Yet another stuck oil filter housing thread
on
Thanks Mini! I've now broken a 3/8" breaker bar, (3) 3/8" ratchets (with a pipe over them as a cheater bar), and (2) 1/2" to 3/8" adapters. I've tried soaking the groove with PB Blaster, I've tried when the car is cold and when it's hot. I've tried from up top and through the fender well. This is f'ing ridiculous.
I read about a guy that took his whole filter housing off of the engine (3 bolts), put it in a vise and hit it with an impact gut to get his off. I've also read about warming the car up and using CRC Freeze Off to get the filter housing cold and loosen it up as well as another guy using a MAPP torch.
I haven't tried any of those three methods yet but does anyone have any ideas as to what would work best? I've pulled engines in less time than it's taken me to NOT change the oil in the Mini.
This is not a good start to my relationship with Mini. Thanks in advance for any ideas.
I always use a 1/2" breaker bar mated to a 1/2" drive 36mm 6 point socket to break it loose.
Better chance of it breaking loose before the tools break compared to 3/8" drive stuff.
A few whacks to the bar near the socket with a deadblow hammer (in the correct direction) might help.
Running the engine a few minutes might help, but the housing tends to warm up almost as fast as the engine does.
A cooling blast might help at this point, too.
on
Thanks for the input. I was thinking the same thing about using a 1/2" drive so I ordered on off of Amazon. I was using the 3/8" drive because that's all I could find locally. If it breaks the 1/2" breaker bar I'll definitely have a problem lol. I'll use the freeze stuff too just as an extra bonus. Hopefully it works out. I guess worst case I just take the whole assembly off and either try to break it open that way or buy a new one. What a PITA.
Thanks!
Thanks!
Are too using the BMW specific tool to get this off? I would be concerned that maybe your housing has been Galled or cross threaded. It would be hard to see what the cause is with it on the car.
While I would agree they tend to get on there pretty tight I didn't have a problem using a breaker bar to get mine off.
While you might not want to spend the $$ even a mini dealer oil change is only about $70...not that much more than a full synthetic oil change at home
on
I've thought about trying this as it was worked on other things in the past. If I can't get it with the 1/2" drive I'll give it a shot.
I recently am doing engine rebuild on my 03 R50.(Cylinder head, piston rings, hoses and everything else) I had a stuck and frozen oil filter housing and know if u even tried taking it while connected to motor it will cause damage since u can't apply the proper force.
I took my whole housing out and used a vise to held it and loosen it without a problem. The cause of the filter cap being stuck was the oil ring wasn't oiled before cap was put back onto housing, and seized it.
If you take housing off from the three bolts. Get a new gasket and you will be set. I pulled mine off completely I saved $250 because I can reuse the old part.
Hoped this helped. If you need more info let me know.
I think its worth to take it off so you don't damage the three bolt threads and not cause oil leaks from the block. The three bolts are easy to take off so better be safe then sorry. New gasket replacement is worth it too.
I almost got my whole engine together. Just waiting on a few parts in mail. Like this gasket lol
Naww...you should be able to get it off in place!!
Like said above...a bit of pressure to TIGHTEN, then try to take it off...helps to get it moving!
Having the RIGHT socket helps!
http://www.waymotorworks.com/36mm-oi...er-socket.html
3/8 or 1/2 is more ratchet depandant....a quality tool of EITHER size should be able to apply suffivent TQ without breaking.
on
naww...you should be able to get it off in place!!
Like said above...a bit of pressure to tighten, then try to take it off...helps to get it moving!
Having the right socket helps!
3/8 or 1/2 is more ratchet depandant....a quality tool of either size should be able to apply suffivent tq without breaking.
^^^^+1.
Did u try to tighten / loosen method back and forth a couple times, not just once. Kind of like rocking it. Sometimes this method also works with large bolts so you don't shear them off.
Someone really put the cap on tight when they installed it last. When you do get it off post pics so we can see what it look like.
on
on
Quick update. The 1/2" breaker bar coupled with the 1/2" drive 36mm socket did the trick. After I had that loose I totally expected the drain plug to give me fits (based on what I have read) but it came right out.
Anyway, thanks for all of the replies and help. I lubed up the threads with some oil and I change my cars oil at 4k mile intervals so I dont anticipate having any more problems.
Great news. Glad you got things fixed.
Adding a little clean oil to the outside of the new gasket helps it slide up against the inside of the oil housing base.
http://www.ecstuning.com/Search/11427512446/ES24009/
Glad you got this fixed.
I have a mechanic friend that was helping me do some work on my car, and when he noticed how the oil filter is, he said that he would never buy a mini. He liked everything else, but hates these types.
After a few oil changes, I agree with him. But I still love my mini...
on
That is exactly what I used, minus the shoes ;-)
on
