Navigation & Audio Factory Bluetooth option help
Just purchased a 2009 Mini Cooper with Bluetooth and USB/Ipod adapter. The Ipod integration works seamlessly but I cannot figure out how to setup Bluetooth. Online searches show that the first step is to press menu and select the phone option. However, I do not see an option for phone. Am I missing a step to activate this option?
This might help. Have the car running. Turn on the Radio, then tap the menu button..."phone" should be on the left side. Next, push the larger button, when "Phone" is encircled. This will take you to a menu to help with instructions on how to "pair" your phone. Every phone is different, ours had to have Bluetooth enabled before we were able to pair it.
Another hint, when the System asks for a "password" "passkey"??, use a simple # sequence (4-digit) works, and enter it into both your phone and the car by using the corresponding keys.
You should also have a fold-out in your Manual Binder that helps with setting up Bluetooth.
Good Luck!!
Good Luck!!
Just got back from the dealer. I've been told that the option "Bluetooth and USB/IPOD adapter" is not sufficient to activate bluetooth connectivity. They said that bluetooth will cost another $1700. I'm confused. Do I have bluetooth or not?
There are 3 bluetooth options from Mini:
1. Bluetooth and USB/IPOD adapter
2. Comfort Bluetooth with USB/IPOD adapter
3. Smartphone prep with comfort USB
Which of these options will allow me to use bluetooth with my phone?
IF you have the Bluetooth and USB/iPod option you have all that is required to make the bluetooth work.
Now with that said. To have the Bluetooth/USB/iPod option you need the ULF/USB module. To check to see if you have this module we need to do some visual check and some hardware checks. after answers to these questions we can help you further.
1. Do you have a USB port just below the windows (up/down) switches in the center stack?
2. With the radio on Press the "Audio" button you should see the following options: Tuner/CD/USB/AUX Do these show up?
If you have neither of the above then you have the iPod connection and not the bluetooth/USB/iPod connection.
I have a USB port in the center console below the window switches. The USB port is right next to a stereo jack. This works with the IPOD adapter.
Pressing "Audio", I get Tuner/CD/AUX. No USB. This is consistent with pressing "MENU" which does not show the "Phone" icon.
The factory sticker lists "Bluetooth and USB/Ipod Adapter" which is a $500 charge.
One other thing, my AM radio jumps 9Khz instead of 10Khz.
If bluetooth does not exist in the car then the two buttons (face, phone) on the MFSW are not used for anything. It is actually easier for the m to just have one standard set of buttons even if the functionality is not available in the car.
No charge except for my time and the hassle of bringing it back to the service department twice.
First time, the service advisor did not know what he was talking about. Claims that I do not have bluetooth included. Also added that I needed Nav for Bluetooth.
Second time was better. Even got a loaner.
07-16-2020 12:54 PM
penguinhomey
R60 :: Countryman Talk (2010-2015)
38
07-07-2019 09:24 PM
12-23-2015 10:36 AM
tippin
08-05-2015 08:43 AM
