- Best place for part Penske www.penskeparts.com
- thought I had a dead alternator
- Clunk from hell
- Quiet HK volume
- Engin Fan keeps running after the car is turned off
- 05 MCS:: Clutch pedal sticking
- Mini fell off the MINI
- temp guage diping down below normal.
- Radiator Fan Test
- Why is it every time I change my oil...?
- Ticking Noise, Gets faster with higher RPM, what could it be?
- It's not you it's me
- So my first batch of problems has arrived
- thermostat housing/computer removal - reprogram?
- More Brake Problems...
- Rear Taillights Out
- Replacing ECU Unit with Used one
- Is this too much to pay for PS pump & fan
- just had ac worked on now the heat doesn't work :(
- Rear roof glass shattered!
- California emissions warranty coverage
- Broken exhaust above cat on '05 S.
- Many different Codes popping up...
- Throwing code that doesn't match symptoms?
- Mini leacking oil
- Clutch Blow-out?
- engine fuse box bolt help!!!
- Xenon headlights causing trouble! Help!
- Air conditioner and radiator fan issues
- help with crankshaft pulley please?
- Strut tower accident
- 2003 Mini Cooper S Brake Pads?
- Gear makes noise while driving
- HELP!! Water Pump
- Driving light
- 40k maintenance?
- No smoke after using Seafoam
- Testing the camshaft and crankshaft position sensors
- Replacement Aero Front Bumper Grille Anyone?
- Broken seat - who replaced it
- Bad clutch or master cylinder?
- '03 R50 - "whirring" noise under hood after car is shut off - HELP!
- Power Steering cooling fan issue
- 2005 Service Manual PDF Download Available?
- Clutch died in my MCS this morning :(
- CD Changer Problem
- Chronic Clutch Slave Problem
- Maintenance Advice?
- '03 MCS: Oil Blow-back on air filter
- At what mileage did you have your first problem?
- Freeing a stuck axle?
- R50 A/C & Odo display Problems
- traction control going crazy, help please
- Do I have a bad clutch or transmission?
- CV Boot Torn
- How to close air filter cover?
- Weird random issues with my MCS
- Check Engine Light - Exhaust?
- Weird noise
- brake job! HELP
- Alternator might be dead.
- Armrest replacement
- Code P1689 and low power
- Hard to start and CEL code -P0302
- hello,new (used) to minis
- Forum noob requesting input/help
- Where to buy a connecting rod?
- HELP, 2nd cracked and melted ignition coil
- HID Headlamp Assy Replacement
- Headliner (?) cloth loose
- Popping Out of Gear
- Xenon Fail
- Should I replace spark plugs? Whaddya think?
- Stubborn Bulb!
- Side trims falling off
- Non-catastrophic tensioner failure.
- Need some Rad Fan replacement direction
- Fuel gauge broken
- Tapping after Seafoam
- Belt Replacement HELP!!!
- 2005 Cooper S
- I lost a piece of my bumper...
- Power window parts?
- Shifter Cable Broke.....I Think. Please advise
- 5 speed Gearbox
- Wheel size, MPG, and computers
- Lesson Learned..the hard way
- Cooper S fuel mileage concerns
- Wheel bounce around corners
- Fan, STDs and brakes - shade tree notes
- Need help, timing issue.
- Airbag Light!!!!
- Need advice on engine swap asap!
- R53 Belt Tensioner Question
- Clicking from axle/driveshaft on drivers side
- New squeek today triggers limp home mode
- door lock + automatic unlock (2 pulls on handle)
- 2005 MCS Auto Transmission Surge or Yo-Yo
- The 2003 to 2006 Mini Cooper "S" is a Neat Car BUT!!
- clicking sound from the front
- Oxygen O2 Sensor prob. that won't go away.
- Serpentine Belt issue
- Looking for help with a window problem in Norther VA
- Headlights always on when driving
- Wiper Fluid Leaking...
- 2003 cooling fan problem
- Air Conditioning Recharge DIY?
- My AC blows heat every once in awhile.
- Did my engine mount just died?
- Horn Relay
- sluggish acceleration R53 - help
- Stage 1 Fan?
- Bad Crank Pulley? I Need a Second Opinion
- Missing rear rotor/hub retaining bolts, & holes don't line up.
- AC blows hot and compressor is not turning
- Engine Damper/Dealer Quote/DIY?
- SES Light, Inspection, and 75,000 Miles
- Glove Copartment
- 2006 MCS JCW shuts off while driving..
