R50/53 new pulley, belt slipping?
on
06 R53, 37k miles. i installed the WMW pulley this weekend. also put on the new belt and the tensioner stop. all went smoothly on take apart and rebuild. first startup was normal. if i really romp the throttle though, it makes a very loud screeching noise. my buddy came over and we loosened the bolt on the tensioner right above the pulley, and it helped out some. still screeches a little bit. so my question is, is there a certain torque or something i can set that bolt at? the directions didnt specify.
i did torque the pulley bolts to 60 in lbs. more? less? other pulley loose?
Vendor
If the tensioner stop cable isn't in the right position it can cause that. Remove the cable and see if it does it. If the noise goes away you just need to reposition the cable. What happens is when the cable is on wrong the tensioner can't put full tension on the belt, then it makes noise.
on
"If the tensioner stop cable isn't in the right position it can cause that. Remove the cable and see if it does it. If the noise goes away you just need to reposition the cable. What happens is when the cable is on wrong the tensioner can't put full tension on the belt, then it makes noise."
and i will give that a shot. thanks!
on
I have a slipping belt as well. WMW 17% pulley, K060532 belt, new tensioner, ATI super dampener in the stock diameter. I can hear pulley slipping above 5000 RPM and the power loss is confirmed by data logging.
Does anyone have a solution to preventing belt slip? I don't think I could get a smaller belt on there - I already have to pull on the tensioner tool pretty good while slipping over the idler pulley or it won't go.
I have a slipping belt as well. WMW 17% pulley, K060532 belt, new tensioner, ATI super dampener in the stock diameter. I can hear pulley slipping above 5000 RPM and the power loss is confirmed by data logging. Does anyone have a solution to preventing belt slip? I don't think I could get a smaller belt on there - I already have to pull on the tensioner tool pretty good while slipping over the idler pulley or it won't go.
Hey- part 6 is posted.
I might see about an even smaller belt but don't know if it will be possible to even compress the spring that much.
I was wondering also about a stiffer spring... It would not be easy to do that without some special jig to hold everything in place. There should be a market for that.
I think I will probably end up using the Alta fixed tensioner...
I had a similar problem with a 15% pulley. Long story short. I bought a 16% and found an Alta *gag* 15% and when I put everything back together it was wailing And screeching. I took it apart today to replace the tensioner and noticed that my WMW tensioner stop worked really ONLY with the little washers on the side with the bolt head. If the washers get on the damper then the hex bolt clamps down on the stop and prevents the damper from aiding the spring. All went well after I fixed that...... Aaaand then I snapped my ground mount on the engine. F%@!
elverado
01-18-2022 02:51 AM
patsum
26
05-29-2021 06:29 PM
09-16-2015 02:01 PM
