- DTC. P2097. Post Catalyst Max/Rich.
- P0456 - Evaporative emission control (very small leak)
- Craptastic heretic.....maybe
- Oil Pressure concern after oil change
- Clock stuck on time
- Radiator Hose Rub
- Mystery Diagnostic Code???
- Chrono Pack Oil Temp Sender
- Yo-Yo Explination?
- Jack Points
- Lucas Oil Stabilizer
- Dead thing in my air ducts
- Need to find a good metal toolbox
- Cruise control adjustment?
- I think I had a problem never before posted...
- Cooper Tranny Linkage Seems Dry...
- Inspection II (2) costs?
- clutch compression bolts for a flywheel
- Amsoil..
- crank pulley tool?
- tools needed
- Tachometer and computer dead (random)
- new horn installation wiring help
- Is my clutch about to go??????
- Coolant (etc.) Change Interval?
- Key question from a newbie...
- Exhaust Burble 2006 MCS
- Rattling noise
- Technical Service Bulletins
- Leaking Transmission Fluid
- Timing Chain Tensioner problem....PLEASE HELP!
- Changing paddle height
- My new "MyMiniParts" Intake
- Supercharger Wear
- Battery Woes
- Hood Adjustment?
- Hesitation on part throttle - 2800-3000 rpms
- Climate Control Noise
- Need Non-HID bulb replacement suggestions
- 03 to 06 Supercharger interchange
- What's the average mileage for the first oil service?
- Normal ticking noise?
- oil catch can
- Leaking Main Oil Seal
- power steering issue...
- Heater Blower ?
- Lost some boost.
- Spastic rear hatch
- got a funny noise myself...
- have engine computer question
- Engine Fan problems
- DSC too sensitive?
- Somethin weird happened...
- Need help from Gurus!!
- Hydraulic motor mount leak
- remus exhaust for cooper S
- MC tow-hook access hole?
- small oil leak
- wiper fluid residue
- Need help setting the Clock ACCURATELY
- water pump
- Time To Play Replace Untill Fixed
- problems with CVT and possibly the engine: can anybody help?
- sunroof grease and sticking doors?
- where to get a good alignment
- Tweet Tweet
- who can tell me how big a job replacing a cam is
- what oil to use?
- Fuse blown
- linkage deterioration?
- Acceleration Hic-ups
- Use regular gas??Quoting AAA magazine Nov/Dec 2005
- Coolant Question
- 2006 Borla Sport Exhaust ?
- 1st check-up / oil-change
- Intelligent ECU
- Cruise control headaches
- S . E . S. Light on off on off on off..
- Climate and Sparkplugs
- Exhaust Gas Temps (EGT)
- DYNO DAY at SWIFT MOTORSPORTS
- Ses Code P1237
- Dvd
- If I worked on my MINI...
- Mods - mismatched?
- "Must Have" Mods
- Speedometer Signal
- P1242 engine code set
- Crank pulley DIY?
- brakes are sqeaking/screeching
- Do I worry?
- Clicking noise.. Anyone????
- SC Pulley? 15,17,19%? Whats best?
- Radiator fan won't shut off
- rewiring the paddle shifters in the MCSa
- Steering Pump WON'T SHUT OFF?
- Clutch feels very light after being replaced?
- Where's the heater rail vent screw on a Cooper?
- Partial JCW Kit for '03 MCS?
- brake light on sometimes?
- Duron Synthetic Oil 5w-40
- Stuck brake
- Service Engine Soon Light Activated
- How much damage to my clutch?
- Oil drain plug
- 36MM Socket Wrench - Where?
- Hesitation when cold, MC
- O2 sensor malfunction
- I reset my ECU
- Dummest Question Ever.... (I can't pull the front wheel off?)
- oily mini...
- Help With OBD Code P1237
- Brake Hesitation at Cold Start
- pilo intake
- Beeeeeep!
- Fuel Additive for Fuel Injectors
- Test for LSD
- Questions after replacing Power Steering Pump
- yellow light on speedo 03 cooper S
- new catch can install, havent seen this one
- ALTA-nator Pulley
- Rough 1st and 2nd Gears
- CVT drip anyone?
