Navigation & Audio Show Your iPod Installation
#101
#102
#104
I've just installed the HK Drive + Play unit, directly wired into the HK head aux input and it works great. I've mounted the display on the black roof panel overhead to reduce dash clutter. My issue is where to mount the HK head unit. At present I'll probably do the PCV pipe and try to figure out how to angle it toward the front, but the tiny change space beneath the brake handle could be another option if a bracket could be constructed to mount the HK head unit to the side of the brake handle. Anyone have a clean install on this?
#105
Originally Posted by Mastersonics
Has anyone though about installing a Macmini instead
I'm looking into this very seriously since
I could have all the functionality of Mac and play DVD's etc...
I know it's not for everyone plus is more $$$
but I've seen some incredible installations
just wanted to know what you guys think about this
regards,
Charles
regards,
Charles
#106
#107
Some really nice installations here. This was one of the first mods I made to my MINI when I got it. I wanted the iPod beside the tach, so I made an aluminum bracket for the Dension connector and attached it to the back of the tach.
It works great, and the orange illumination on the iPods buttons match the MINI instruments perfectly at night.
#109
Originally Posted by paulr
Nice ipod bracket!
It required a subtle bend to fit snugly against the back of the tach. I also spent some quality time polishing it to simulate the chrome finish on the back of the iPod.
#111
My Griffin Tuneflex came in the mail today.
Very nice. Holds the nano very securely. The output plug is located at the base so there's no hassle with the aux cable running up the unit. I ran the engine, revved it up a bit and thankfully there is no feedback noise. I noticed that once it's docked, you can't control the volume via click wheel like you do if it's just connected by the aux plug. You control the volume via the headunit or the steering wheel (if equipped). At the base there's a two position switch for the output volume.
#112
Good Job!
Good Job! Very sleek.
While at the Dragon, I was told that cravenspeed was coming out with a mount that sounded very similar to this one.
#113
#115
#116
My iPod mount is a homemade job, from wood, a Proclip mount, some paint, and velcro. I planed the wood so that there would be a slight angle to the mount, to improve the visibility of the iPod. Not very high tech, but cheap to make. I have the iPod adapter from MINI (about 35 bucks) which I installed in about 5 minutes (once I figured out how to pull the knee bolster down!). I have a November 2005 build car with the H/K system and the head unit I have does not show ID3 tags. I had ordered the ICElink, and sent it back after I chickened out on the initial horror stories with it.
I'm glad I did - for a LOT less money, I have a great setup. I can still use the MFSW to adjust volume on the iPod, AND have full control over the iPod. Not seeing the ID3 tags on the HU is not a big deal to me - I can easily see what's playing on the iPod itself. Because it simply "sticks" to the mount, I can easily remove it with one hand while driving (while it's still hooked up and playing!) if I want to adjust anything on the iPod. I charge it with the Belkin adaptor (I recently installed a second cig lighter/12 volt jack to use for my Garmin Nuvi).
And, with the velcro, it's a total of one second to remove the iPod! When I leave the car, I simply hide it out of sight or take it with me. No big deal. I like that I still have my big cupholder as well as the smaller ones available for parking meter change, etc.
The other nice thing about this mount is that it is very adaptable. I recently got a Nano - so when I am ready to use that, all I have to do is to put a strip of non-fuzzy side Velcro on the back of it and I am set to use it in the Mini!
#117
iPod install "on the cheap"
Without a MFSW I couldn't see spending too much on getting my iPod into the MINI. so after viewing all the great installs posted, I thought I'd represent the cheapos in the house:
Your standard "install"! (lousy shot, I know)
The best part about this "install", is that I didn't have to unscrew or drill a hole in anything. When I sold the MINI I was able to take it all with me- minus the AUX Input itself.
Future plans... A car charger splitter w/ room for 4-5 devices (in anticipation of additional GPS, Radar, and cellphone)
(This set also available w/ more details on Flikr: http://www.flickr.com/photos/66289509@N00/180276587/ )
- Yes- I paid the dealer to install my Aux Input... (I was a noob and didn't know better!)... ($120 w/ labor, if I rem. correctly)
- (Blue) Car Charger Splitter... (powers neon "footlights" too! neeto!) (~$2 off the clearance rack!)
- (White) Beklin iPod Charger (~$20)
- (Green) 5-foot 1/8" cable from Radio Shack, neatly tucked. (~$3)
- All routed through the "factory" hole in the glove box.
- Running 1/8" stereo cable and iPod Charger from the behind the glovebox, behind/under the whatchamacallit cover
- Note the neon "footlight" (yes there's a matching one on the driver's side...)
- Belkin Hard Shell Case (~$20)
- With the long cable, I can set my iPod in the cupholder, grab it Pod when needed, or even let rear seat passengers control it.
- And they say the cupholder is usesless!
#119
I keep reading this is an FM transmitted signal and can't be hard-wired in. Can it be hardwired???? If so, I'm going to get one!
~PJ
~PJ
Originally Posted by Ministi2005
Sure. So here's the thing -- I'm either older than most of you guys or at least more blind. So, being able to see what I was doing without killing myself was key.
Navigation using the HK is very simple. It is just as if you were navigating directly on the IPOD, with the difference being that I can actually see it while I drive (and I can barely see anything without reading glasses anymore) thus making the roads safer for everyone.
In other words, I can keep looking directly ahead and still change my music. There are a number of options re: font size and scrolling and also brightness. The brightness doesn't bother me at night at all (I thought that it might). It is easily visible in almost all lighting scenarios (I thought it might look washed out in the sunlight, but it doesn't).
95% of my music source is IPOD driven so I rarely do FM radio or CDs anymore. Before having the DrivePlay interface I was limited to 99 songs on a playlist with the Mini HU interface (and in fact only to 5 playlists which had to be named in bizzare fashion). The HK has eliminated all those annoyances and given me access to my music again.
I have the navigation button under my handbrake - which works just fine. I can navigate without looking at it easily (since you're watching the screen ahead of you); however, it would have been nice to integrate it's nice blue light somewhere else - since it has a certain "cool" factor. Of course, to move it somewhere cool where it could be seen would mean it would be hard to reach.
In short, I like it. I have only one regret and that it is that I can see a little bit of the wire to the screen --- and I would prefer no cords at all. Eventually I will try to pick up the screen and see if I can manipulate the cord -- however, right now it's 3-M'd so nicely to the dash I hate to break the seal.
Hope that helps.
Hope that helps.
#120
#123
