View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Drivetrain "lag"
  2. Door wont unlock/open from inside? It -might- be as simple as this.
  3. New to the Mini realm, not welcomed!
  4. no crank/cut the belt, now it cranks
  5. automatic transmission trouble engaging
  6. Engine won't turn over
  7. Oil Leak! Please help
  8. wiper motor
  9. HELP! - MFSW Left hand radio buttons not working???
  10. Car jerks / bucks when letting off or pressing gas pedal around 3K RPM
  11. tear in intake tube
  12. navigation system
  13. water leaks and radio problems
  14. 04 MCS Odd Electrical and Ignition Issues
  15. issue with aux imput
  16. Cammed Idle?
  17. HK Stereo Dead... Help.
  18. Power folding mirror problem
  19. Power steering (oil) filter?
  20. Clutch or supercharger belt?
  21. A/C Compressor Not Engaging 05' MCS
  22. Power steering pump keeps pumping even after the car is shutoff.
  23. Replace a parking sensor advice MCS.
  24. Power steering pump hoses
  25. Excessive Oil Leak
  26. Oil Pressure
  27. servicing the SC rear water pump plug. PLEASE HELP!!!
  28. Battery finally kicked the bucket
  29. 05 mcs wont start, batteries fine, has new alt and starter
  30. 08 mini cooper airbag sensor question
  31. 2006 MINI Cooper S, 34k miles, blown head gasket
  32. 100k maintenance on SC and everything else. Need advice!!! Please
  33. Inner and Outer Ball Joint Replacement
  34. Coolant Temp, how to find/check with Nav
  35. "MINI" Label on motor is peeling, how to replace?
  36. Starter & Clutch Problemo
  37. Key Fob won't program.
  38. Bogging down & plug question
  39. On-Board Computer Going Nuts
  40. New Owner W/ Lighting problems...
  41. Is this right? New Rotors? 40k
  42. Slave cylinder leaking
  43. Replacement battery suggestions
  44. Transmission Question
  45. SES and ASC lights on
  46. Power Steering fan fuse
  47. 04 cooper just shut off no electronics HELP
  48. My cupholder swings like a monkey in a tree
  49. Speedometer not working correctly
  50. Seat won't move when tilted forwards
  51. Navigation Problem
  52. Strange idle...? Need help...
  53. remote works but key won't start '04 Cooper S
  54. stock rear camber problem...
  55. Engine Replacement? Humble advice request
  56. New owner clutch problem advice needed..
  57. Large coolant leak front of engine
  58. newbie with a troubled '06
  59. Service Engine
  60. This sound is driving me insane!
  61. 2006 mcs door hinges sound terrible
  62. MINI 06 wont start after shut down because didn't hit the clutch on time.
  63. head gasket blown!!!
  64. Reset Service indicator
  65. Need a wheel bearing/hub
  66. Steering Wheel Falling Apart
  67. Oil in Intercooler
  68. high gear, low RPM, backfire?
  69. P0301 with no power sent to injector 1
  70. coolant is leaking from exhaust!!!
  71. A/C help...
  72. Car interior really hot with AUTO climate control
  73. Serpentine belt wear prematurely/strangely
  74. Coolant Expansion Tank Leak Fix
  75. need heater core help
  76. Afrer Market xeonon
  77. Coolant Leaking!!!
  78. timing chain or hydraulic lifter
  79. Can't reach Fuel sender plug
  80. Glove compartment stuck
  81. Replaced brakes, Now soft pedal
  82. Help!!!!
  83. Passenger seat stuck
  84. Bad gas? Engine stutter + check engine light + dsc light
  85. UGH! Exhaust Went Kaplooie!!
  86. Transmission surging(?)
  87. Car will crank but not start after hitting curb
  88. Need help diagnosing clutch issue?
  89. Start, stall, repeat with lights
  90. drove through flooded road and stalled
  91. Mini Transmissions/Gearboxes (UK to USA)
  92. Stock antennae replacement
  93. Stock muffler replacement
  94. DSC Light stays on
  95. Air Filter
  96. Drive belt
  97. Mini Cooper S Temperature Gauge Flashing
  98. Airbag Light?
  99. Symptoms of bad CVT transmission?
  100. Radiator Fan Help
  101. I want all of your opinions!
  102. HELP PLEASE! What am I?
  103. No spark-no start.
  104. Knock Sensor Service Engine Soon Code - Some Questions
  105. Help!!!!!! 2004 R50 In Need!
  106. Purchasing thermostat gasket only?
  107. Supercharger Replacement
  108. mysterious clear oily fluid leak
  109. Strange (electrical?) issue
  110. Proper way to check operations of fan
  111. Cooling fan in cold weather
  112. Temporary rough Idle upon stopping. :c(
  113. Intermittent Power Failure
  114. What Does this mean?
  115. Oil in coolant - thinking it's the oil cooler, opinions?
  116. Finding Top Dead Center (TDC)
  117. Blown/leaking Head gasket. @ 54K miles?
  118. Engine/Tranny chatter?
  119. Play in shifter
  120. What fuse= cigarette lighters?
  121. A/C issue
  122. Good Midlands rebuild kit (so far)
  123. loss of power rough idle
  124. Problem with vibrating accelerator pedal in R50
  125. Engine oil fill cap is faulty!!!!!
  126. Help diagnose dead AC
  127. Drivers side door mirror is too wiggly
  128. Increased Battery Discharge notice four times in two weeks
  129. Transmission explosion !
  130. Messy leak under there *with photo*
  131. Strange supercharger noise
  132. Ignition Coil replacement ?
  133. My heater blows out cold A/C.
  134. so help? random fan issue then overheating...
