R50/53 My r53s progress thus far
#76
Looks great, came out nice a flush at the ends !! If someone wants to install the middle grille w/o using a dremmel/modding the bumper itself, here is a PDF file "how to" just modify the grille. ( only need to enlarge two slots I think ) I would also suggest folks use some black paint on the bumper area behind the middle grille area so the painted body color doesn't t show thru. http://www.motoringfile.com/howto/MI...ll_install.pdf
#77
I found the best way to remove caps is:
- Place a blanket on the ground below the mirror area. ( If mirror cover pops of suddenly it wont scratch or ding up on bare ground/cement)
- Find some wooden popsicle sticks ( 3 or 4 ), rub one end on sandpaper to make somewhat of square/sharp end.
- Angle the mirrors down as far as they can go.
- Carefully get your index, right and middle finger tips behind top edge of mirror glass and pry away from the round center drive disk it's snapped into. Remove glass and just let it hang from the brown heat wire.
- The 5 tabs have "bridges", best not to fracture those. Three tabs up top and two at bottom.
- Start at the two bottom ones, usually once those are released the tops release thereafter. Hold onto sticks between your teeth...easier than fishing around for them while doing this.
- Use one modified popsicle stick with shaved end to pry up on one of the covers clips while simultaneously making some tension to bottom of cover by lightly pulling. Remember just apply slight pressure here at this point don't want to break that bridge.
- That tab will be raised up some now but not totally free.
- leave the stick under that raised tab, grab another stick and work on the one to the bottom right now doing same process.
- Applying more pressure and continue the prying process to get the bridge over the black molded tab until both bottom bridges make it over releasing the bottom two.
- May have to work at others up top in same fashion if they don't immediately free up.
when re-installing cover line up all the tabs first before applying pressure to front of cover snapping it in....eye ball each tab to be sure they are lined up exactly.
when putting glass back on, line up the tabs at the back of the glass with the mounting disk and use even pressure. Pin point pressure will crack the mirror.
GL!
#78
#79
#82
hahaha..
When wrapping the caps it may take a few attempts. "I think", the best way is to start at the top of the crown of the cap....
Here, then using hair dryer to warm it and with thumbs fan your way out from that point.
Compound curves can be a pita.
wrapacover.jpg?1414946166629&1414946167392
#84
We have the clear top that flashes amber and then the amber lens tops also for the 7/2004+
Amber top.
https://www.northamericanmotoring.co...oem-parts.html
Clear lens top:
https://www.northamericanmotoring.co...ts-06-mcs.html
Then you can get the Ziza Back up Leds: 7/2004+ Gen 1 MINI
https://www.northamericanmotoring.co...erse-leds.html
Amber top.
Clear lens top:
#86
Clear top on BRG convertible:
#88
You are welcome. As long as your MINI is happy.
#90
We have some holiday promos going on right now From instagram to our wheel spin. Goodluck.
https://www.northamericanmotoring.co...-contests.html
#91
#92
OK so my scoop is on, finish is excellent no broken clips or scratches like some members have reported. Fitment was good no issues there, the scoop has a wider opening so it looks a little more aggressive than the stock scoop. I love it, i would have liked the m7 but this was only $100 vs $220 which is just too pricey for me. Unfortunately, by the time i got home and installed it was dark and snowny, so these pictures will have to do for now but better pictures will follow.
[IMG][/IMG]
stock size for comparison
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#93
#97
Nice mod.
#99
Those look awesome and exactly what I want on mine. Did you take them off to spray? Also how did you keep the "s" red? Lastly did you use a sealer or just the plasti dip?
#100
