R50/53 Wheel Arch Light Help!
Whats going on,
I am looking to purchase all 4 Wheel Arch Lights for my 03 Mini Cooper S.
I currently have the amber up front and red on the rear bumper.
I was wondering, where can I purchase new ones, Also do they have clear ones or white ones instead of being amber and red where can I purchase those.
Thanks!
P.S. That's not my car, just to show the Wheel Arch Light
Thanks!
Thanks for the mention jwh,
Yea, we have them here for front ( amber and the rear, and easy change if you want them working but to match the wheel arch a bit more is the Lamin-X film.
63147165869 Side Marker Light - Front Left
http://www.ecstuning.com/Search/SiteSearch/63147165869/
Side Marker Light - Front Right 63147165870
http://www.ecstuning.com/Search/SiteSearch/63147165870/
The Rear arch reflectors.
Side Marker Light - Rear Left 63147165871
http://www.ecstuning.com/Search/SiteSearch/63147165871/
Side Marker Light - Rear Right 63147165872
http://www.ecstuning.com/Search/SiteSearch/63147165872/
Here is the Lamin-X Film. Set of Four ( one for each corner ).
http://www.ecstuning.com/Search/SiteSearch/MN005/
Possible in the future , the Lamin X looks good easy to apply for tint, blacked out , All Red or smoked look.
No problem, it all what you like as far as looks.
Here you go, I just did on of the rear sockets and wires.
#3, one per arch light. Check to make sure this is ok. The bulb inserts into this.
http://www.ecstuning.com/Search/SiteSearch/63138382104/
Then on the body side. 61138365340 x 1 per arch light
http://www.ecstuning.com/Search/SiteSearch/61138365340/ES2673826/
Then you will need to wire in the two new cables and socket plug.
61130005199 x 2 for each plug. Cut out the old one at the cables and leave enough room to wire in. These then slid into the back of 61138365340 all the way on the square head and then push the white clip closed to the side, ( Open in our pics ) . Then plug into 63138382104 w/ the bulb and you are done.
http://www.ecstuning.com/Search/SiteSearch/61130005199/ES2676087/
You are welcome. With those parts. One plug, light socket plug, and wires will do one corner. If you have another light on the other side bad , just get another set and etc.
Awesome!
On the hatch grip handle there is a little more explanation here:
https://www.northamericanmotoring.co...t-housing.html
Awesome!
Or you can replace them all together with these bad boys! Just order a pair for the front to see how I like them!
http://www.voltageproductsonline.com/aerodiffuser.html
07-16-2020 12:54 PM
