R50/53 R53 OEM bluetooth retrofit
Old 04-30-2013, 01:52 PM
bradnic's Avatar
bradnic
bradnic is offline
Originally Posted by AKIndiMini
I'd love to do this with my R53...but I've got the Euro arm rest (the one with the lid that hinges open...not the slider kind pictured here). Do I have to switch to the other style of arm rest, or is there a kit out there that works with the Euro one?
Do you have a pic? Maybe Mike at ECS can comment. If you look earlier in the thread you will see the cradle assembly and how it slides into the armrest.
I know when I was researching things that there are several BT handsfree kits in Europe for the R50/R52/R53.
take a look at the list of install docs here. maybe they will match your armrest. otherwise ECS sells the armrest retrofit kit needed - check the first post in the thread...
  #77
Old 04-30-2013, 02:45 PM
bradnic's Avatar
bradnic
bradnic is offline
Originally Posted by joylove
Did you notice if your vehicle harness had MUTE and TELON wired back to the HK? Mine doesn't and the schematic says at least Mute should go back to the amp, however this just muted the radio+phone inputs.
Just realized I never really answered this question. I just pointed out that the ULF mute wires are connected to the radio.
are there other mute wires in addition to these? or are you asking if the amp was prewired with them in the body harness? I certainly did not route any wires to the amp.
  #78
Old 05-01-2013, 05:20 AM
bradnic's Avatar
bradnic
bradnic is offline
Originally Posted by RichardP
The voice activated dialling command does NOT use the phone phonebook. You have to enter each number into the VR module (which is integrated into most ULF's) phonebook. You have to use the command 'Save Name', then say the name, then say each digit of the number and then finally say 'Save'.
This was the key point I was missing yesterday. The newer systems *do* attempt to provide a single integrated address book.
Thanks Richard. I know you posted this comment a couple of days ago but couldn't get it approved. Glad the moderators took care of your user account.
Still need to get our Intravee+Bluetooth music solution sorted with you..
  #79
Old 05-01-2013, 08:09 AM
joylove's Avatar
joylove
joylove is offline
Yes, if you check the schematics (and there are a couple of variations) it says that TELON goes to the radio, MUTE goes between radio and amp and depending on the yes TELNF goes to the amp or the radio.
I have an aftermarket nokia car kit at the moment, and whist TELON is functioning well using a relay driven by the phone's MUTE line, the MUTE is not working and the line is not pulled up by the radio. I've tried a different radio (the 2007- Blaupunkt), I've tried connecting the mute line at the amp. I can't make the radio mute and the TELNF and radio fight at the same volume. I have to click the radio volume **** and rely on TELON to keep the audio circuits alive on an incoming call.
Another question; the VR in my TCU is beyond useless. If VR is disabled via coding in the ULF, do you get to use SIRI by holding down the sneezing man button?
  #80
Old 05-01-2013, 09:13 AM
ECSTuning is offline
Received 1,965 Likes on 1,765 Posts
Quote:
For iPhone user you can also hit the button on your phone (while in the cradle) for the iphone help and hold it down and the system will prompt like another version of bluetooth.
bradnic said-
"you're talking about Siri right Mike? I actually haven't tried that yet as my son's got the 4S now. you have full access to the home button and screen while in the cradle that's for sure."
Pre Siri , but voice control only using on the iPhone 4 home button. See below.
Joy love said-
" Another question; the VR in my TCU is beyond useless. If VR is disabled via coding in the ULF, do you get to use SIRI by holding down the sneezing man button? "
I have the pre -Siri Iphone 4 and with the latest updated by holding the button on the Iphone $ and promoting the beep on the phone only , its a another way to use the phone built in commands which it will mute the radio (once you hold it) and if you talk to the center console it will dial the phone number, like if you are just using the phone.
"Do you have an audio clip yet of how to talk to the system using audio commands? It has a notepad feature and its funny to hear it talk and read the notepad. This was very cool feature for MINI back in 2005."
This part of the system is not working properly yet. I suspect it's the ULF version included with the kit and/or incompatibility with the iPhone(s) and Galaxy S phones I tried. It was definitely installed properly. As I indicated above my M3 has a 552 module while this kit came with a 492 version. The voice prompts are different. "
Did you finally get this to work. Hold in the "phone icon" button , then you get the beep. Say command. I was able to store names and phone numbers in the ULF hard drive and then using the "phone icon" command button say Dial... lady says ... Speak the name.... say"name of person" .... lady says" Is this correct" (or something like that)... say" Yes" ... Lady Says "dialing " . Are you getting anything close to that ?
For the Euro armrest:
The MINI Full Bluetooth kit has the cradle snap in part that was made for the factory regular armrest which Brandic did a very good job of showing the removal and install on.
The Simple Bluetooth. Does not use the armrest in any way. It also has a little keypad that comes with the system which is to cover people that might not have the steering wheel controls. The key button also comes on the full Bluetooth kit to cover people who don't have the button on the wheel also.
