Navigation & Audio How to: Upgrade sound system
#101
Well, I found the problem. The "Power IC" setting in the Audio section was set to "off". I'm not sure why a "reset" as called for in the manual didn't re-set this item. Well its now working. Though I did something to the antenna, broadcast stations are not coming in, they did before (the tuner successfully found stations) but now FM is all static. But that's another day's problems...
#102
on
I seem to have a nasty habit of answering my own questions, not long after I ask them here, LOL.
I just spoke with a Crutchfield tech advisor, reguarding my questions above, and I learned the following:
The red "Ignition" wire, in fact, can and should be connected to the factory purple/blue "Accessory" wire (PIN-16). What I was basically told was that, because this pigtail connector is used for more than one model vehicle, the red wire is not included within the connector because most of those other vehicles cannot use it. ...But ours' can.
The orange "Illumination" wire also should be connected to the factory grey/red "Illumination" wire (PIN-14). The tech advisor seemed to be kind of surprised that an orange wire was NOT included in the pigtail. Looks like I'll be using a "vampire clip" to tap into the factory wire for that one!
But here was the big surprise for me...it was kind of an "...Oh, by the way"-question: The aftermarket HU's (Alpine, in my case) blue/white "REMO" (Amp Turn-On) wire DOES NOT connect to the factory white "Power Antenna" wire (PIN-13). This wire must be run directly from the HU to the amp/s, or whatever you're using it to turn on. Instead, the HU's blue "P. Antenna" wire should be connected to the factory white (PIN-13) wire (via the blue wire in the pigtail). The question immediately becomes, why is this important...these cars don't even have power antennas? The answer is that they DO have antenna booster modules. The factory "Power Antenna" wire powers this module. If the Amp Turn-On lead is connected to the booster module, it will be "hot" all the time, whenever the HU is switched on. This may cause noise, or interference, when modes other than AM or FM radio is used. (Could this be why so many people experience noise issues with aftermarket installations? ) And of course, if neither the blue OR the blue/white leads are connected to the booster module, the module will never get power, the symptom being bad radio reception.
I'm posting all this here because, based on all my searching, I don't think ANYBODY else here actually knew this! (No need to thank me.)
picture 2. is my stock pile of audio supplies waiting to get installed
picture 3. a close up of my kenwood KDC-BT948HD. I had the kenwood excelon KDC-x994, but I returned it when I found out the BT948HD was coming out. I bought it mainly for the looks, I dont like the way most HU's look too glossy(almost cheap). I wanted to have a matte finish to go with my mini's interior and not stick out. The screen and the control **** is the only thing that is glossy, the rest has a matte finish. only negative is I went from a 5-band EQ to a 3-band....which shouldnt make that much difference
#104
Which harness is that actually? Crutchfield provided me with the Metra 70-9003. This harness is missing the illumination and ignition (hot) leads, hence, it comes with a separate red wire with the fuse tap. I looked at the Scosche VW03B and it appears to have more wires/pins in it.
Like I replied earlier, I discovered this thread about a month after doing my install the "Crutchfield" way, so, I wish I'd had the pinout information that ellcapitan has provided!! I really don't like the fuse tap. If I can determine that the Scosche has all the wires, I might even considering switching it, though, that's a pain in the butt.
UPDATE: I just discovered that Metra has instructions for their harness on their website. These include an exception for MINI which shows how to connect the long red wire into pin #16. It does seem that this is a newer revision of the one I received from Crutchfield. It is still missing the illumination lead though, but it's still an improvement.
Last edited by Scavenger; 03-30-2011 at 05:06 PM. Reason: new info about Metra 70-9003
#105
on
Like I replied earlier, I discovered this thread about a month after doing my install the "Crutchfield" way, so, I wish I'd had the pinout information that elcapitan has provided!! I really don't like the fuse tap. If I can determine that the Scosche has all the wires, I might even considering switching it, though, that's a pain in the butt.
This is the metra 70-9003 harness, I just simply moved the green speaker wires to the Ignition and illumination's respected spots.I didnt like the idea of running a seperate wire to the fuse panel either!!! This is the first time I've ever seeen this....the factory HU has to get its power from somewhere!! If you are running an amplifier this is possible but not if you are running the HU as a power source. Not unless you go to a local stereo shop and ask if they could help.
