R50/53 How to Access Seat Belt - '05 Mini Cooper S
I am trying to open/access the seat belt panel where it gets in the tensioner. Before I break anything, has anyone done this before? I am a new member so can someone post instructions on how to open and access the seat belt panel please.
The issue I am having is that my seat belt gets soaking wet when it rains. I can't see anything from the outside of the car where the water is leaking from, so I would like to be able to open the panel inside then pour water to see where the leak is coming from.
Thank you in advance.
Next I would look at the window seal....bet it is out of adjustment...might be noisy......water is streaming back past the glass....
Window should be TIGHT against glass...but if the door is a bit out of sack...a tiny bit...you have a gap...air...water comes in...there is a vent in the back....so bam....wet seat belt...
That's my 2nd guess!!
do your windows "do the dip" when you open the doors?
What part of the belt is wet? A picture or (crude) drawing might help. ... Is the exposed part wet, or what comes off the reel, or both? Any wet carpet?
This might sound silly .. BUT: you know those car washes where you can stay in your car?
07-16-2020 12:54 PM
12-23-2015 10:36 AM
08-07-2015 09:51 AM
08-07-2015 08:10 AM
