MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Navigation & Audio
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post My lifted mini is done!
by Moby911
40 Replies, 923 Views
Advertisement
Thread Tools Search this Thread
Old 10-17-2009, 12:45 PM
Wake|MCS's Avatar
Wake|MCS Wake|MCS is offline
Gallery
Front Speaker Replacement / Amp Question
#2: It's time to replace the front speakers as I have a blown tweeter and a blown mid (different doors). I was thinking about the Polk DB6561 as I've read good reviews and they can be had for about $115, anyone have any experience with these components? Any other suggestions?
I currently run a 500w 2-ch amp to power a 10" Kappa sub-woofer, I don't care for a lot of power to the sub as I'm over the heavy bass phase (when I put turn it up, it HITS). Could I do the following: power both front speakers off 1-ch (can run 125w continuous per channel at 4 ohms) and then power the sub off the other channel?
Please note, I'm on a very tight budget so keep that in mind.
Old 10-17-2009, 08:15 PM
Wake|MCS's Avatar
Gallery
Bueller... ? Bueller... ?
Old 10-18-2009, 10:19 AM
Supercoop55's Avatar
Supercoop55 Supercoop55 is offline
Gallery
Options
Running the left and right fronts off of one channel would be a bad idea. You would only be getting half of the musical info in a track, especially on broadcasts/recordings that have good stereo seperation of instruments and vocals. The way around that would be to combine your stereo output to a mono input. You would get all the info, but it would sound flat an awful. There is one possible way to do as you propose. It requires passive crossovers. You can run your amp bridged and stereo at the same time if you passively crossover your fronts above what you crossover your sub at. For example; you run your amp full range. On the speaker outputs you run a high pass crossover on the left and right channels at, say, 80hz. At the same time you wire a single 80hz low pass crossover to your bridged output (usually right negative and left possitive, check your manual). This effectively divides up what the amp is "seeing" at it's output in a way that does not conflict. It's an old school solution, but it works for a budget. Note, you will not be able to independantly control your sub volume without a attenuator after the amp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
