R50/53 My r53s progress thus far
#176
on
1 Post
How well does the Konig Feathers work when being tracked or auto cross?
I was looking at the OZ Allegerita HLT or Ultraleggera.
#177
I have had issues with ordering new rims in the past and one of them was "tweaked" during shipping or the tire balancing is not done correctly.
They should be fine for autocross since "racing" is stamped on the wheel:-)
#181
Run them on the track also.
http://highplainsraceway.com
http://www.pueblomotorsportspark.net/rc.html
Never had any issues.
Liked them enough to get a second set for my winter setup.
Cheap and light.....
Good-win racing had the best prices when I got mine.
#182
I have been running feathers for 5 years on Colorado pot hole roads.
#184
#186
#187
#188
well ive been having an issue with my tachometer working, long story short i have the tach working but it requires a jerry rigged fuse switch to work. The issue however, is causing a ses light and preventing me from getting an inspection.
Dealer says i need to replace the speedo to fix the issue. which is $562 from ecs. They are telling me a used unit cannot be used, anyone know otherwise?
by the way the feathers are on ill take some photos when its light out.
#189
Yea, a used unit might not take the flash, when the 2005 models had a lazy clock , they replaced mine and had to flash a new one. Think the main speedo is programmed to vin.
I know you can replace the tach , but I believe the speedo is to VIN. I dont know if any other third party programs can work with reflashing the speedo , think it because of the mileage security fault or something.
Good luck.
Good luck.
#190
Good luck.
Good luck.
#194
#196
#197
#198
#199
Ordered some brembo ceramic pads to complete my r56s brake upgrade so I'll get those on this weekend. The brembo pads have good reviews with tire rack and bavauto, for half the price of the Akebonos I've been using I guess I'll try them out.
I'll be removing the Zimmerman rotors, akebono pads, and stock calipers which I'm gonna grease, clean and paint up red for anyone interested they have about 10,000 miles on them, if that.
#200
Yea, if you can go without your car for a day... yea, this would be a DIY.
Motor on!
