MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > R50/R53 :: Hatch Talk (2002-2006)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Head Unit Upgrade
11 Replies, 1,713 Views
Go to first new post Problem coding FRM/FRM2
18 Replies, 588 Views
Advertisement
Thread Tools Search this Thread
Old 04-07-2008, 07:09 PM
COOPERPOOPER's Avatar
COOPERPOOPER COOPERPOOPER is offline
Gallery
Funny Clutch Sound / Squeeling!? any ideas? Warranty?
I bought an 06 R53 with only 9K miles. The car has 16K miles now and ever since I have had it, the clutch has been making this annoying squealing / screaming, metal rubbing sound when I let out the clutch. I know how to drive a manual pretty well, so I do not think it is operator error. In acceleration, I rev to 2 - 2.5 rpm's and release smoothly. The sound is on and off - when it does happen, the car doesn't feel any different.
If this is some type of mechanical problem vs. maintenance - would it be under warranty?
Thanks for your input.
Jared
Old 04-07-2008, 08:10 PM
JakeMandell JakeMandell is offline
Gallery
Jared,
I too am experiencing the same problem on my '06 with 23k miles. The car is at the dealer now and I am being told that they cant reproduce it. Of course. They have told me that in order to check it out, they will have to charge me $1500 to drop the tranny and inspect. If it appears that the clutch was abused, then I pay and if it looks like it hasn't been abused then dealer will cover it. The service guy also told me that he has NEVER seen a clutch covered under warranty. Thats comforting.
Please let me know what else you find out. I will let you know what I am told.
Jake
Old 04-07-2008, 08:36 PM
imortalsin84 imortalsin84 is offline
Gallery
i have the same problem the tech at mini said something with the clutch is warped...yes no clutch is covered by anyone no matter what they tell you when you buy the car they will not cover a clutch
Old 04-07-2008, 09:36 PM
Some Guy's Avatar
Some Guy Some Guy is offline
Gallery
Squealing is a new one to me. I know that the clutch on 05-06 have been known o make a groaning noise when being released. This is due to oil leaking onto one of the clutch surfaces, it doesn't hurt it, it just annoying.
But I cant say I have heard of the squealing you talking about.
'05 HB/B MCS.
With: LED lit scoop - DIY AUX cable - Angel Eye running lights - M7 STB - Air horn - Rally Lights -SVT Focus LSD - Poly Control arm bushings - IE fixed plates
UCONN FSAE Engine Systems Head '10-present
UCONN FSAE dyno testing and tuning lead '09-10: www.uconnracing.com
Follow UCONN FSAE on twitter: http://twitter.com/UCONNFSAE
Old 04-08-2008, 12:18 PM
sequence sequence is offline
Gallery
Glazed Flyhweel
OK guys, this sounds like a glazed dual mass flywheel, because the OP described exactly what happened to my 05 S with only 24,000 miles. A good test is to drive the car to a level spot, keep the engine running, put on the E brake, put it into first, and slowly let the clutch out while giving it a little gas. If you here a loud squeal/groan, you have a glazed flywheel. Offer this test at the dealer to reproduce it (my dealer showed me this test when we reproduced it.)
Unfortuantely, this is a common problem on R53s and R56s. On the R53, y'll have to get a new DM flywheel and clutch, because DM flywheels cannot be turned. If yr under warranty dont let the dealer pull the "operator fault" BS, because this is a well-documented issue. My dealer didnt even question it and replaced everything uder warranty.
Oh and the repair is about $2,600 if y're not under warranty
PS Jared, Ralph Schomp MINI repaired my flywheel/clutch under warranty no questions asked. Both Robert and Devin know of this problem, so you should be covered. Of course then unlike many MINI dealers, RS is NO BS.
I say, boy, you dont seem to be apprehendin' the general gist of what I'm tryin' to convey here. Maybe you oughta take a second, let your head catch up to your tongue before it gets all sunburnt. That was a joke, son, I say - a joke! Nice boy, but he's about as sharp as a sack o' wet mice.