Like above.
Simple Bluetooth:
http://www.ecstuning.com/Search/84110302897/
Full Bluetooth: **Brandic Install
http://www.ecstuning.com/Search/84640404810/ES201283/
The "euro" Flip top Armrest has a rectangular cavity and would need to make a homemade version to hold the snap in adapter console section to mount it to the flip top euro , on top of cutting into the back of the armrest and zip tying wires down the side. It would not be clean unless you did some work.
* in a R56 but the same concept.
[IMG][/IMG]
FlipTop " Euro " Center Armrest Console - Black R50 R52 R53
http://www.ecstuning.com/Search/51120430469/ES253376/
The clean look would be to have the regular armrest:
Armrest retrofit kit: White Silver
http://www.ecstuning.com/Search/51160398630/
Armrest retrofit kit: Anthracite
http://www.ecstuning.com/Search/51160398467/ES79576/
And handbrake console top for the factory center armrest.
http://www.ecstuning.com/Search/51166958575/ES82388/
It comes down to ability and ease of install.
Thanks and I hope that helps.
  #81
Old 05-03-2013, 04:50 AM
bradnic's Avatar
bradnic
bradnic is offline
I've finally posted video on YouTube, also added it to the first post - enjoy
  #82
Old 05-03-2013, 07:48 AM
lathedog's Avatar
lathedog
lathedog is offline
Looks good
  #83
Old 05-03-2013, 08:17 AM
bradnic's Avatar
bradnic
bradnic is offline
Nice post Mike! thanks!!!
Pretty cool! will try this out with an iPhone 4S and report back. Siri behavior is a bit strange - when you first invoke it you hear the "Siri bong" through the speakers. It also looks like the car's BT mic is being used. The weird thing is Siri replies after that come through the phone, not the speakers. This may be affected if you have BT A2DP setup.
I have the pre-Siri Iphone 4 and with the latest update. By holding the button on the Iphone 4 and promoting the beep on the phone only, its a another way to use the phone built in commands which it will mute the radio (once you hold it) and if you talk to the center console it will dial the phone number, like if you are just using the phone.
Not sure I'm following this. Is this a reference to Siri, and that it mutes the radio if you hold down the home button? definitely does that.
Yeah turns out the system was working perfectly - nothing wrong at all. As a newbie to the system I thought it used one address book for display and voice dialing (which is not an unreasonable assumption I think). Anyway it's clear it doesn't.
  #84
Old 06-01-2013, 09:46 AM
joylove's Avatar
joylove
joylove is offline
Hi Eric
Saw your power folding mirror post - next on the list if I keep this car, with OEM switch
I found the OEM supplier and part number for the mirrors. Got mine for $124 delivered a side. Installed and tested working already with OEM covers and connectors.
Just waiting for my switch and module to do the vehicle-side wiring. Can give you the part numbers when I'm back on my Computer.
Today I start my OEM bt retrofit, so I'm here to re-read this exellent guide.
  #85
Old 06-06-2013, 10:01 PM
joylove's Avatar
joylove
joylove is offline
My BT and powerfold mirror thread is here!
https://www.northamericanmotoring.co...ml#post3753581
  #86
Old 06-11-2013, 06:47 AM
Thanks , I am glad I could help discuss some of the very cool features with this early but heavily featured system.
"Not sure I'm following this. Is this a reference to Siri, and that it mutes the radio if you hold down the home button? definitely does that."
Just referencing another way to access the bluetooth system instead of pushing the buttons on the steering wheel, like using a piggyback through the pre-siri , voice command built into the iPhone.
Joylove - sounds and looks like another large but very cool project.
  #87
Old 08-08-2013, 01:35 PM
Update to thread:
Hello guys I just wanted to update the thread with some of the latest info from MINI.
We have received several kit from MINI with the Bluetooth ULF not in the package on newer stocked kits. They have determined that the kits before did come with the ULF and the kits now will not come with the ULF. It will have to be purchased separately.
We tried to get the old ULF but it has been discontinued. We did some work and found an updated ULF module which is a shared unit on the MINI and BMW side . The ULF have had multiple super-session over the years.
So, this kit is much like the Gen 2 Bluetooth kit where the ULF module is separate. It has been updated on our website.
Thanks and I hope that helps with future installs.
