Navigation & Audio aftermarket speakers for my R53
There is no such thing as "can't" in the aftermarket world, rather a matter of how much are you willing to spend. Personally I don't know the situation with the mini but I do know that there are some cars that require reprogramming or special circuits etc. should you want aftermarket speakers/amp/subs due to the stereo being wired into the ecu(again, not all cars, only some). I personally haven't been down this route with a mini yet, but considering that people have put amps and such in the boot, I don't see why the other speakers can't be swapped out.
Finding a parted out mini that had a stock Harmon Kardon system might be your best bet, it bumps nicely and should fit the stock speaker spots.. but might require some dealership tinkering after the install of the whole system.
I got the Polk component front speakers from Crutchfield.
They supply the adapters for the front lower speakers,
and I had to adapt the tweeter location a little for a good fit,
and screw in the crossover, but it worked out well, and I could
easily do it myself. Also put some Dynamat in.
http://www.crutchfield.com/p_107DB65...01.html?tp=106
used HK system?
Thank JA Bowders, I'm encouraged to see it's pretty easy. I'll probably take mine to stereo dealer, but not to the one where the guy said I needed to replace my whole system.
Polk Audio speakers?
The Polks sound very good, and they're a smidge more efficient than the
stock drivers, so I'm happy with them without having to add an amp,
and they don't cost an arm and a leg. No programming required.
I did have to replace one of the 6.5 in drivers after several years. The
magnet shifted and pinched the voice coil after a couple years of the
Fonzie manuevre (banging on the door just above the speaker) to keep
the window motor working.
Navigation & Audio Impedance of Stock Under-Seat Speakers
jnrjr79
Navigation/Audio
18
09-18-2015 05:51 AM