09 MCSa JCW
Old 04-08-2008, 12:21 PM
Gallery
Quote:
Under an extended warranty yes, but OEM? No way. The clutch and flywheel are covered for 4 years 50K.
That is load of total complete assaholic BS from yr service guy, that and them charging you $1500 to pull it out to inspect. WTF? Good grief MINI! Screw the customer while yr at it! Some dealers pull this crap all the time to get out of charging BMW back for a very expensive OEM warranty repair, to place the blame on you. If trouble persists, call MINI-USA and complain loudly!
09 MCSa JCW
Old 04-08-2008, 12:28 PM
TexasCooperS TexasCooperS is offline
Gallery
It sounds like a throwout bearing. I have never heard of a glazed flywheel making noise like that. If anything it would just cause it to slip a little bit
2003 MCS- no mods...yet
Old 04-08-2008, 12:33 PM
Gallery
Throwout bearing noise would be evident at all gears, the glazed flywheel groaning/Squealing sound is only evident under load in first gear, when letting out the clutch.
because this has happened to me, I would bet good $$$ that the OP's problem is a glazed flywheel, because MINI has proof that this problem has existed in R53s with as little as 5,000 miles on the clock.
09 MCSa JCW
Old 04-08-2008, 12:35 PM
Gallery
Quote:
Who the F#$% is giving out this information?????
(Also, this thread should be in stock problems/issues.)
09 MCSa JCW
Old 04-08-2008, 02:47 PM
Gallery
Quote:
Originally Posted by COOPERPOOPER View Post
. The sound is on and off - when it does happen, the car doesn't feel any different. Jared
this is the giveaway for the glazed flywheel. It's not a drivability issue, just annoying, and Schomp will fix it for ya if y're still under factory warranty. Just call Robert or Devin and tell them U think it's a glazed flywheel, and a tech will go out with ya to do the test (described above) to reproduce the sound and confirm.
09 MCSa JCW
Old 04-08-2008, 02:54 PM
kalbone kalbone is offline
Gallery
really???? umm... i got 3 clutch replacements under warranty....
Old 04-08-2008, 03:11 PM
Gallery
They are telling me that "normal wear" is covered under 4yr/50,000 mile warranty. But, the service guy told me that he has never had a clutch that showed "normal wear" when inspected. That sounds like a load of bull to me.
Old 04-08-2008, 04:28 PM
MaxMCS MaxMCS is offline
Gallery
I've had the same problem with my '04 MCS, and I was told by the dealer that the flywheel had been worn smooth and when I let it out, it would vibrate against the clutch disc and create harmonics, which ended up in a "whistling" sound. They didn't cover it under warranty, and after about 5,000 more miles of driving on it (and a track day) the noise is completely gone. So, I guess you just need to keep wearing it down until the harmonics stop!
Old 04-08-2008, 05:41 PM
Gallery
Yup Jake that's a load of donkey hooey. What precisely is "normal" under BMW standards, according to that guy, and doesn't he realize that faulty components prevent "normal" wear?
If y're in an area with a lot of dealers (like S CA) you could go get a second opinion. Dealer-wise, I and the OP Jared only have one choice, and Im glad they dont pull this bull.
And if I was off warranty and needed a new DMF/clutch, Id just go to Randy W and install a H/D racing setup rather than deal with this sketchy, hi-tech easily glazable German engineering.
09 MCSa JCW
Old 04-08-2008, 08:21 PM
Gallery
Thank you so much! I will set up the appointment to get this fixed! I usually talk to Devin.
Also, I tried the e-brake trick today and was indeed able to reproduce the sound.
