Navigation & Audio HK Enabler? A bypass?
Just order it direct from NewMINIStuff in the UK: http://newministuff.com/hk-enabler-465-p.asp. Seriously, all you have to do is add it to your cart and checkout like any online purchase. NewMINIStuff is the only vendor making and selling the HK Enabler. A MINI enthusiast and engineer (Ian Cull) originally designed the circuit for his own use, then he collaborated with NewMINIStuff (aka MikeyTheMini) to create the production version: http://www.gbmini.net/wp/2004/06/min...roductionized/..
Or you can replace the HK amp with an aftermarket amp and reuse the existing wiring to the speakers. However, you'd also have the replace the HK speakers because of their nonstandard characteristics.
No one has questioned the $160 price tag when buying the Enabler/MFSW controller? That's half the cost of my HU!
MERP
i question the cost, but it may be the quickest option. The enabler looks to be a Motorola microprocessor chip circuit coded to control the HK amp unit. I'm also replacing the HU currently and need to decide whether to get this enabler or just wire up to the existing or new speakers.
I'd like to understand what signals & power the factory Mini HU is sending to the amp.
Details in Ian Cull's blog:
http://www.gbmini.net/wp/2003/08/hacking_the_mini_ibus/
http://www.gbmini.net/wp/2004/04/run...ory_head_unit/
The reason for the high price is that it is a low production specialty item. I would guess that total sales since 2004 is in the hundreds. The wiring harnesses for the kits are probably hand assembled in the vendor's shop.
Interior/Exterior So Where Do You Keep Your JCW Exhaust Bluetooth Remote? I Mounted Mine
camptown
07-29-2021 11:43 AM
Alpha Motoring
06-01-2016 07:16 PM
MTVic
R58 :: Coupé Talk (2012+)
20
04-14-2016 06:21 PM
PelicanParts.com
03-29-2016 02:48 PM
