MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Navigation & Audio
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post MINI's on TV!!!
133 Replies, 4,428 Views
Advertisement
Thread Tools Search this Thread
  #26
Old 03-13-2009, 09:28 AM
COOP310 COOP310 is offline
Gallery
Quote:
Originally Posted by IrishCooper View Post
yeah after reviewing this DIY again i would really like more pictures of the adapter plate and how it fits, i have the wiring part down but i would like to see the other side of the finished dock if possible. I have a universal dock i was going to mount there and just plug the cable into the back of the dock but i dont know if that will work. I think from what i read you just "glued" for lack of a better word. The cable to the apple dock so that its actually plugging directly into the cable just through the dock. Help me out here understanding it.
The adapter plate merely sits between the plastic cupholder and the cupholder trim. There is no trick to it, it just sits there, and fills the space where the rubber piece used to be. As long as you use the right thickness of plastic, It will be held in place by the upper trim piece.
I don't have any photos with the electronics attached to the dock, because that dock has was sold after I totalled my R53. You just epoxy the connector to the bottom (you may have to zip-tie the clips on the side as well).
Here are a couple of photos of the dock without the electronics. The one on the right is for the R53. It is the original dock in the first post that was made from an actual ipod dock instead of just the dock plate. The one on the left is one that I was working on for my R56, but it does not utilize a DICE-like device, it is simply a dock (I don't have the ipod control in the new car). I have included the photo In case anyone wanted to go that route with an R53.
  #27
Old 03-13-2009, 12:34 PM
IrishCooper's Avatar
IrishCooper IrishCooper is offline
Send a message via AIM to IrishCooper
Gallery
ok that helps out alot. I want to try and use a universal dock so that i wont be limited to just 1 ipod as i have several and others i know have ones so if they want to listen in my car they can. I see on the on on the left it looks to have a dock already installed in it. Can you tell me more about that? Did you build that or mold it or something it looks very professional.
Mykl Milligan
Hyper Blue Owners Club #1 MMC #432
'06 MCS Hyper Blue/White :( SOLD
'05 MCS JCW DS/W <-- Dad's Car (Currently for Sale!)
Currently driving an '04 Jetta but looking for a PW MC, PST me if you know of one!
  #28
Old 03-13-2009, 06:52 PM
Gallery
Putting the universal dock in the cupholder may yield a few problems. First and foremost, the dock electronics may not actually fit while allowing a dock cable to be connected. Second, the iPod dock is not a passthrough for all of the pins on the connector, so if you are using a DICE or the MINI solution, it may not work at all (it didn't when I tried it).
The dock on the left is too big for the first gen MINI. It is one that I was experimenting with for my R56. It is simply the inside of my iPhone dock epoxied to some ABS and then attached to the underside. It is worthwhile to note that I did actually break a component from the circuit board when I took the iphone dock apart due to the way that apple puts them together, had it not been for a friendly electronics engineer at work, It would have cost me another $30 to try again. The R56 cupholder is quite a bit bigger than the R53, so the dock itself does actually fit, but it doesn't look like I can fit the cable in there too without cutting a rather large hole in the cupholder.
Both were both built using the same method in the first post. I highly recommend using the plastruct bondene instead of glue, as it does not leave a gap between the two pieces, It kind of melts the two plastics together From there it is just a good deal of sanding and a little painting to make it look good.
  #29
Old 03-14-2009, 11:52 AM
Gallery
yeah i have taken both apart and the universal dock was easier to take apart than the iphone dock. Funny thing you should mention it not working for my current car (04 VW jetta) i bought a ipod adapter just like the Dice from a company called Blitzsafe works the same way and if its plugged directly in works fine, through the iphone dock it only charges it doesnt play, and through the universal dock everything work just like when its plugged directly in. So i have tested it and only the universal works apparently.
Mykl Milligan
  #30
Old 10-20-2009, 02:08 PM
Supercoop55's Avatar
Supercoop55 Supercoop55 is offline
Gallery
Nice work
  #31
Old 02-02-2010, 11:55 PM
Mello_Yellow's Avatar
Mello_Yellow Mello_Yellow is offline
Gallery
Hmm, I'm interested in the cup transmitter from Amazon. However, it seems from several reviews that the sound quality is bad if you have a lot of radio stations around you. I drive a lot between Columbus and Dayton and am wondering if I'd have to constantly be changing the radio station to find a clear channel or not.
On a scale of 1-5 (5 best), how would you rate it, Dawger101?
2002 MCS - 15% Craven Pulley - Alta V2 CAI - One Ball Exhaust - M7 Strut Tower Brace and Plates - M7 Under Strut System - Out Motoring Tow Hook - Aesthetic Creations Black Out Kit - Replacement Grille - OEM Rear Bumper Black Vinyl
  #32
Old 05-05-2010, 10:39 AM
Sportspack Mark's Avatar
Sportspack Mark Sportspack Mark is offline
Gallery
Looks great, so there is no way this will work for the r56? :(
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