#107
on
I'll do a complete write up when I do my install
#109
on
https://www.northamericanmotoring.co...6_800x600_.jpg
https://www.northamericanmotoring.co...8_800x600_.jpg
https://www.northamericanmotoring.co...4_800x600_.jpg
https://www.northamericanmotoring.co...5_800x600_.jpg
a few pics from my gallery. did the install last week....to be honest it took longer then i expected. The week before I did a stereo in a friends truck and it only took me a day. Mine took me 4!!! I guess because I had to run all new speaker wire and add sound deadening. The first day I spent on the driverside door alone. running speaker wire thru the doors is no simple task.
#110
The first step at least in my mind would be to make sure that the new speakers, head unit, amp, etc (the whole works) will actually work together as a system before any work starts or any money is spent. Suffice it to say that I had a fried amp in my basement for years that simply would not work with my other components (and had to replace) that I did not want to pay to have repaired, but could not bear to throw away.
#111
There are only three ways I can think of that would meet your criteria.
1. Rely on a pro to design and install your system. Be prepared to write a very big check. Depend on the pro to make it work.
2. Turn your specs over to someone at Crutchfield and depend on them to design a system to meet your needs.
3. Exactly duplicate what a buddy has done after hearing his install. Assume your needs are exactly the same as his.
There is a fourth potential approach. Build your system in stages. That is what I'm going to do.
1. Start out upgrading the speakers. Listen to the results of the upgrade. I ordered my Polk DB-6501s and DB-691s from the cheapest source, Amazon. In my case I've installed these speakers before in my '11 MCSC. After installing, decide if the speaker quality improvement meets your objectives. If there is a possibility you may not go on to step 2, pick very efficient speakers as the MINI base head unit is underpowered. That is why I went with the Polks in my last two installs. If the speaker imprivement does not sufficiently meet your needs then:
2. Do the head unit swap next. Before purchasing the head unit, make a list of what is important to you and what isn't iPod, Bluetooth, HD, satellite, etc. In selecting the head unit, make sure it is MINI compatible. If you have steering wheel controls, make sure it can be operated (with an adapter) from the steering wheel. The Crutchfield site is helpful here. I'll order the head unit from Crutchfield even if I pay a premium as the advice, the installation materials, and Mini specific instructions are worth the premium. After the head unit swap, evaluate how you feel about the power/distortion tradeoffs involved in powering your door and rear panel speakers directly from the head unit. Evaluate how well it supports the requirements you listed earlier. Evaluate whether the bass response meets your needs. If you feel you are underpowered:
3. Purchase and install a separate booster amp to power the door and rear panel speakers. Make sure the head unit you purchase has six pre-amp outs. Four will go to your booster amp. The amplified output will go from the booster amp to your speakers. Evaluate whether you need a sub after going through the amp upgrade. If yes:
4. Purchase and install a powered sub. The other two pre-amp outs will power the powered sub. If you plan to do a rear seat delete as I do, you might instead go with one or two small subs powered by a sub amp and build the subs into the rear seat delete cover.
Some of us (myself included) tend to panic and feel we need to do everything right now. It is a whole lot easier on your wallet and not a great deal more work if you take it one step at a time. If something goes wring and you take it in stages, it is a lot easier to debug the install, "Speakers were working before and aren't now, I wonder what I did wrong in installing the head unit?"
My speakers are on order. I should see them next week. I'm trying real hard to avoid pulling the trigger on a head unit purchase for my new R53 until I've installed the speakers and see how it sounds. But it is so tempting to move on to Step 2 before you have finished Step 1.
I have a sub amp and two small subs that were intended for a Chevy Avalanche install that never happened. I also have an Alpine Amp and a powered sub that were purchased to install in my '11 RCSC. My lady who is driving the RCSC MINI is pretty happy with what she has. Expensive lessons have been learned.
On the other hand, I may already have the booster amp I need and either a powered sub or a sub amp with two small subs to complete my installation if I elect to move on to steps 3 and 4.
Tom
#112
on
Bmbulbe,
Tom
Tom
I found the HK system, while in fact good, Its just that I always found it that the volume would only go so high.
So planning and research is the key!!!
check sites like: crutchfield-good for headunits because it come with everything you need(mounting kit, harness, and antenna adapter)
woofersetc.com
onlinecarstereo.com
I purchased my HU from crutchfield and woofersetc i bought speakers, amp, rca's and wiring. Total I spent around $850, for a system that is louder and cleaner then the HK
#114
PA-MCS
I'll agree step one and two could be reversed on a base audio Generation 1. You can do the first step (speakers) with the HK unit then decide whether to upgrade head and amp.
