- Rear Hatch
- MCS Crank Pulley Damper
- cvtneverland again
- Starter wires - forgot how they go on
- Weird cold start-up noise (R53)?
- backup sensor problems
- 05 Cooper S Second Water Pump Leaking in less then 40K
- Rear Parking Light Bulb Replacement
- Weird Noise?
- Independent Repair Shops in Fairfield County, CT?
- Airbag light on
- cvtneverland
- Coolant leak and warranty/cpo warranty.
- Headlight looks foggy. Will replace, but from where?
- Manual Transmission, won't go into first gear, HELP!
- Any ideas where this stuff is coming from?
- Oil filter will not come off
- Spedometer oddity
- Electrical Gremlins......
- Power Steering Pump Wiring Routing
- Airbag Light?
- LogJam Ipod Interface Mini Cooper 06
- Weird sound and stuttering?
- So this is what I found on an 02 with 13x,xxx miles.
- Overheating/Coolant/Idle/Fan Issue
- need tech help
- Where is my windshield washer fluid going???
- Cruise control
- Re-greasing the shifter/box
- Mass-Airflow-Sensor cannot be cleaned?!
- tachometer problem
- 2nd oil pan gasket in 6 months
- Replacing Inner Tie Rod / Tie rod assembly, Any Tips & DIY?
- Any look with aftermarket ball joints?
- Broken Wheel Lug
- engine wouldnt shut off
- MINI shuts down after start up...?
- Some light function and changing questions
- dead battery
- VW Extending Warranty on 6 Speed Auto Transmission
- Powerloss and EML light
- Sunroof and windows opening by themselves
- blown head gasket any other possibilities.
- Coolant Leak - Back, Right of Engine
- Tranny trouble /swap
- Another Option for a Repair Manual
- Cold Start/Run Problems
- OEM driving lights
- 395 for an injector?
- Battery Dead?
- Slave cylinder fails 3 months after clutch replaced-coincidence?
- HELP! DSC faulty? Multiple dash lights on
- Very loud "POP" while driving
- $4000 in repairs already?! Help!
- Fan and wiring harness fried
- Fluid Leak
- Aero bumper repair in MA
- Frozen Brake Lines?
- MCSA - Aisin 6 Speed AUTOMATIC, failed at 80K?
- Engine misfire in cylinder 2!!!
- oil pressure
- Sticking throttle in freezing temps upon starting?
- R53 Water in the Battery Box And Side Cubby Clarification
- key batt replacement
- Thermostat dissapointment..
- 04 CVT lurching at low speeds
- MCS Auto Trans. Fluid Check/Fill (Aisin 6 Speed auto)
- Both of my doors wont open! :(
- Wippers not work =(
- Fuel filler door lock frozen
- 04' Mini R50 intermittent idle problems
- Seat Heater Problems ?
- Mysterious Leak!
- Window Not Rolling Down Far Enough When Opening Door...
- engine noise/rattle
- R53 Headlight problem~ Pls help!!!
- Coolant pump ?
- control arm bushings
- Weird Clicking noise in seatbelt
- whats wrong? weird revs and throttle
- Car Underperforming - Could you or SGII help?
- High-RPM hesitation
- Coolant Temperature
- HELP! Tessie wont start
- Thermostat replacement
- Installation help
- Weird Starting Issue
- can't fill gas, venting problem?
- Buy a new dipstick...now!
- Misfire in 3 and 4, no longer running
- Strange noise... : /
- Resonator/cat rattling?
- Need Help! How to replace my High Beam DRL?
- Heater core plugged??
- Where to buy stock style wipers?
- Fault codes!! P1692 & P1229
- window switch question
- Wheel bearing Change Bearing wont come off axel shaft
- Doesn't turn over after clutch replacement
- oil leak
- replaced rad fan, still no low speed
- Water temp problems! Oh no!
- 2004 non S
- Pillar A molding source
- Seeking vendor for OE GE E1 Halogen headlamp bulbs
- R53 turn signal goes rapid fire.
- axle seal.... welded on!?
- R53 Crank Pully vs. R50 CP
- Cooloing system help
- What is this noise... SC or tensioner maybe?
- no starting after sitting for a while
- Weird supercharger noise!
- Daytime Running Lights
- Passenger Door Won't Open From Inside
- Door Lock Not Releaseing
- Half Shaft install, drivers side
- Does anyone know what part this is?
- Odb-ii P0130 & P0138
- Ebrake is loose (tuning?)
- Aaahhhh Need Help!!!
- rattle rattle
- right windshield sprayer not spraying?
- Potentially hazardous electrical problem...
