- Window motor relays or ????
- Strange pass. side "tick" noise
- control arm bushings
- P2270 before and after header change and sim install
- Passenger side driving lights out
- Power steering wire
- Brake pad wear sensor light issue (Search was used, need advice)
- Funny chattering noise
- Does the ABS fuse control anything else?
- used seafoam now I have issues
- Fuel Pump Question........
- no key lock for glovebox?
- Yay or Nay!
- Floor Mats
- Rear washer not working
- Where Is The Neutral Safety Switch???
- HELP! Cooper S hard to shift
- Please Help...'05 Mini S Convertible...
- Air conditioner / temperature gauge
- 2004 MCS Boot Release with dead battery ?
- Need new rear calipers R53
- Header/Midpipe Break
- Steering shake on acceleration
- No start...
- How would you proceed? Oil Change Fail!
- Duralast Alternator Thread
- Engine cooling fan fuse (FL9) keeps blowing!
- Mini Convertible: Top won't go all the way down
- Compression Test Results
- Rear Hatch Hinge Broke......
- A/C blown hot air momentarily
- Radiator/Cooling Fan replacement suggestions and sources
- license plate bulb
- Christmas tree dash lights
- One last p/s fan question
- I'm having a tough time getting the air out of my cooling system
- Engine whine getting louder and now there's a whistle..
- Supercharger Oil Service - increased sc lifespan?
- 14.0 - 14.4 On board diagnostic codes
- Bleeding Coolant lines Help
- Strange Electrical \ Computer Issue
- Shaking under acceleration
- Clutch Slave Cylinder
- Strange Rear Suspension Noise
- Air in coolant system
- Oil Leak?
- Replace PS Pump while my subframe is down?
- Wiring has melted! Help!
- coolant cap temporary solution?
- 02 MCS Shifter Loose Feeling
- OEM ignition/starter kill in 05 MCS?
- Manual transmission does not "center" in neutral
- Strange engine noise/rattling... with video
- same engines different noise...
- Serpentine Belt?
- Car wont start EML light on PLEASE HELP!!
- Fuel issues
- Closed hood uneven?!
- can I change my own R50 auto trans fluid?
- need help changing the tail light bulb
- Help! 2008 MCS Cabrio at dealer for 2 weeks!
- AC Repair, or lack thereof -- Recourse?
- sunroof switch issue
- Window off track, falls down into door!
- Wipers too slow
- r50 mini cooper traction control problems
- A/C Fan stays on with A/C off.
- Fan Stays on after you take the key out
- Windshield wiper "Jitter/Lift" at 100+ MPH
- Steering problems
- R53 drive shafts - HELP
- Droopy Headlight
- Need help, oil change gone wrong!?!
- Weird Sound-Help
- Input Clutch Cylinder Problems?
- squeeky sound on full lock
- tail gate noise
- Sun Visor mirror door
- Oil Pressure Light
- Everlast (Walmart) 47-3 battery
- What is this noise?!
- Help replacing thermostat!
- New Mini Owner - Couple of issues
- Clicking sensation/noise caused when turning the steering wheel
- B200 Scan Tool
- Frozen Tire Rod. Yes or No?
- Stuck in gear???
- Mini S 2003 Transmission issue
- wipers dont work
- SES light with coolant temp code.
- Rear license plate screws stuck
- Bowden Cable
- Stock '03 MCS - intake howling/whistle under load not idle.
- Stretched Bowden Cable
- Not another supercharger thread!
- Brake noise, opinions??
- MINI does not start! Recent window problems
- foggy windshield + antifreeze on floor
- Feds investigating 1st gen power steering complaints
- Clutch help needed please.
- Clutch Disengagement noise
- Back up sensors not working
- Must Read About time Power steering pump failure !!!
- ABS Module Failure
- Transmission failure on 2006 Cooper S automatic - any other ideas?
- Oil on spark plug
- A Tale of Mini Maintenance and Repairs
- 04 MCS Power Steering pop the sieve
- Help how to tell the difference PS fan or Pump
- Engine fun :)
- dead battery how to open trunk ?
- Metal shavings in oil, oh god, now what?
- Strut problems?
- Dropped the vent screw!
- Vaccum leak
- RPM running high at 50-65mph
- R53 Overheating
- Front Wheel Hub Rotors
- Sun Visor Problem
- need help tried to search
- Finally! Hesitation and rough cold start fixed!
- scheduled maintaince
- Oil Sender Socket Size
- The Next 70,000 Miles: Help me figure it out...
- Anyone have the Bentley repair manual?
- Mini will not start
- Driver side Turn signal Issue - With Pics
- BBA - Remanufactured PS Pump Failure
- 05 MCS fuel cutting out???
