- I can't believe I'm living a nightmare
- Odd sound at start up...
- Cracked exhaust manifold
- Need input on window tinting.
- Another a/c thread
- Electrical ;Speedometer needle shakes
- Been searching but can't find any help, big issue!!!!!
- 56k Miles and Looking at Thermostat #4.....HELP!
- Right Drive Axle Issues, Q's need A's...
- Brake Master Cylinder Replacement
- New clutch mounted but won't engage
- Bumper/Fog lights not turning on?
- Wind Noise from wipers?
- Help! My key doesn't unlock driver's door....
- Fuel gauge not working
- Engine noise... I'm thinking bad
- Airbag light
- 2003 mini cooper s head gasket
- Check engine / EML Light!!
- Guage problems
- Help need a new key!
- R50 Fuel pump Problems
- 2003 mini cooper s head gasket issue
- Cylinder Misfire Prevention??
- Stuck bolt help
- Exhaust Leak - Help, please!
- 2007 conv...Won't start
- Fan running....sometimes
- FAN stays on/overheating!!!
- Noisey LSD getting worst..
- NEWS: Investigation Upgraded to 60,000 Mini Coopers for Power-Steering Loss
- detonation with different gas... :-(
- Sill losing coolant
- Drops of radiator fluid
- dreadful experience uphill - stall, e-brake, 3rd gear start
- Knock sensor
- Loud Fan/Humming Noise After Engine's Off
- LHD and RHD Headlights ... different?
- Roaring road noise
- Rubber Grommet under MSD pack
- hard start, time for a tune up?
- Rebuilt Transmission
- Another clutch ?
- Windshield trim: "Purely cosmetic" or "Pure BS"? Need your input!
- So I know, all you ever see is steering problems...
- Steering Rack replacement
- What is this indicator light means?
- Radiator fan question.
- Broken Glove Box
- how to get more mpg?
- Toggle switch problem!
- Does this look right?
- Help leak diagnosis pump or ??
- Coolant Service @ Dealer - legal questions
- windows wont go up from the outside
- will not idle after warmed up. stalls
- What should I fix first? On a budget :(
- Throttle Lag?
- Annoying wiper, wiper fluid question
- 2005 R53 Rattle dissapears when I depress clutch
- Stuck removing bypass valve
- What does this connect to?
- Did I screw up my fuel system?
- Another Start problem...but I don't get it
- How to replace radiator hoses?
- Rear Seat Broke
- Steering Wheel Lock Mecanism
- Bad Battery??
- Ad me to the list
- Engine oil cooler: conflicting info
- WHO has replaced their Super Charger? What Rebuilder did you use?
- Did we get a lemon?
- belt squeak at idle?
- Head Gasket or Worse-gases in coolant
- Bentley Service Manual
- Engine Sound?
- Diagnostic tool ?
- Starting problem. Bad starter?
- Gas Pedal - gone bad or not bad? I dunno!
- P1688 code, how to check bypass valve?
- Seatbelt Tensioner Question
- Check engine soon light came on after putting in Borla exhaust
- New Steering Noise
- How much to replace an alternator...!?!?
- '06 R53 Clutch System Questions
- Clutch replacement/repair under Extended maintenance warranty
- Can someone help me determine what problem this is
- a/c inoperative - need advice
- Door Alignment - Help ! Advice needed badly !
- Low beam HID lights not working
- Clutch Pedal, Master & Slave Questions
- Have to wait 20 secs before turn key!!!
- How to check voltage going to coil pack?
- 05 Cooper S no start
- R53 Boost Leak? Intake Leak?
- Tensioner Stop Cable Breaking?
- CEL after fuel filter install (P0455)
- "Steering Rack" issues
- more mushrooms
- Glove Box Will Not Open
- FINALLY a Mini dealer in Chicago!
- steering wheel lock mecanism
- The R from COOPER fell off....
- Lots of play in steering wheel
- Please help..Supercharger problem 03
- PLEASE HELP! Something died in my car a few weeks ago and I can't take it anymore.
- R50 drive line whine
- o2 sensors
- Engine light code P1481 and P1484
- Sun Roof Problem Please Help =(!
- AnyOne Need An Experienced Certified MINI tech for there MINI?
- Intake manifold nut/washer substitute
- Car doesn't start and clicks when I turn the key
- poor gas mileage 21mpg
- Possible electircal issue?
- Lost half gallon of coolant in 5 blocks?
- Strut mount rubber going bad again!?!
- Just replaced power steering fluid return hose (pics)
- Rear Lower Control Arms
- 2003 R50 Water Pump Replacement
- Blinking A/C Light?
- led replacement for driving light!!!!!!
- when to replace my battery?
- Fan noise or ???
- Sound while turning at low speeds
- headlight washer issue
- Intake manifolt nut broken
- Fan noise or?
