I understand it was wired in but not connected on US models. Of course all the other wires within that branch of the harness head to the tail light and seem to be connected, and presumably they handle the entire tail light.
Had you posted this on Monday I could have taken a photo of one of my '04s, I had the whole thing stripped out to install my recovered headliner.
I'm pretty sure there is a wired L shaped connector plug that is pre-wired and part of the harness on the Left Rear loom, it should run about 12 inches or so from the main loom.
Reference Parts:
http://parts.miniofkennesaw.com/show...modelYear=2003
Motor on!
Reference Parts:
Motor on!
Did you ever figure this out? I took a look in my '03 and I found an unused connector with a brown/yellow wire and a black/yellow wire connected to it. There is no power outlet. I don't know that I'd use it very often if I had one, but it would still be nice to have.
If in the drivers side.... You might be lucky....
With a battery INCHES away....you could wire up a plug and fuse in mear moments on an S....
67morris
12-01-2015 12:53 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
09-10-2015 12:34 PM