From a practical standpoint, after spending the last 3 days going back and forth from Madison to Seattle with lots of time in airports to do little other than dig through the Crutchfield site, it was pretty obvious I was going to replace the head unit too.
So I violated my own recommendations and pulled the trigger on a head unit purchase today. I went with the JVC Arsenal KD-A725 plus their bluetooth adaptor and the steering wheel adapter box. I like the fact with an iPhone you can access pandora with that unit without popping for a HD radio. I can always add that piece later. I suspect with all said and done, I'll be in the same price range as you ($850) as my Crutchfield rep indicated he thought I'd also be adding a 4 channel amp before it is over.
In comparing to factory costs, keep in mind that at least a setup like mine not only is a substitute for the cost of the HK upgrade, it also replaces the cost of the iPod bluetooth adapter. On a new MINI we're talking close to $1,000. Both of us will be comfortably under that with a far better system.
I'm going to start a thread and do a step by step on my install. I know there are other threads out there but they are in bits and pieces. I want to go through prioritizing and how that led to the equipment decision. Then I'll go step by step through the install.
Tom
Tom
#115
on
Thanks Scavenger. I love the HU it does everything. my only complaint is the screen is sometimes hard to read. not sure if its because of the the orange text color or the sun reflecting off the screen.
#116
#117
on
I have one from a 2005. Not sure of any changes from 2003 to 2005, maybe someone else can answer that question. Im pretty sure they are not cheap from the dealership. Not sure what used ones go for....throw me a offer!!
#118
Sharing a couple of notes
Hi All!
Just replaced the stock HU in my wife's 05 Cooper S convertible (no H/K, no nav) with a Kenwood Excelon KDC-X695 HU. I had the Metra harness, so I took note of the info from this thread and just clipped the ignition wire from the Mini harness and wired the Kenwood ignition and the Axxess SWC ignition to that. No issues at all and no fumbling with the fuse block.
With regards to the Axxess SWC, use the wiring pinouts for the 2005 BMW 325xi - simply use the white/red/yellow polka dot line on the Mini harness and connect to the Axxess pink line. Wire to the radio according to their instructions and it should synch up properly.
I got the Kenwood for the IPod/IPhone access and Bluetooth. The Bluetooth microphone sits between the two dials on the steering wheel and the wiring is in the lower front dash cover. It did take be about 4 hours as I was being careful with the wires. Wouldn't it be nice if all interface connections were one standard type - USB or something similar?
Great thread, though. I read through all of it before starting my upgrade.
Regards, Jim
Regards, Jim
#120
My wife has an 03 Mini Cooper S, and the amp has gone bad. Is it possible/recommended to do any of the following: 1) rewire the speakers directly from the HU, bypassing the amp, or 2) add new HU (with USB/Bluetooth, etc.) and rewire to the speakers, bypassing the amp, or 3) add new HU and new speakers, and live with that until we decide if we want to add and amp. If new HU is added, will the steering wheel controls still work?
Any help anyone can offer is greatly appreciated. We want to get tunes back the easiest/least expensive way so we can sell it and get a Countryman (we have a 2 year old, and the Mini is just, well...too mini).
#121
#122
Thanks. It is the HK system...pain in the ****. Anybody know the model # for the amp? I've seen a few different model numbers thrown around.
#124
#125
I realize this is two months old, but in case you are still looking into this or for the benefit of others:
No, not possible. The 1st gen HK system has a 2 ch fixed low-voltage output from the headunit, and volume level/balance/fade/etc info is sent over the CAN bus. If you tried to run directly from the HU, you'd only have two speakers (out of 6), they'd be extremely quiet, and you'd have no volume control.
Yes, this is possible. The rewiring is a quite a bit of work, and you need to deal with crossover location/mounting OR go with plain coax speakers in the fronts.
Yes, this is possible, but again you'd need to deal with the wiring. Your steering wheel controls will not work unless you add an adapter (PAC and Metra make them, among others).
Unfortunately there is no easy way to piecemeal upgrade/replace the HK system (or any of the MINI upgraded systems for that matter). It's pretty much replace all of it, or none of it.
Any help anyone can offer is greatly appreciated. We want to get tunes back the easiest/least expensive way...