I feel much better now! Thanks
Old 04-09-2008, 09:26 AM
MUShadd MUShadd is offline
Send a message via ICQ to MUShadd Send a message via AIM to MUShadd Send a message via Yahoo to MUShadd
Gallery
I just had my flywheel and clutch replaced over the exact same issue. It fell under the service warranty, which had expired. However, the dealer,Cincinnati MINI...being the awesome ppl that they are, replaced everything for me for free, and the car wasn't even purchased from them.
Gallery
right on, man. Schomp will treat you right.
09 MCSa JCW
Old 04-09-2008, 10:39 AM
DaveTinNY's Avatar
DaveTinNY DaveTinNY is offline
Send a message via AIM to DaveTinNY
Gallery
Garage
I feel better now... ONLY in 1st gear when taking off cold, I'll hear a brief (1/4 second or so) horn sound (horn as in orchestra brass) upon letting out the clutch pedal... after she's warmed up I don't have that sound in 1st.
67,000 miles so far. 2005 MCS.
MINIs On Top 09 http://www.youtube.com/watch?v=MO0zC99H6bQ
2005 MCS LSD, DSC, CBC, SPORT, Harman Kardon system
XM Radio lifetime subscriber 17" S-Heavies with 205/45 Yokohama Envigors in summer; 15" ASA Blizzak REVO 1s in winter, M7 Strut Tower Reinforcement plates, Moss Motors PS Fan shroud
Old 04-09-2008, 07:44 PM
AutoXR53 AutoXR53 is offline
Gallery
To say something from the eyes of a service tech, he wasn't lieing to you. Most clutches that have under 20k on them don't need replaced b/c of a defect, most of the time it is in fact b/c someone smoked the clutch. He probably wasn't trying to feed you a line he was probably telling you the truth that when they take them appart and there are a bunch of blue and black hotspots on the flywheel that's not normal for under 20K. I recently replaced a clutch and flywheel in a 2008 Civic Si b/c some punk kid blew it out at 5k. But since it is a documented problem with the R53 and having encountered it in my own when it is below 20 degrees out, I agree that it should be under warranty. I mean heck you should see some of the stuff Honda warranties... it's insane haha
Forced induction is so delicious...
http://www.myspace.com/jamesf1985
Old 04-09-2008, 08:50 PM
Gallery
thats exactly how mine acted....it got a little worse though, doing it more frequently, and for slightly longer, i could feather the clutch and increase/decrease how long the noise lasted.
Old 11-05-2009, 09:22 AM
deanjay98 deanjay98 is offline
Gallery
I can tell you exactly what it is. It is the Clutch Release Bearing. You basically need a new clutch set. It can just be replaced without new clutch, and cheaper if money is tight; but it is wiser to just get a new clutch!
In UK about 500 pound, aprox-$1000. But once you have new clutch that horrible chewbaca noise goes away, and a nice smooth clutch again
Old 11-08-2009, 10:20 AM
Boxcars Boxcars is offline
Gallery
i described mine as
uurrhhttt sound, first gear release only.
it was replaced by the dealer under warranty
clutch, flywheel and throw out bearing,
done at 39k, rep said there was a TSB on it?
boxcars
2005 MCS BRG/W Sport Pkg / Chrono Gauges / Front & Rear Fog Lights
Pirelli P Zero Nero 215/45/17 / 17" Konig Feather Wheels / Cobra Laser Radar Detector / Garmin Nuvi 250W / M7 Strut Tower Brace / 20% window Tint / M7 Air Plate Diverter / 3" MiniMania Antenna / Texas Speedwerks Engine Damper / Texas Speedwerks Springs / H-Sport comp sway bar / M7 OCC / Detroit Tuned Tensioner Stop / Carbotech Bobcat Brake Pads / TSW Slotted Rotors / DDM CAI
Old 11-12-2009, 05:55 PM
e3zkiel's Avatar
e3zkiel e3zkiel is offline
Gallery
Yes there is a TSB on it and it is a well documented issue. Just stick to your guns. I know the TSB # is in this forum somewhere. That's how I got mine replaced under warranty.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
