Navigation & Audio My R56 Reverse/Backup Camera Install How To
Old 10-22-2013, 07:20 PM
walk0080's Avatar
walk0080
walk0080 is offline
walk0080's Avatar
walk0080
walk0080 is offline
Walk-through of install
Old 10-23-2013, 10:10 AM
AZdsrt's Avatar
AZdsrt
AZdsrt is offline
Good write up, a moderator should consider making this a sticky..
Old 10-26-2013, 09:11 AM
walk0080's Avatar
walk0080
walk0080 is offline
Old 10-26-2013, 10:08 AM
MINI_42's Avatar
MINI_42
MINI_42 is offline
Excellent write up and very neat workmanship! Can you tell me where I would get the same camera? I would also like to add it to my car?
Thank you,
Mike
Old 10-26-2013, 10:47 AM
walk0080's Avatar
walk0080
walk0080 is offline
Old 06-20-2014, 10:20 AM
walk0080's Avatar
walk0080
walk0080 is offline
Old 10-31-2014, 06:55 AM
walk0080's Avatar
walk0080
walk0080 is offline
Old 11-01-2014, 11:49 AM
Paceman S's Avatar
Paceman S
Paceman S is offline
I am installing a backup camera on my 2014 Pacemen S. There are five wires leading to the rear tail lamp housing. I am trying to verify which wire goes to the backup bulb and also the ground wire. Any clarification would be appreciated.
Old 11-02-2014, 08:58 AM
walk0080's Avatar
walk0080
walk0080 is offline
Old 11-02-2014, 09:42 AM
Paceman S's Avatar
Paceman S
Thanks for sharing your experience.
Old 11-26-2014, 09:25 AM
Chrisjav's Avatar
Chrisjav
Chrisjav is offline
Good stuff! I will be doing the same soon...
Old 11-26-2014, 12:34 PM
Luv_My_JCW's Avatar
Luv_My_JCW
Luv_My_JCW is offline
Thanks for sharing. Great write up.
Old 01-10-2015, 06:52 AM
walk0080's Avatar
walk0080
walk0080 is offline
Old 10-26-2022, 04:02 PM
r56_driver's Avatar
r56_driver
r56_driver is offline
can anyone re-share these how to instructions? i bought a used 2010 R56 and would like to install a backup camera DIY. thank you!
Old 10-29-2022, 12:59 PM
giorgos's Avatar
giorgos
giorgos is offline
Text and link content (until 2014.11.26) can be found here:
https://web.archive.org/web/20141221...ll-how-to.html
The project involves installing a camera above the license plate and an additional, non-OEM display in the cabin.
I'd be curious to know why the content was removed by @walk0080.
Old 12-09-2022, 04:42 AM
amancuso's Avatar
amancuso
amancuso is offline
I'm installing a cam in conjunction with an ANDREAM Carplay module in my Mom's 2013 Cooper S Coupe. Everything is hooked up, however when the engine is running, the cam fails to work. I see the backup lines flicker for a few moments, then the screen goes blank. If the car is in accessory mode it works no problem. Any thoughts, ideas?
Old 02-20-2023, 11:09 AM
Screaming Skull's Avatar
Screaming Skull
Screaming Skull is offline
Originally Posted by walk0080
What happened to the how to?
Old 05-04-2023, 06:36 AM
amancuso's Avatar
amancuso
amancuso is offline
Good question, I can't find info on this anywhere...
Old 01-14-2024, 04:29 PM
andylatham99's Avatar
andylatham99
andylatham99 is offline
Copy of the instructions:
I started by running the camera cabling through the lift gate handle.
Modifying one of the handle clips with a rotary power tool:
Test fit (missing rubber seal).
The boot handle has four drainage holes (one for each screw) along the bottom of the handle. I simply enlarged on of the holes to allow the cable to escape.
The stock entry point for the boot button/lights are untouched so I don't have to worry about water leakage in that area.
View from other side (hatch panel removed) - I later added part of a rubber grommet to protect the cable from the steel body panel edge:
I ran the 4-wire cable (black - pos/neg/video) along the drivers side of the hatch window and then along the top to the rubber cable conduit:
Then ran an 8-wire cable (white - pos/neg/video - extra wires unused) under roof panel to passenger side boot storage area. I tapped into the backup lamp wire (blue/grey in my car) for the relay trigger and ran the wire (red) as well:
[It was around this point where the provided 4-wire camera cable became damaged and I had to re-run a new 8-wire cable (now white).]
[The extra coiled black/red wires are for a secondary boot light install for later.]
The camera cable then ran along the passenger side next to/under rear seat then behind the passenger side lower door panel:
[I then had to take a several day break here before continuing.]
Close-up of the passenger side fuse box area. Relay is bottom left, 12V power tap center right.
I used fuse # F34 (7.5A for heated seat control in my car). There was already a fuse tap installed for my FESAutoSport module so I used a POSI-TAP to add my circuit along with a 5A fuse.
The 8-wire cable then ran up from passenger side fuse box towards the passenger air vent:
And then behind passenger side air vent and along the top of glove box/behind the knee panel:
And then down the passenger center console:
Cable exits lower storage cubby - below A/C and window controls... there was already a small square hole next to the Aux-out/USB jacks:
I attached the 8-wire cable to the RCA and power jacks. The LCD panel is secured to the lower cubby rubber mat using double-sided outdoor high-strengh foam tape.
The LCD unit then just slides back in place. I later moved/hid those white/yellow wires that are visible in this pic.
I then re-attached all of the removed panels.
I also had to modify the license plate holder by drilling two new mounting holes. This is because of the thickness of the camera prevents access to the rear boot/hatch open button. I lowered it by about 1/2":
The camera license plate frame was attached using the stock MINI screws. The camera came with anti-theft bolts but they don't work with this install. I may purchase some new screws with star or some other less common head design to limit chance of theft. As-is it is difficult to notice it is a camera unit:
I broke and had to replace two yellow clips on the rear hatch panel - they are $3 each at my dealership. Cheaper elsewhere of course.
I will also be replacing the passenger side lower seat bolt - $10 at my dealership. Service manual indicates it must be replaced if ever removed (better safe than sorry...).
All cables/connectors were soldered except for where I used the POSI-TAPs.
Enjoy!
Project_Mini
How to
07-04-2020 07:34 AM
Duc OT
01-24-2019 03:00 AM
Lucas63
Navigation and Audio
02-19-2018 01:23 PM
TVPostSound
11-17-2017 12:06 PM
89AKurt
03-18-2012 03:16 PM
Quick Reply: Navigation & Audio My R56 Reverse/Backup Camera Install How To