- sc removal
- 1st gear....extremely sluggish uphill low end RPM's
- Drivetrain vibration in rain
- Koni FSD / strut mount
- Coolant temperature pegged-out at max
- Rear Wiper
- Help my 05 Mini is still overheating
- Broken Window Switch??? :(
- code p1125 and p0638 no start
- 2005 Cooper - Horn stopped working
- HELP!!!mcs wierd noise from unde hood
- Bad fuel sensor...
- Battery cable squib resistance
- EML and Check engine light 06 MCS
- Help, trying to figure out what is going on
- $40 for a spark plug??
- Installing New Starter
- Coolant problem
- Please Help! I keep blowing fuse w/iphone?
- PCV Valve questions
- replacement filter
- Help with MCS overheating at idle
- Clutch issue
- Windsheild washer has stopped spraying.
- bad cat or exhaust leak?
- What have you paid for these repairs?
- tire failure light flashing!?!?!
- rear tag light-what size are our bulbs?
- Heavy steering
- Subframe removal, in conjuction with control arm Bushings
- Power Steering Fan question
- Blower Motor Woes
- Glove Box Lock Cylinder removal?
- Intake Air Temperature (IAT) high or normal / Post Your IAT's
- Two problems in my engine bay. Help?
- Rad Fan part information
- Standard oil for r53
- ??? Powerflex front control arm bushings ??
- Unable to start after fuel filter change
- New owner with a question.
- Exhaust system explanation requested
- 2003 cvt
- Cooling system issue
- Strange Squeaking from front end
- Hissing Vacuum Line
- Help!!
- idle wub-wub-wub 02 mcs
- Morning hesitation
- Dunlop DSST weather cracking dry rot
- '04 MCS tail light problems
- Do I have mushrooming? (Pics)
- List of Changes to Computer at Dealer
- R53 Starter Motor replacement proceedure
- Help! stumpped fixing my fan and a/c
- 03 MCS Manual Transmission? Noise
- SuperCharger bad
- Battery Troubles - 1K miles
- Boot Trouble
- Regarding these NGK Spark Plugs
- buy a code reader? or trust the dealer?
- What air filter suit for R50, 2006 Mini Cooper AT?
- Keyless Actuator FCZ Windows Convenience fail
- R53 2006 Tcs, Abs And Tire Pressure Lights On
- Chassis and engine question R53 MCS
- Broken fog light lens
- replace water pump???
- 2003 Mini Cooper S, Catalytic Converter failed in California
- Alternator help, if you please.
- ambiance lighting?
- Won't Start ! Battery is Good, Any help ?!?!
- Need help diagnosing overheating
- Metal Shavings and Chirping
- New 03 MCS owner in Arizona
- Cooling fan troubles
- On dash...What is this? Pic
- Would like to confirm my harmonic balancer is dead
- Water leak onto my left foot
- Water in Battery Box
- Car Slow to Start, lights on dash
- Valve Cover Gasket replacement question
- Odd Gremlin...
- A/C Broke (again)
- what fuse is this?
- Installed new belt still squealing. Help please.
- Why me? Valve cover nut disintigration
- TMAP/MAP sensors
- new power steering pump fan not working!
- License Plate platic light cover
- Master Keys - Are we really at Mini's mercy?
- Supercharger blown
- TMAP/MAP sensor location
- Engine Codes/CEL driveability issues
- Catastrophic Engine Failure at 72,000 miles
- HELP - I'm New to Mini - P0172 code
- help?
- God awful noise HELP!!!
- hesitation when it comes to acceleration
- just bought my 1st Mini! I have q's and concerns;(, hoping for advice
- 2002 MINI Cooper - Need Battery Part Help
- Engine Block
- Car won't start
- Red sticker behing air box
- how to clean throttle body
- Oil Change Problem and Questions
- Help! Crazy electrical problem
- P0500 and P1613
- Oil leak
- White smoke from exhuast?
- ?no a/c, no p/s fan, no lo speed cooling fan.
- oil pressure 2006 S
- Water pump replacement?
- Need to vent
- Annoying rattle
- New o2 sensors and still throwing a code.
- Couple questions to fix some minor things
- Supercharger rattles
- H/K stereo concern
- odd ac issues
- Streering Rack Removal
- "Mushrooming of shock towers" /NHTSA
- A/C decided hot air is better, any help?
- Leak in Convertible
- A/C cool not cold
- MCS erratic Idle and rough acceleration
- Tweeter Replacement
- Please Help!!!
- Weird KLUNK sound
- AC Question: Adding Freon to my Cooper.
- HPFP Failure Article
- Checking fuses and something's missing HELP!!!
- Reverse sensors on Convertable
