Navigation & Audio presets
What do you do when you go to the station you want to preset, hold the button down and it gives you an error message "cannot complete request"? It works on one AM station I tried, but no HD and no FM. Can't find a thing in the manual about this. I am reasonably tech savy and I am pulling my hair out. I'm setting it up for my wife who is 0% tech savy so this is not working out very well.
I have found for some functions you must set the button not while viewing the item, but while it is selected in the list of the menu tree above it. Pretty much anything in MINI Connected or Settings I have to set this way. Radio stations work as expected though, both FM and satellite.
Hope this is of some help.
- Pull up list of stations
- Highlight station to set
- Press OPTION button on controller or radio, then "Store Station"
- You should see "Presets" on top of screen. Rotate controller to select Preset slot and press to confirm - you should hear a chime and it will spit back to the station list
- Repeat with other desired stations
TO ACCESS PRESETS:
- From main menu, go into Radio. Tilt joystick left until you see "FM, AM, Presets, Tone" and select "Presets"
- My preferred option: Set "Presets" as one of your Favorites buttons (1-6 buttons)
TO ACCESS PRESETS:
babydoc (07-01-2018)
cflowrider
11-19-2016 12:37 PM
ObiWein
09-19-2016 01:05 PM
Quijote
General Mini related Ads
09-18-2016 04:48 PM
