Navigation & Audio Installing Speakers + Amp and Warranty Concerns
I just talked to my dealership about this and they mentioned that the modification to the car could be considered an electrical change and that I might be at risk for voiding a warranty if I were to have a stereo installed (or installed it myself).
I'd be installing Polk SR5250 5 1/4" in a component configuration and an Amplifier.
Has anyone ever had trouble with their warranty because they installed speakers?
I didn't think that there would be any required cutting of wires to install the amp.
I'm probably going to install it myself. After reading some posts about it, the tutorials here and some other reading I've done online, it doesn't seem all that bad to replace the front speakers.
Why would you need to cut any wires though?
I think the biggest thing is putting a mounting screw through a wiring harness or other expensive component. Also, if you take power from the wrong place (say a fuel pump fuse--don't laugh, I have seen it), or tap into the CAN bus wires you can do some major damage.
Be careful about putting the 5 1/4" speakers in the doors. You'll need adapters. The openings are bigger than the 5 1/4" Polks I just tried to install. I finally changed my mind and am going to get a 6.5" speaker. The diameter of the opening is about 5.5".
I've seen it happen.
Replacing the front speakers is easy. Adding an amp is not for the unskilled. The sticky has all the info you'd need though. several speaker wires would need to be cut.
What about adding an amp and subwoofer to the system? My receiver has already been replaced with an Kenwood MP3 player, and I was thinking of adding a JL Audio Stealthbox and amp to the back end. Just wondering if there are the same type of issues with electrical. Wiring should be very easy since my R53 has a rear mounted battery.
What's a CAN bus wire?
What the dealer told the original poster is just plain false. The Magnusson-Moss Warrant Act of 1975 makes it illegal for any manufacturer or dealer to void a warranty due to any aftermarket part or modification unless they can prove that the part or mod caused the issue resulting in the warranty claim. Even then, they can only deny coverage for problems resulting specifically from the the aftermarket part or mod - all other claims are still valid.
Now, if you have someone who doesn't know what they are doing install an amplifier and they damage something, you are out of luck warranty-wise for anything that they damaged. So be careful - only install quality parts from reliable suppliers, and only hire reputable firms to work on your vehicle.
If a dealer ever gives you undeserved trouble regarding a warranty, ask to speak to the service manager and refer them to the Magnusson-Moss Warranty act. If that fails, contact the FTC and your state's attorney general (most states have similar laws).
I
while true, good luck fighting the dealer. It's much easier said in a forum than done in real life.
Also - if someone does actually cut a wrong wire somewhere - you could potentially have to replace the wiring harness in the car - at an expense of several thousand dollars out of pocket. So yep, only let a reputable installer work on your system! If you do the work yourself, avoid cutting any wires.
Absolutely agree. I just finished my upgrade (for now) using BMW/MINI parts to create my own loom (thanks TomFarin) to cleanly connect at the x9331 connector. The only wires that were cut were the factory speaker wires right at the speaker terminal in the doors. I doubt very highly that the dealer could pin me for causing any warranty violations.
squawSkiBum
10-02-2015 09:21 AM
