[FONT=Arial]New Products From Zaino![/FONT]
[FONT=Arial] [/FONT]
[FONT=Arial]Shipment Enroute[/FONT]
[SIZE=3]
[FONT=Verdana]RELAX - QUIT WORKING TOO HARD & WASTING TIME! [/FONT][FONT=Verdana][/FONT][/SIZE]
[SIZE=3]
[FONT=Verdana]JUST APPLY & LET DRY![/FONT][FONT=Verdana][/FONT][/SIZE]
[SIZE=3]
[FONT=Verdana]Zaino Z-CS Clear Seal[/FONT][FONT=Verdana] is finally here after years in development. From conception to realization, the principal and design emphasis of
Zaino Z-CS Clear Seal was quite fundamental - an advanced total synthetic polymer protectant that is simply wiped on, and that's it! Yes, achieve Zaino award winning gloss and protective durability in ONE simple wipe on step. Wipe on, and walk away, you're done. No buffing. No final wipe down. Simplicity at it's best. Just apply & let dry.[/FONT][/SIZE]
[FONT=Verdana][SIZE=3]Zaino is pioneering the industry with Z-CS, a self curing transparent sealer that doesn't require any buffing or final wiping. Z-CS dries clean and without residue. Use Z-CS on paint, glass, wheels, plastic, or trim for the protection, durability, slickness, and gloss that Zaino is most popular for.[/SIZE][/FONT]
[FONT=Verdana][SIZE=3]For up to 9 months protection, use Z-CS to top coat Zaino Show Car Polish protectants, or use Z-CS
by itself. You can even use Z-CS as a top coat to add high-gloss and improved durability to
ANY other manufacturer's product. Z-CS extends the gloss and durability of any previously applied products. Z-CS should never be applied over uncured waxes.[/SIZE][/FONT]
[FONT=Verdana][SIZE=3]You'll have to forgive our enthusiasm for the release of Z-CS. We are VERY proud to have accomplished the height of product simplicity with a no compromise approach to cutting edge development and industry leading gloss and durability. There simply is not another product like Z-CS in the industry.[/SIZE][/FONT]
[FONT=Verdana][SIZE=3]Less than 1/4 ounce of Z-CS will complete an average sized vehicle.[/SIZE][/FONT]
[FONT=Verdana][SIZE=3]VOC
free.[/SIZE][/FONT]
[FONT=Verdana][SIZE=3]The Z-CS bottle contains 6 fl. ozs.[/SIZE][/FONT]
[FONT=Verdana][SIZE=3]Price:
$29.95[/SIZE][/FONT]
[SIZE=3]
[FONT=Verdana]ONE STEP CLEANER, POLISH & PROTECTANT[/FONT][FONT=Verdana][/FONT][/SIZE]
[SIZE=3]
[FONT=Verdana]Zaino Z-AIO ALL-IN-ONE[/FONT][FONT=Verdana] is here. [/FONT][/SIZE]
[FONT=Verdana][SIZE=3]• Excellent daily driver solution[/FONT][/SIZE]
[SIZE=3][FONT=Verdana]• Easy to apply & remove[/FONT][/SIZE]
[SIZE=3][FONT=Verdana]• Apply by hand or machine[/FONT][/SIZE]
[SIZE=3][FONT=Verdana]• Safe for all paint types[/FONT][/SIZE]
[SIZE=3][FONT=Verdana]• Restores dull paint & minor oxidation[/FONT][/SIZE]
[SIZE=3][FONT=Verdana]• Safely smoothes minor flaws & cleans embedded debris[/FONT][/SIZE]
[SIZE=3][FONT=Verdana]• Leaves a glossy & strong protective layer[/FONT][/SIZE]
[SIZE=3][FONT=Verdana]• Excellent base coat setup for optional Z-2 PRO or Z-5 PRO application[/FONT][/SIZE]
[SIZE=3][FONT=Verdana]• Does not contain any oils or fillers[/SIZE][/FONT]
[FONT=Verdana][SIZE=3]Zaino is proud to build on the success of it's line of award winning Zaino Show Car Polish Products with
Zaino Z-AIO ALL-IN-ONE. Z-AIO simplifies the task of painted surface maintenance. Z-AIO's versatility on all paint types make it your one source, goto polish. Whether on your car, truck, motorcycle, or boat, Z-AIO can be your true SINGLE polish & protectant product.[/SIZE][/FONT]
[FONT=Verdana][SIZE=3]With an emulsifying cleaner and very mild abrasive, Z-AIO gently cleans and protects while effectively enhancing light refraction and reflectivity for remarkable results. The advanced polymeric substructures within Z-AIO produces optically perfect layers to all paint types, yet also provides excellent adhesion and detergent resistance, resulting in a strong and glossy layer of polymer based synthetic protection.[/SIZE][/FONT]
[FONT=Verdana][SIZE=3]Z-AIO is an excellent solution for daily driven vehicles. Exposure to environmental elements as well as surface contaminants affect the look and life of your paint. Contaminants like tree sap, tar, bird droppings, bug remains, road grime, and many other pollutants can be easily removed with Z-AIO.[/SIZE][/FONT]
[FONT=Verdana][SIZE=3]Z-AIO can either be used by itself, or as an excellent foundation & bonding agent for the full line of advanced Zaino Show Car Polish Products.[/SIZE][/FONT]
[FONT=Verdana][SIZE=3]Although it is not required, you may follow up Z-AIO with application of any Zaino Show Car Polish protectant, including our new advanced [/SIZE]
[SIZE=3]Z-CS Clear Seal[/SIZE][SIZE=3], or [/SIZE]
[SIZE=3]Z-2 PRO[/SIZE][SIZE=3] or [/SIZE]
[SIZE=3]Z-5 PRO[/SIZE][SIZE=3] products.[/SIZE][/FONT]
[FONT=Verdana][SIZE=3]The Z-AIO bottle contains 16 fl. ozs.[/SIZE][/FONT]
$26.95[/SIZE][/FONT]
Okay....so I don't know what's going on with my post. Anyone tell me how to clean up this mess?
TIA
Steve
Carolina Shine
704.759.0142
cashine@juno.com
