MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > R50/R53 :: Hatch Talk (2002-2006)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Hot or Not (Fuses)
by oPossum
65 Replies, 17,518 Views
Go to first new post Problem coding FRM/FRM2
19 Replies, 598 Views
Go to first new post MINI's on TV!!!
134 Replies, 4,451 Views
Go to first new post Best FMIC
2 Replies, 77 Views
Advertisement
Thread Tools Search this Thread
Old 03-19-2008, 05:50 AM
cycleway4 cycleway4 is offline
Gallery
Power Steering Pump Fan Operation
OK,....I've searched thru lots of threads,..cant find exactly what I'm looking for. I'm not having any problems, but I would like to know the operation conditions needed for the P/S cooling fan to operate...does it run all the time?..[havent looked to see if it does]..is it temperature controlled/thermoswitches?/relay/timers?....just was curious to know, so I know what to watch for....
thanks,
Steve
Old 03-19-2008, 06:10 AM
cmt52663 cmt52663 is offline
Gallery
Quote:
thanks,
Steve
http://www.northamericanmotoring.com....php?p=1817550
Cheers,
Charlie
Charlie Thompson
'04 MCS, Works
NER SCCA - STX
Quaife, H&R Coil Overs, LCA, Rear Sway, Webb Camber Plates, Borla Race, and Cupholder Delete. Kosei K1 at 15x7 +38. Tuning by Turner Motorsport of Amesbury MA.
Old 06-08-2008, 01:47 PM
Eurothrasher's Avatar
Eurothrasher Eurothrasher is offline
Gallery
Power Steering fan ~ Is it supposed to run all the time ?
RE: MINI 2003 - R53 Power Steering fan proper operation. Is not running when car on.
I checked all previous threads on issues with regards to MINI's Power Steering fans, mine is down to the wire on a 90 day warrany from non Mini dealer - and she is going in on Tue for unrelated matter;
Do they operate off a thermostat switch and only come on as needed ?
or
Do they come on with ignition start up, to run 24/7 ?
Thanks for the help.
Old 06-08-2008, 02:13 PM
Gallery
Quote:
Originally Posted by cmt52663 View Post
Charles,
In regardst to this thread, What does the A/C have to do with the Power Steering pump exactly... why would turning on the A/C make the power steering pump fan initiate ?
That is what the thread states. Maybe this is why the pumps are failing, they should be rigged up to run all the time ?
In my day I have heard/seen some dumb arse manufacturer's designs before but this one take the cake !
Old 06-08-2008, 04:21 PM
burberryed burberryed is offline
Gallery
The PS fan comes on when the low speed function of the cooling fan comes on. This is determined by engine temperature. The AC increases the engine temperature, thus causing the fan to engage. When the temperature decreases the fan disengages.
Old 06-08-2008, 04:27 PM
Gallery
Comes on when the low speed cooling fan comes on.
Old 06-08-2008, 04:45 PM
Xymox Xymox is offline
Send a message via AIM to Xymox
Gallery
Quote:
What's the easiest way to get the low speed cooling fan to engage to test to see if the power steering fan spins?
Thanks.
Old 06-08-2008, 05:54 PM
Gallery
Fan SUks
Quote:
Thanks.
Bought this R53 used with 55,000 mi. two months ago. And after oil change Saw that the PS fan housing was grimy and that the fan spun like it was full of sand.....
Drove the car up on Rhino Ramps and removed the fan's housing bolts with a SAE 1/2 socket ( YUP ~ SAE 1/2" Fits tighter on any 13 mm nut on MINI's) I cleaned it up with some WD40 and a rag, replaced and it, started up the car and it didn't come on. I was not sure if the fan's bearings heated up and cooked the elect motor, or if the PS fan was thermostatically controlled.
So I entered a post here and got no immed response.
So I checked the 5 A fuse behind the panel next to drivers side left foot well. Found a blown fuse, and the spare 5 A was gone too. So it must have blown before.....
Fired up the car, turned on the A/C which automatically turns on the High speed Engine Cooling fan, and about 30 seconds later........I thought my girlfriends cat got caught up in the serpentine belt
The PS Fan was making the most terrible racket one could only imagine. Must be bad bearing(s) for the fan I guess.
Was this fan an afterthought or something ? Or, purely the end result of German barley and hopps intoxification
Either way, not much thought went into its design, placement or inherint climatic hazzards. One of my 7 yr old twins could have done a better job with an eraser board and markers
Old 06-08-2008, 06:48 PM
Gallery
You can just start the car and let it warm up. You can see and hear the low speed cooling fan come on. The PS fan should come on at the same time. It will go off as soon as the cooling fan stops. Turning on the AC speeds up the process.
Old 06-08-2008, 06:58 PM
Gallery
Hahaha! You're analogy rules. However, it's more like the end result of English fish and chips without the malt vinegar.The power steering pump and fan are a Rover holdover. BMW switched it out with a fully electric power steering pump unit in the current MINI (R56).
Old 06-08-2008, 07:58 PM
Gallery
The new electric unit looks similar to the old unit, but without a new manual it is impossible to know what mods would be needed to make it work on the 02-06 MIMI.
Old 06-08-2008, 08:08 PM
Gallery
Jag owner
So now the German's are taking lessons from this loser SUV company whom now has to make their trucks in INDIA ? It just keeps getting better and better
Cheers, Pass the Beer Nuts !
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
