Navigation & Audio Mini Connected and iPhone 6
I appear to have the same issue. While launching Mini Connected app in iOS8 on iPhone 6, the app doesn't make it past the launch screen with the MINI logo.
I upgraded from an iPhone 4S, so I missed the forum discussions about connectivity issues with the lightning port. I'm reviewing these message boards to see if perhaps the problem is using the Apple 30pin to Lightning adapter that I assumed would work.
So I'm working through if this is a hardware connectivity issue with the use of the adapter, if this is a problem with the Mini Connected app and its compatibility with iOS8, or if this is an issue with new hardware on iPhone 6.
I followed through with the diagnostics within the app with the apple white lightning cable which yielded the same results with connectivity. The cable I used was the new y cable without the adapter. It has lightning one end and audio and USB in the other. It may appear we need to wait for an update on the app for it to work again. Maybe someone will find a work around.
I think my issue was cellular connectivity or connection to server gremlins. Once the app prompted for my username/password, everything worked as it always had before with the iPhone 4s.
Software versions:
Multimedia: MX-003.005.004
Telephone: TX-003.005.006
Music Adapter
6112 2287641-01
08.01.2014
The lightning cable from apple works with Mini Connected but the Y cable does not work with Mini Connected but can play music.
There seems to be different Y cables available through BMW/Mini. Not sure if they are specific to function.
61122287505 is listed as a media cable.
61122287642 is listed as a music cable.
Can't seem to find my cable part number. May need to call Mini Service this week to find out about the different part numbers.
Music Adapter
6112 2287641-01
08.01.2014
Asked my mini parts manager and found out:
61122287505 is listed as a media cable for use with models with navigation
61122287642 is listed as a music cable for use with models without navigation
After connecting the media cable, music plays, apps work but the plugin option does not recognize the iPhone 6. It does not detect it as a compatible device.
Do any of you notice the sound being really bad when connecting the iphone 6 via the Y cable? I just bought an R58 with mini connected. Bought the Y cable, if I connect via the Y cable the volume level coming out of the iphone sounds way too loud and it distorts bass / treble.
If I use bluetooth audio, the levels sound better, and don't distort. I've also tried turning bass / treble all the way down with the cable connected with no luck.
I went into the EQ, change it to flat, but that didn't really help either. So I left it alone.
I see it is probably one of a few different things
1) The cable is bad
2) Iphone 6 / ios8 changed the line level to be too loud, and mini connected overboosts the signal coming out of the iphone
3) The aux port is bad (or the mini connected itself dont' know)
Just wanted to see if anyone else had the issue.
1) The cable is bad
1) The cable is bad
1) The cable is bad
Also getting some distortion on my R56.
The cable is brand new.
Will try to fiddle on the iPhone's EQ to see if it gets any better.
Hmm I have to try that. Typically "high volume" is achieved by some sort of compression so that could in fact work.
07-16-2020 12:54 PM
12-23-2015 10:36 AM
tippin
08-05-2015 08:43 AM
