Hydraulic Floor Jack Issue - North American Motoring
Old 09-20-2013, 09:25 PM
DRoc7822 DRoc7822 is offline
So tonight I went out to jack the car up to check a few things. Pulled the jack to the jack point and proceeded to lift the car. I got the car half way up and then it wouldnt lift it anymore. Let the car down and now it wont lift the car at all. I tried standing on it and it will lift me perfectly fine. Just seems the car is to heavy to lift. Its a 1.5 ton Pittsburgh 69252 Aluminum Racing Floor jack that I've had for maybe 6 months. I looked through the manual to see what the possible causes could be, I bled it, checked the valves to see if they were blocked... and checked the hydraulic fluid. All seemed fine. Was curious if there was anything else I could do for the jack to work again. Jack is in prestine shape (only had for 6 months and only used it a handful of times). Thanks in advance.
Old 09-20-2013, 11:11 PM
danjreed's Avatar
danjreed danjreed is offline
Low fluid?
Seal failure?
Cheap Harbor Freight crap strikes again?
Take it back, chances are they will hand you a new one without an issue.
Old 09-21-2013, 08:11 AM
Yeah I checked the fluid and it seemed filled. First time I've ever checked hydraulic fluid in a jack. But when I unloosed the fill plug some fluid came out and I tried adding more but it didnt seem like anymore could go in. Maybe I just dont know what I'm doing. But didnt seem to hard to put in. It seems like every time I try and pump the jack with it under the car theres this loud whoosh sound each time I pump. All plugs though are tight and had never been loosened prior to bleeding it or adding fluid. There was a 90 day warranty on it but its been about 6 months since I've had it and the closest one is 45 minutes away. I may try and take it back though.
Old 09-21-2013, 08:28 AM
danjreed's Avatar
Quote:
Sounds like the seals failed...
Old 10-06-2013, 01:31 AM
Eric_Rowland's Avatar
Eric_Rowland Eric_Rowland is offline
Quote:
+1
That it will lift you shows that the mechanicals are functioning, but you're not getting the hydraulic pressure to lift 1,000+ lbs
Old 10-06-2013, 08:06 AM
Fly'n Brick Fly'n Brick is offline
Sears/Craftsman. $50.00. 1 year warranty.
Thread Thread Starter Forum Replies Last Post
FS:: NOVA: 2012 MINI JCW (factory) w/ 100k Warranty + TONS OF EXTRAS! igzekyativ MINIs & Minis for Sale 25 09-21-2016 05:38 PM
2002 R53 Creaking/Clacking maestro39 R50/R53 :: Hatch Talk (2002-2006) 3 10-27-2015 03:38 PM
Advice for budget DIY brake & rotors replacements thebordella R56 :: Hatch Talk (2007+) 22 08-31-2015 02:37 PM
What I learned from dropping the subframe minipopkart R50/R53 :: Hatch Talk (2002-2006) 2 08-13-2015 06:22 AM
:: ECS Tuning :: New Items from ECS Tuning ECSTuning Vendor Announcements 0 08-07-2015 09:02 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
