Replacement Cigarette lighter housing?
Hi all - this is my first post
Anyway, my wife just bought an '05 Cooper, and the front cigarette lighter doesn't work. It won't heat up the element, or charge a phone, gps, etc. I've looked everywhere online and can't find an OEM part to replace it. The dealer wants $250 to fix it (pssshhhhh yeah), so I'm hoping the gurus here can help us.
J
J
Sorry, forgot to mention that - yes, I have checked the fuses, and they're fine.
Interesting side story...the passenger door lock was broken, so we couldn't program the new key we 'thought' we needed. Then we fix the door lock for $500...turns out the dealer says there's a sensor in the side mirror that is keeping us from programming the key and THAT need to be replaced for another $250. Huh?
The lighter socket has two plugs on the bottom. After checking fuses, next check to see if it has come unplugged.
The socket itself is a pretty darn simple thing... can't imagine that the problem is the socket itself... unless it's full of caramel mocha.
In that case, it costs $4.00.
Here's the diagram:
http://www.realoem.com/bmw/showparts...=61&fg=35&hl=2
How to find OEM parts:
Go to RealOEM.com
Enter your model, manufacture month, etc.
Browse or search to find the parts your looking for.
Call a MINI dealer (like Morristown or Classic MINI who offer NAM discounts) or, if you must order online, go to PelicanParts.com
Select "BMW" at PelicanParts
Paste in the part number from RealOEM.
Part price will be shown.
Order
Here's the diagram:
Go to RealOEM.com
Order
I lifted up the console to see why it wasn't coming out, but I couldnt figure out how to take off the lightbulb thats attached to the luminous ring. The socket can turn within the ring about a quarter turn but that's about it. It pulls out a quarter of the way out of the luminous ring but thats about as far as it goes..
I think that luminous ring is the one that has to come out for the whole lighter to come out, I took out mine to replace the amber ring" it was broken anyways so it came out easily but as it turns out my 05 didn't have a bulb so I just bought another Ring and installed the socket.
By the way check to make sure that you don't have a penny stock in there.... I know it's silly but possible, good luck
Yea, they can stick when coffee or soda is dried in there.
Here is the break down.
Socket For Cigarette Lighter Part # 61346973035
http://www.ecstuning.com/Search/SiteSearch/61346973035/ES2674216/
Which has the little yellow luminous ring surround, which slides over-top and lock the cig socket in place. You can access this from taking out the panel cover the console.
Luminous Ring Surround - Priced Each Part # 51167052720
http://www.ecstuning.com/Search/SiteSearch/51167052720/
If you need a new plug stopper ( blank ) or for people who don't want things to drop in there.
Cigarette Lighter Block-Off Plug Part # 51168222183
http://www.ecstuning.com/Search/SiteSearch/51168222183/ES86890/
Or
Lighter Element Part # 61346969134
http://www.ecstuning.com/Search/SiteSearch/61346969134/ES168948/
Good luck.
Or
Good luck.
so I'm a little unclear as I'll be doing this over the weekend. Does the lighter come out through the top? My illumination ring is cracked but the lighter does work for charging cell phones, it just moves all around.
I'm purchasing all the pieces to replace all the parts from ECS. $17 total. But then I'm adding the dual port USB Charger they have too. Nice edition with the red ring and considering my mini is Crock Red.
Any help would be much appreciated. I really don't want to remove the entire center console just to replace the lighter.
so I'm a little unclear as I'll be doing this over the weekend. Does the lighter come out through the top? My illumination ring is cracked but the lighter does work for charging cell phones, it just moves all around. I'm purchasing all the pieces to replace all the parts from ECS. $17 total. But then I'm adding the dual port USB Charger they have too. Nice edition with the red ring and considering my mini is Crock Red. Any help would be much appreciated. I really don't want to remove the entire center console just to replace the lighter.
nevermind, I figured it out. The flat part of the metal connector, not the part that has the curl down its that grab onto the Spade, you need to slide a screwdriver in between that and metal and the housing plastic. That will let you pull the connector and the wire back out of the plug
Yes, just a small flat head will do it.
07-16-2020 12:54 PM
PSIChocolate
08-13-2015 12:46 PM
