Remove the four torx bolts, prop the seat up with a roll of paper towels, remove the four small phillips screws, underneath that is the Antenna lead(Pink). VERY EASY!!
__________________ DyeLooper
Alta CAI, Functional Hood Scoop, 4" Helix Antenna, Infinity Speakers, H & R Springs, Alta Rear Controls Arms, 17" Konig Unknowns w/Goodyear F-1's
To remove the seat:T40 torx bit and ratchet
To remove plastic cover: Phillips screwdriver
I was actually able to reach the cable by just taking off the cover. I didn't remove the seat. It's just 2 screws between the seat tracks in front of the seat and 2 screws between the tracks at the rear.
__________________ Otto Moe Beall
2007 MCS 6spd manual: CR/B,Sunroof,Sport Package,Black stripes,LSD,Rear Fogs,Carbon Black Lounge Leather,Rooster Red Colorline,Chromeline Interior,Piano Black,Hi Fi Upgrade,Anthracite Headliner,Black Koenig Feathers,H&R springs, ALTA 19mm sway bar,Whalen black Delrin Shift Machine, red Mach 5 LED lights
Appears that you do not have Sirius pre-wiring, there should be a plastic cover under the passenger seat. This is where the antenna lead is, as well as connectors for the OEM Sirius module.
