Navigation & Audio Aux Input installed! (pics)
#201
Here is the original Aux-in/Nav install as posted by Greatbear. Pics are even still there!
https://www.northamericanmotoring.co...lled-pics.html
#202
That's a great DIY, MINI still sends the MINI factory instructions for the glove box location in the kit ( 82110153367 ), but can easily be plugged into the back and the mounting plate can be put under the toggle bank. I really like the creatively of the additional locations people have put them in this thread.
Aux Input Cable Retrofit Kit Part # 82110153367
http://www.ecstuning.com/Search/SiteSearch/82110153367/
#203
First question is will this aux input work with my current system?
I have considered installing a new head unit with an adapter to utilize the factory steering wheel controls but my understanding is the speakers are not compatible so new wire must be run from the new unit to the HK speakers?
Just trying to explore all options and pick the best for my situation.
Thanks in advance!
#204
There's a how to for the aux install on this forum. As for bluetooth I bought a bluetooth dongle that plugs into the aux. It's awesome, works and it's only $18.99...
#205
Yep, it will work.
DIY install, there is also instructions that come with the kit. Aux Input Cable Retrofit Kit Part # 82110153367 linked above. Then you can plug a male aux cable into your MP3 or Ipod,/ iphone. MINI does not have bluetooth streaming for music for these older models.
#206
Yep, it will work.
I have been looking and there are some neat kits for bluetooth streaming and even phone calls.
One issue is it will be done through the aux jack. So if the head unit is in radio mode or cd mode no phone calls. The head unit has to be in aux mode for these kits to work. Does anybody know of a way to install one of these kits that would still interrupt radio and cd functions? I have seen a bluetooth kit that installs throughout the antenna but it is only for streaming music not phone calls. Just trying to explore all options.
#207
Thank you Greatbear (and NAM) for showing me the way for this mod!
I recently bought a 2006 MCS with NAVI and if it wasn't for your excellent instructions, I'm not too sure that I would have attempted the install myself, especially dealing with switching the 3 wires.
BTW, I took a page out of your book and also installed the AUX port on the same side of the parcel shelf (I was lucky, the car came with it already).
#208
rolla , you are welcome.
harleyheaven - way to install one of these kits that would still interrupt radio and cd functions?
If you have your iphone( headphone port ) plugged into the aux port for music and then there is a call , it will go through the speakers and act like a integrated hands free phone. That's an option how to use it. Of course you have to hit answer on the phone.
thanks
thanks
#209
thanks
thanks
Also, assuming this works. What serves as the mic for the phone? Wouldn't the phone have to at least be in speakerphone mode?
#210
Nope, this is just a work around when you are in Aux mode and have you phone connected to the aux jack using a male connection cable . Like this. You mic is the one on your phone. You are using your phone , listening to a song,... then someone calls you, mutes the sounds and then you are using the phone.
http://www.ecstuning.com/Search/SiteSearch/61122153330/ES2080503/
thanks
thanks
#211
thanks
thanks
http://www.newministuff.com/new/shop...uctshow&id=116
#212
Part Two - The Snag
Well, upon examination it didn't appear to be a lost cause. This is the Nav connector (yellow wires) removed from the head unit and the Aux connector plug. The Nav system wiring occupies different cavities in the connector than the Aux input. In that case, I can transfer the wires from the Nav into the Aux connector.
The outer shell of the the Nav and Aux connector have to be removed first. The release tab is under my thumbnail.
This is the Aux and Nav connectors opened up. You can see where the wiring positions are different.
I used a small jeweler's screwdriver to release the terminal from the shell. Press down only enough to release the wire, then pull the wire out.
This is what it the freed wire and terminal looks like.
The terminal is pressed into the corresponding cavity in the Aux connector shell.
The same is done for the second wire from the Nav connector. This is what results.
The outer shell is snapped back onto the completed connector.
Now to get back on track....
#214
#215
Pictures really help, Greatbear did a great write-up, two most popular locations have to be : under the toggle bank or in the glovebox. Seen the through the blank toggle switch also.
#216
#217
#218
I have a question for everyone who has ever installed or done this aux "mod" to there mini .. just recently I have ben using my ipod with the aux cable and mode and it has recently just been cutting out, I tried several different cords checked the connection etc but always after about 5-10 min itll cut out and not be present on the mode display until sometime when it "cools off" HELP???? Anyone know how to fix this???
#219
Did you check all the connections on the back of the stereo ?
Also does this happen when you are on CD or just standard stereo radio stations. If so you might have an amp problem if you have the H/K system .
#220
Nope the only time it cuts out is when I have AUX on, I have seen other people having a simular issue with NON H/K systems on here but I have a H/K system and CD and radio work great with no issues??
#222
I am not charging it through the car usb or anything I am using the cigarette litghter usb charger that I installed on my own. Would that be a problem? And thanks ill search tonight for that..
#223
#225