  135. Noisy first gear and reverse
  136. Strange noise / clicking sound?
  137. Moaning/Groaning sound Help!
  138. 03 MCS will not turn on! Urgent.
  139. Other reasons than low pressure for Oil Light on?
  140. How to not get ripped off at dealer for service
  141. 02 MCS Stalling when fuel is low
  142. transmission problems on 2006 mcs automatic?
  143. P0130 - at 20,000 miles?
  144. I have problem !!! plz help me!!
  145. power steering pump
  146. Battery being drained while parked.
  147. SC rebuild kits
  148. All of the seat adjustments don't work
  149. Battery post under hood won't start car
  150. Starter Problem? Clicking after key removed
  151. Revs, revs and some more revs
  152. Valve Cover Gasket Replacement. Please Help!
  153. reservoir cap missing
  154. Dealer unable to program convience features.
  155. Flat tire light will NOT go out
  156. Electrical Problems
  157. 2004 mcs axle nut won't come off.
  158. Gas tank whistle while I pump gas.
  159. Weird noise from my car. Ideas?
  160. Another mini won't start thread...
  161. Help Please. My Shifter is Sloppy.
  162. No Power Steering this morning 05 MCS
  163. Brake Pad Indicator Light
  164. Central locking
  165. Very very simple question
  166. clutch...
  167. cam timing chain
  168. Coolant leak after long drive the next morning.
  169. Help heater/ac fan replacement
  170. Tire light reset button stuck??
  171. No low beams, but hi-beams work
  172. Gauge lights stuck on
  173. New owner, DSC/tpms lights
  174. yellow muck in oil
  175. Oil filter price
  176. Power Steering Fan duct replacement
  177. Leaking fluid
  178. Possible driveshaft CV joint problem after re-installation
  179. Engine Misfire
  180. Tie rod end without hex bolt?
  181. SES Light
  182. Flat Tire.... caused by a leak in my 17" 2 piece wheel
  183. knock sensor replacement
  184. 2005 Cooper 5sp, replaced shift cables, shifter is still stiff going to 1st or 2nd
  185. Clutch slave cylinder bleed nut is plastic
  186. Any cold starting issues with your R50 1st gen Mini?
  187. P2096 code, help
  188. Dash "squeak" might be a bad speaker in the door!
  189. High RPM, EML, SES light (permanently on), limp mode
  190. New tie rod assembly, DSC light now on?
  191. Transmission issues 2006 MCS automatic
  192. Leaking rear hatch
  193. Windows down when I went to get it in.
  194. Horn won't work - '05 MCS Conv
  195. Is this normal, throttle response.
  196. SES light: p2270, p2270, p0136 codes
  197. Car will turn over, but just wont "POP"
  198. P113C code...
  199. Heater blows out top of dash instead of vents
  200. Chirping Noise?
  201. Mini Hard to start when cold
  202. Arm Rest Removal
  203. Dead Horns
  204. Odd noise...
  205. Latest software version and how to check installed version
  206. fixed air bags / shop ran car outofgas,now won't start!
  207. Windshield wipers are on when car is off
  208. Ebrake adjustment?
  209. Airbag light issue, Extended Warranty that covers it
  210. Antifreeze smoke coming throughf my vents.. Help
  211. Another radiator fan question
  212. windshield panels?
  213. Clock stopped working.....
  214. Dust cap MCS 2002 rear caliper
  215. climate control
  216. '04 bogged, now new motor??!! Help!!!
  217. Body Control Module replacement questions
  218. Potential new Mini owner!!
  219. How to repair the thermometer
  220. Diagnostic Trouble Code 672800 - Unexpected High Idle
  221. O-rings for AC compressor and condenser?
  222. Airbag Diagnostic Questions
  223. 2005 R53 Rear wiper washer part?
  224. Oil change DIY...can't get bolt off
  225. R50 500hp. Transmission Swap questions?
  226. Driver Side Window will not close
  227. Broken thingy.
  228. New Owner w/Cold Start Squeal/Squeak
  229. Electrical Issues....
  230. New - Love my Mini, hate the SES light!
  231. funny od strange noise after clutch replacement?
  232. Frozen shifter
  233. Gas and Temp gauges are rattling at start up
  234. starter removal advice
  235. Muffler rust
  236. tachometer problem
  237. Seats for 02 S
  238. 2005 Mini, major cooling issues!
  239. MINI hates Seafoam
  240. 2006 Mini Cooper Base Fluid Leak
  241. Sensors bad?
  242. Condensation in fog light.
  243. Clutch going bad?
  244. P2096 code
  245. Rhythmic squeaking in the back when cold
  246. R53 Clutch and other issues
  247. Oil Filter Housing Removal & Replacement DIY step by step instructions?
  248. Rich smelling intercooler
  249. New to the site, could use some help.
  250. Rear Hatch