- Mini Won't Start!!!!!
- Leaky sunroof to body cut-out seal.
- ABS and "tire" lights turning on and off, intermittently
- How to enable factory alarm "beep"
- Yet another won't start issue
- How necessary would you say the power steering pump fan is?
- Brake Pad Advice
- Head gasket help
- Wheel bearing Hex Nut Size ??
- a/c compressor clutch
- stripped spark plug cylinder head
- Need help identifying a part...
- i found these parts and don't know where they belong
- Help Please
- Silly Question concerning service mode
- AC Compressor clutch assembly
- Constant Growling Noise When Running
- 2005 sport electrical problem
- P/S pump fan protector-does it really work?
- 2006 S Automatic transmission harsh downshift
- a/c cooling fan
- a/c cooling fan
- First day member! P/S Issues
- '03 Cooper Transmission Failure
- Ringing from Engine (Hello? Hello?!)
- Help guys...2months of trying but r53 wont start up
- Automatic window roll up
- SES light and Check Gas Cap lights on!
- Coolant leak...again
- hydraulic motor mount bad again less than a year will dealer cover this??
- questions on installing the top right clamp (exhaust)
- Cooling fan replaced. New problem arose.
- 02 Idle issues and a/c problem NEWBIE needs help
- Dealer suggest repairs totaling.... drum roll...
- 2003 Mini Replace Reverse bulb
- NEWB Intro Thread....Tranny Questions (not that kind)
- Fuel Filter replacement and related cold and/or hard starts
- Outer Tie Rod replacement
- Competition Edition warranty on fan and horns
- Rear Trailing Arm Maintenance?
- Super Charger Maintenance??
- Help me please asap!! Supercharger gasket
- Power steering fluid overflow?
- Not so clean shifts
- Electrical issues
- 05 Mini S, Stalls on approach to stop.
- stock #1 piston and rod
- fan question
- smart guys needed
- Electrical Problem...??
- Extra key made?
- Simple question about leads
- Mini Badge
- Problems with Aftermarket Oil filters -- Pics -- MUST SEE
- Air Conditioning Problems
- Oil drain valve?
- Keyless locking problem - Clarification.
- Need help with S/C Intake desperately!!
- Oil Leak
- My car rolled back while in gear help!!!
- Mini runs rough below a half a tank of gas.
- supercharger oil
- burn smell at high RPM
- Looking to replace struts and wheel hub assembly...feedback welcome
- R53 Battery is STUCK, anyone else have this problem?
- ABS & Flat Tire Light Both ON
- Fixing Vaccum leak
- tranny leak?
- passenger door lock stopped working
- 2003 MC with 70k km transmision problem.
- Gas Gauge Shows Empty - Tank is Full
- 2002 Mini Cooper (Auto) Fan Issue
- Lost Lash Adjuster
- headlight/tail light issue
- 04 MCS .. new sound from motor. sounds like power steering ?! but maybe supercharger?
- Blown engine
- Sunroof Won't Open and Blowing Fuse
- Brake Pad Indicator Light
- Strut replacement ?
- p0240 - do i need to replace cat or just oxygen sensor?
- Help 2 warning lights are on
- Car doesn't idle...After fast idle and subsequent valve cover gasket replacement
- How to change temp display from celsius to Fahrenheit
- OEM steering rack or aftermarket?
- Help! Cooper S engine wiring harness
- p113c code
- O2 SENSOR AND p0107 CODE
- Non Functional TPS
- Battery Draw
- Seafoam video 90K miles
- Car Died at Stop Light
- flat tire light
- "Random Misfire"?
- Emergency Brake Light Remains Lit
- ABS Failure
- Instrument Lighting Issue
- Door Lock Actuator repair on the MCS R53
- Beeping tones when I turn the engine off??
- Thank You All..Newbie
- Radiator fan & Temp Gauge questions
- Whats causing this??? (coolant boiling out)
- looking for clutch advice...
- Supercharger service bulletin?
- 04 MINI window malfunction
- Infamous intermittent power steering issue
- Mini stalled in flooded wash
- why.. 18mpg 02 justacooper
- TPS PN ?? or Vendor
- Steering wheel shake
- Negative Terminal Sparking
- power steering fan fuse
- 2003 Mini S PS fan
- 2002 Cooper S Fan underneath engine.
- supercharger? done? and ac problems?
- 06 Cooper air filter replacement
- Seatbelt Removal/replacement
- Very Low Boost PSI HELP!!!
- Car Lighter Problems. Fuse?
- Warped Rotor or worse?!?!
- Best place for part Penske www.penskeparts.com