- DSC Light and Dead Battery
- 2005 Mini Passenger seat won't slide
- Knock Sensor, Service Engine Soon as soon as I took posession of my MINI!
- 2006 mini hatchback wont start
- Raido draining battery, any fix ideas?
- no boost! help!
- Does Napa Legend 7547 battery fit a 2004 MCS
- Fuse for radiator fan?
- Headliner coming unglued around edges - anybody???
- 05 MCSa transmission problem
- power steering hose leak and oil pan gasket, Help!!
- 06 MCS clutch kit specs?
- Wing Mirrors blown fuse
- Knocking noise coming from engine
- Dtc
- check engine light on and off
- It's impossible to Close/Latch rear sunroof blind
- Super Charger repair or replace?
- A/C inop and fans not working... Please read
- Supercharger Wine - Pulley side gear noise?
- S.O.S. multiple issues - won't start / dash lights stay on / etc
- front seat recline - again
- Yo Yo and Stumble
- Lots of rattles
- Annoying electrical "shock" when exiting??
- Help!
- R53 Issues: Odd tachometer behaviour and blown passenger engine mount
- Supercharger Fluid Capacities and Torque Values
- A question for the track and auto cross guys (Overheat?)
- Infamous 2005 airbag light problem/question
- wtf!!! need help!!!!! please!!!!
- Transmission slips after fluid change
- Washer nozzle residue / repair
- *KNOCK-KNOCK!* sound <<==WHAT'S THIS?
- Headlight Alignment Question
- Heating issue
- Newbie here! question on door locks and window
- Sad news for Happy Mini Owner
- dash light stay on permanently. HELP.
- 2003 camshaft sensor
- Delayed ignition start
- Power steering fan question??
- Help! Sun roof is stuck!
- shredding serpentine belts
- Another Windshield Question
- Please help..my coolant is leaking into my oil..any suggestions
- Need info on oil for supercharger/water pump
- Help!!!!! OBD2 issues
- window problem
- Windshield Wipers stopped working suddenly
- What sensor is this?
- Reset ECU = Smoother/ Faster?
- Power Steering Fluid Leak
- windows, keyless lock and climate module STOP WORKING!!
- This CAN'T be good...
- new to mini coopers need help!!!!!!!!
- co-worker's mini growling >25mph
- Steering Jerks?
- Starting off in 1st
- Leaking C pillar
- Crank sensor loose maybe?
- Too many flat tires
- Questions from a suspension newbie - 2002 R53
- Help!
- Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
- 2005 Mini Cooper S electrical/brakes, H/L
- sound is scaring me, please tell me this is not bad
- Windows fogged, coolant smell, oh my
- Power Steering Return Hose
- 2003 MCS Instrument Lights Stay On
- Heat wouldn't turn on nor would the car start.
- Burning smell
- Steering play
- 03 R50 popping out of second gear, help Miami locals!!!
- '05 Coupe Tranny problem
- Exhaust Problems
- Grinding Clutch pedal
- radio shorts out
- Strange Turbo Sound on 09 clubby s
- 03 mini cvt transmission problems need help
- Help with Alternator problem.
- Can anyone confirm if I have mushrooming or not?
- Loose "plug" in hole below fog lamp on R50
- Quick question on purchasing new mini possible problems to spot
- Sunroof Screen
- Yet another Mini electrical problem thread...
- corrosion on (what i think is) the bcu
- small oil leak after oil change?
- HELP! side window panel thing broken. VIDEO inside
- **NEED HELP!** Lights flash off and on when trying to start!!!
- Hydrulic motor mount issue.
- OH NO!!! Leather seat tear... Solutions?
- 2005 mini Cooper s temp issues.
- 03 S - Warning Lights, No Speedo, No Tach
- Tip of tensioner lock broke!
- Oil service interval problem
- after sc oil service, exhaust manifold red hot. help
- Chatter? What is this i hear?
- Air quality problem
- Check Engine Light & Acceleration lag: Is this the end of the road?
- whats wrong with my transmission ?!?!?!?!
- Gear shift issues
- Yup, another power steering question
- P2097 Check Engine Code
- Steering Wheel Jerks Once Upon Braking
- Right Rear Brakelight will not work (possily because of fog light mod?)
- Help: Grinding noise when I accelerate....
- Engine Blown..03 S
- HELP! Power Steering Pump + Fan problem! --> Emergency!
- 2005 Mini S Possession
- Engine busted after 70,000 miles?
- EML After Pumping Brake Pedal
- Where to get new valve cover?
- Front wiper sizes ?
- DIY: How to wreck your engine
- is this right?
- 06 mcs misfire w/ ses and abs lights?
- TPS and DSC light on won't reset
- Does the boot open from the inside?
- Need help- camber is extreme positive after suspension repair
- non suspension clunk from front of car??
- Help with belt question!
