R50/53 2002 Mini S Oil Temperature Question
I have recently installed an electrical oil temperature gauge on my early 2002 Mini S. The sensor is installed in the oil drain plug. The engine oil temperature runs at about 240-250 degrees on warm days, which is hotter than I anticipated. What is a normal oil temperature for this engine?
I've got the same setup on my 04 MCS. Autometer Oil temp using the oil drain plug for the sensor. My oil temperature runs right at 200. My engine coolant temp varies around 200-220 stopped, depending if the fan is on. On the road the coolant temp hovers around 200. I have an UltraGauge attach to my OBD ports at monitors my engine temp.
I have the Chrono Gauge Pkg on my '06 MCS that I just bought. On the way back from Miami (where I bought the car) in 95 degree heat on Alligator Alley, my Oil Temp climbed up to about 220 running around 80mph.
As soon as I got back home (Siesta Key), I had my mechanic dump that oil and put in Amsoil Synthetic 5w30 with new filter. Now - believe this or not - running on the interstate in the same conditions/speeds above - my oil temp will not climb above 200. Mater-a-Fact, it stays perfectly still at 200 or 190. Go figure. I'm happy there.
I'm running Mobil 1 0-40, recommnded oil, It been working just fine. I just hit 100K this weekend and it still runs and looks like a puppy. Oil pressure and temps are good. Engine just purrs like a kitten, "Tiger cub that is", I have only replaced the SC oil and the water pump a couple weeks back . Other than that no other issues
Approved oils feature the SAE grades 5W-40 and 5W-30. These oils can be used for driving at all outside temperatures.
There is really not much difference other than 0W-40 having less voscoity when cold. However, I tend to lean towards keeping my voscoity(s) (low and high values) closer together due to having less additives. And a 30 weight oil tends to be designed to save fuel. See Motor Oil 101 - Chapter 1 for more info.
Engine oil temperature question.
I removed the skid plate from under the engine but there was no significant change in the indicated oil temperature. The ambient air temp was 82* and the engine oil temp leveled out at 250 degrees at 60 mph. I was wrong about my early 2002 S model lacking any provision to cool the oil. It does have an oil heat exchanger below the oil filter. I am running Amsoil 0-30. I was taught many years ago "the gauges never lie". Despite that, I will change the oil temp sensor at the next oil change.
I recall one of my car owners (midgets) taping over the gauges on the dash and telling me "stand on the gas, if it blows up, it blows up." Maybe a little masking tape will solve my oil temperature concerns.
Thanks again everyone for your input. MitchS
I have a 2002 MCS R53 with 100k on it and it runs at temps between 100c and 110c. ( at the highway driving fast). this is also the middle of the gauge. usually, you can assume that normal operating values are always in the middle of any gauge.
07-16-2020 12:54 PM
Mini'mon
08-16-2015 04:15 PM
M7Speed
08-06-2015 01:48 PM