  #88
Old 08-20-2013, 07:02 AM
technicallyrite's Avatar
technicallyrite
technicallyrite is offline
I've been happy with this $25 IAB13B adapter tucked into the small door under the toggle switches and powered by the nearby power port. The aux. port is nearby, so it's out of sight. I use an iPhone with iOS 7 and it gives me music and turn-by-turn directions audio while keeping siri feedback on the phone to avoid interference issues, so overall I'm very pleased. Sound quality is excellent, no engine feedback or ambient noise while charging. If you have issues with a power feedback loop try different usb chargers or different audio cable. The audio cable that came with this unit didn't have a solid connection, so I used a different cable I already had that does. Several stores have them, I got mine at Walgreens but have also seen them at Walmart. Granted, there are no steering-wheel or in-dash integration features, but you phone is probably a better remote interface anyway, which you can pass to any passenger.
https://www.google.com/shopping/prod...ed=0CEQQ8wIwAA
  #89
Old 09-17-2013, 01:42 PM
bradnic's Avatar
bradnic
bradnic is offline
to each his own.. the phone interfaces are really good now and as long as you're listening to music on your phone you can take advantage of siri and built in nav as well. so definitely with you there. you can do that with this kit too though. if the OEM thing is not that critical to a person then this is definitely not the way to go.
  #90
Old 09-17-2013, 02:18 PM
joylove's Avatar
joylove
joylove is offline
My factory kit works well up to about 40MPH with SIRI with the roof down, so I'm extremely impressed by the DSP and mic etc.
  #91
Old 09-24-2013, 12:05 PM
schwippschwapp's Avatar
schwippschwapp
schwippschwapp is offline
Stencil thingy...
Hi! has one of you still the "jig" this stencil thing part# 01 20 0 300 607 and could scan and upload it? I can't get hold of it. Neither the stencil nor the whole retrofit kit is avaliabe here in Germany anymore. I don't want to hurt my beloved Mini with a wrong cutout
  #92
Old 09-24-2013, 12:37 PM
Part# 01200300507 is NLA for the US. I don/t have the paper temp on me right now. Hopefully one of the guys still have it and could attach it for you.
The full Bluetooth kit is still available here in the US. Part # 84640404810
Thanks and good luck.
  #93
Old 12-04-2013, 01:53 PM
briggsy's Avatar
briggsy
briggsy is offline
Amazing thread. I was one of the few who sprang for the Universal handsfree kit back in '06, because I like to keep everything OEM and integrated-looking as well. I haven't used it since I got an iPhone 5 though because I've lost the pairing passcode! You mentioned it's printed on the ULF module? Is there any other way to get or reset the passcode?
Also, since the unit was first installed I've had complaints about the sound quality/reception (from people on the other end of the calls - the quality through my car speakers is decent, if a little quiet). You claim the sound quality on calls is perfect, however. What do you think is wrong with my installation?
  #94
Old 12-04-2013, 02:09 PM
Its might be in the user guide booklet, there was a little semi laminated white paper that inserts into manual. It should have the 4 digit passcode possible written down. Sometimes it separate from the manual and sometimes its shoved into the booklet. Other then that there might be the tag still on the unit that mounts behind the speedo.
They are all different number codes , this is just an example for the location on the ULF.
Also make sure the mic is on left hand side in the overhead if you have a convertible. If you have a sunroof / hardtop , I don't know if you can swap mic locations with the roof switch. I find talking more direct to it help also.
Thanks and hope that helps.
  #95
Old 12-05-2013, 05:47 PM
briggsy's Avatar
briggsy
briggsy is offline
Thanks for the info, I don't see the BT passkey in my manual, so I'll probably go in and check the ULF module this weekend.
One more question...
I was looking through my copy of the installation instructions (01 29 0 304 506) and re-reading this thread and I'm still curious what the SA 640 telephone prep option is. Was this something only available in Europe, as was the extra BT display in this kit that mounted above the speedometer? I'd prefer not to have the extra antenna on my windshield, if I already have it wired internally. Btw, why not include the extra BT display in the kit - did it just reproduce the info that already is transmitted on the radio display, or something extra?
  #96
Old 12-05-2013, 06:09 PM
joylove's Avatar
joylove
joylove is offline
Yes. No aditional information is available.
The display is for Boost radio/casette equipped cars that didn't support the IKE iBus messages like the CD player does.
  #97
Old 12-06-2013, 05:42 AM
You are welcome. Hopefully you can find that sheet, it might be with the other manuals in the glove box, sometimes separate. Yep, the little display that shows on the parts diagram was never included in the US market. Used for displays that would not support that function, which I believe were not in this country.
  #98
Old 12-06-2013, 10:54 AM
briggsy's Avatar
briggsy
briggsy is offline
Thanks ya'll. Any other info on the SA 640 telephone prep option mentioned in the instructions? Did cars in the U.S. come standard with this, or was it included in the MFSW option?
  #99
Old 12-06-2013, 01:30 PM
joylove's Avatar
joylove
joylove is offline
Most cars did not get it. Late model hatchbacks might have it. It'll be country, date, bodystyle specific.
You can check your build sheet here.
http://www.bmwarchive.org/vin/bmw-vin-decoder.html
  #100
Old 12-06-2013, 04:11 PM
briggsy's Avatar
briggsy
briggsy is offline
I have one of the latest hatchbacks (9/06) and according to the VIN decoder the phone prep is not there...
Quick Reply: R50/53 R53 OEM bluetooth retrofit
