Navigation & Audio Technical HK question
Can anybody tell me for sure if the midrange/tweeter combination in the HK system has a cap and coil crossover, as the Bentley Manual implies, or just the cap on the tweeter line that I found when taking it all apart.
Since the mid/tweet speaker line out of the HK amp is one line, it stands to reason that there is a passive crossover in line. I just can't find the coil, if it exists. Without the coil, are they letting the midrange just play as high as it wants? It can't be electronically crossed over in the amp, as there is just one line to the midrange /tweeter combo coming out of the amp.
Any help in locating that coil would be appreciated, thanks.
hmmm, it could be that theyre relying on the natural roll off from the speaker to act as a kind of crossover
in several of the home hifi speakers i have, the midrange is fed a full range signal, the woofer is fed full range, and the tweeter has a cap
the speakers have highe fficiency so dont use much power, with a low powered amp (which i understand the h/k to be) it will have low distortion and just kind roll off at the frequencies the speakers cant reproduce so they match the frequency response of the speakers to fit together
just a guess though
Im going to be trying out connecting all 3 to a small 12 watt amp and see what happens :p at some point...
just a guess though