- Broken Windscreen
- Tach and Temp needle flicker
- MINI fuel problem
- Steering clunk (no confirming articles)
- RPM triggered shudder?
- Funny Starting Problem!
- replacing radiator
- Temperature in tach is broken
- Left signal, High beam problem
- 04 MCS engine whine
- No-pressure Coolant leak Symptom
- 05 S R53 72k miles, oil pressure light on
- Engine wont start
- Need to replace 2004 R50 Transmission
- Low speed shimmy in steering wheel - Help!
- Certain electronic accessories stopped working...
- Replacing brake lights?
- brake lights
- Stuck outside my Mini on Thanksgiving :(
- Getrag 5 spd noise - Options?
- coolant expansion tank
- SES and ASC lights on
- My 2002 JCW wont start
- Parking Sensors Not Working
- My MINI gave me gas
- Here it goes...need some help.
- Where does this go? Werid airline
- Rear Wheel Noise, Breaks?
- @&#^$% Clutch
- Cruise Control Control Circuit/Open
- SES Light - EVAP problem
- My sons car has a 1 amp draw when car is off Driving me nuts!
- What can cause excessive oil consumption?
- Question on airbag control unit/module???
- After axels were replaced.
- Where Is The Coolant Going
- Help Need New front Bumper
- Exhaust Hanger question
- 06 MCS won't hold 4th gear
- Safety belt light and airbag light?
- New Owner-2006 Automatic/Steptronic Trans Question/Issue
- Module gone bad?
- CVT failure imminent?
- Hydraulic clutch issues, Any options known of?
- Change filter without draining oil?
- No heat. No a/c. No cooling fan.
- Hosed by MINI
- Any one bought a cvt from here?
- Parking light out on driver side, and the bulb is good :(
- TPMS light will not extingush
- Lost POWER on the freeway!
- Radiator AND fan?
- Are all R50 Automatic transmissions CVTs?
- '06 trans shot?
- Exhaust Resonance
- Rear End Collision Followed by Electrical Fire
- 06 Works coolant leak
- WArm/Hot Start Issue...
- windows automatically roll down help!!!
- TPMS Warning Light
- A-Pillar Moulding decided to remove itself.
- Scared!!
- Best band-aid solution for weak motor mounts?
- Power steering fan
- Airbag Sign Denied Warranty Due to Spill
- 2005 Mini Cooper (Steptronic) Not shifting, Please Help!
- Mini Mechanics in Wakefield, MA area
- Help with airbag light
- engine tick right side
- Replacement Jack
- R53 Water Pump Replacement
- re-surfacing a head
- Car Runs Rough When Cold After a Spark Plug and Serpentine Belt Change
- Problems Galor: 2005 Mini Cooper Convertible 1.6 manual
- What does it mean?
- Not a cracked head!!!
- Lifter noise after head installation w/ video ???
- Does this bolt on the exhaust pipe have a head for a socket?
- Help with Wheel Bearing Nut
- Oil leak '05 r53
- Rattling clutch and highway noise
- easiest way to change reverse bulb on MCS?
- Windshield washer / wiper movement
- Door pulls???
- srs light question
- 06 CVT - High engine rev
- Oil Filter Housing leak?
- Headlight failure help!
- Help with Auto Tranny question??
- Help Funky Boost!!!!
- Please help identify this leak.
- Oil leak when car parked facing downhill
- Yay my window works again! But my door lock broke.
- Shaking taking off on first
- Funky heating
- When to Replace Rear Struts?
- What indicator light is this?
- High idle
- Burned Clutch, or bad master/slave?
- 161000 mile supercharger gears.....WOW
- Clutch Release Bearing Unirex S2
- Help needed with possible short in 05 s
- how do I get stuff activated at the dealer?
- Error code p0700
- Weird "chuggy feeling" when shifted from D to R
- Oil Light on
- Transmission Fluid Change at 114K?
- Uh oh... something is making a mess underneath
- p1688 code on 02 r53
- Where is the oil filter?
- cherry red exhaust manifold
- Rattling in engine around alternator area
- Clips for power steering fan
- How do I fix a sheared muffler hanger bolt?
- Engine Mount(s) OEM vs. Aftermarket, also where to buy?
- identify this piece of trim....
- Radiator Fan Working Overtime!
- Ok another PS thread but Namer's need your help
- Dash turn low beam/high indicators not working
- 03 Cooper Help!
- Valvetrain clatter, rod knock or something else?
- Climate controll issue
- Intermittent Clicking Noise from Driver's side
- My 06 MINI is sick :( Need good MINI mechanic in Northern VA
- dsc turns back on
- Worst oil change EVER
- Oil leak from oil cooler gaskets.
