Just black plastidip, yea they just pop out, from the inside of the hood give them a push and unplug the light. I taped of the lens and on the "S" I took i cotton swab and put a little vegetable oil on it so the dip didn't stick to it. Then used the swab to remove it from the "S"
Thanks This sounds like a project for today, do you have any pics of the process or is there a past post/thread about the process? What did you mean by using the swab to remove it?
Hmmm I am not really sure I understand what you mean but I will figure something out I guess lol
Hi, Well you can remove the 'S from the scuttle itself. Also the mesh. When I did mine, I just cut the plastic pin that holds the locking washers. The glued when putting back on.
When using plastic dip I have found that wooden toothpicks help a great deal too. They are great for gently edging the plastic dip out of tight detail areas without causing damage.
Thats a good idea as well, do you do this when it is still wet or after it has dried?
That color coding looks really good. And I think I am going to remove the S as well if I can't figure out a better way. Thanks guys!
You can dip those too but, just make sure that when opening your doors press and pull only from the back of the handles. This will keep the dip last long. Hehe
Getting closer to installing my JCW front brake kit, rotors came in today. Meyles from Bavauto, decided against drilled or slotted since my blank rotors have been working so well. That and they were only $80 a pair and came with new hold down bolts. Now I just have to order pads and wait for spring weather.
Is that the OEM JCW kit or a kit you made? I was looking into doing something similar making my own.
Kit I made. Total cost so far is $230 for the calipers, stainless steel lines, rotors, and painting supplies. I'll most likely use Akebono pads again. For a final total of just over $300.
I like your style how hard was it to paint the calipers? Do you have any tips?
I just taped the rubber parts and any sliding areas as well as the Pistons. Gave them a few coats and then finished with some clear coat. Easy enough, I'll add some JCW labels before I install them and add more clear over them.
Nice, coming along good. They are ALOT smaller than the JCW kit though right?