- Front Strut Brace question ???
- Torque strut - damper "home grown"
- pics of my new mymini intake!!
- ECU diagrams
- ECU version timeline
- Side marker sticking out from fender
- Mobil1 vs. Amsoil
- New engine block on the way
- my coil pack and livewires arived!
- what is the official ECU re-set procedures?
- Passenger seatbelt light/ audible chime... HELP!!!!
- First time overheater...
- Mirror vibration
- 1st Oil Change
- "Oil change at a minimum of once a year...."
- OMG, ABS issue again!!!! Help....
- DSC and Service Engine Soon lights are on
- Overzealous fuel guage
- Rear wiper blade removal?
- '05 Filter Housing Oil Leak / Convertible Impression
- New Bie w/ a Qucik Question....
- Bad Day...Questions on Cylinder Head & Clutch Problems on '05 MCS
- Wierd Look'en Spark plugs!
- Racing gas=no stumble!
- 03 mini S air bag code
- Home link mirror upgrade?
- grinding or rubbing noise...
- carbon fiber intercooler cover
- UniChip and warranty
- When is too much mods?
- Water Wetter
- spark plug gap
- sway bars??
- MOD recommendation
- Supercharger Tech. question
- Injector help , Please !!!!
- Engine Rattle-Tapping Fix!!!
- My Next Mod.......
- Mini dealer only parts...
- Fuel Filter change... any how-tos?
- track day prep
- More Power!
- Loss of Power
- Parking Brake Maintenance
- to launch or not to launch
- Which OBD tool to reset airbag light?
- 06 MCS: timing retarded?
- Broken Glove Box Latch
- OBDII engine code p1476 ?
- Compression Test?
- Engine oil consumption + Noise.
- Variable Valve timing?
- Is my steering motor shot???
- New Clutch/Niello's the best
- another ticking thread..anyone know why?
- Power Brake Booster Leaking Down...advice?
- Thought of upgrading my BC1 to a BC2
- Xenon bulb replacement
- Brake Pad Gap???
- LSD Oil?!!!!!!
- Foul odor under acceleration
- Funny clutch noise...
- What oil filter and where to buy?
- Breathing at altitude
- Weird Transmission squeeking noise.
- White smoke & blue fluid everywhere...oh my...
- Fuel Pressure
- P0130 and Rev issues
- Oil Change Mileage Meter
- Ok, here is an easy one for ya
- Has anyone seen, and touched, one of these?
- New gasket done. Now new head :-(
- teaching a crashed cooper S- throttle body
- S/C pulley tool, crank pulley tool & belt tension tool
- How much boost
- Driving in heavy rain/puddles? Help please!
- A nice touch under the bonnet
- 2006 MCS JCW and "Diesel" Clattering Noise
- My MCS is dead!!!
- Rear jacking points and Jack Stand placement
- Installed Aero Kit this weekend
- Smoke
- why not the 19%
- Speedometer ticking???
- M7 air gain CAI
- Crankshaft Pulley Numbers
- MCSa shift lock
- ScuderiaMini Undergoes Surgery
- limits of the steptronic
- Rear bumper removal?
- Am I crazy...or is my MPG down...?
- Which OBD II meter to get
- Mcs Aux Gauge Kit Not Reading Boost??
- OBD P1681 SES light
- Lies and more Lies...
- Love my MINI, but BMW sucks!
- 06 MCS - Buzzing rattle from hatch area between 3900-4200 RPMs
- Knocking noise
- BPV Instructions
- CAI - looking for recommendations
- Optima Performance Module
- Check engine light, OBD, oyxsensor questions
- Completely lost....
- SES light...any suggestions on what this could be?
- coolant replacement..
- MCS Stock pully size ?
- Steering wheel 'clicking'? Help?
- 2006 throttle lag
- The "it cant be its too cheap on ebay" thread
- Need help with engine block coolant drain plug
- fuel presure regulator vacuum connection
- Ignition ?
- SES, EML, DSC and limp home
- Stumble, died, now a check engine light
- o2 Simulator for MINI?
- Ok kids... let's talk about SKIDPLATES!
- 03 Mini throttle body
- Whats the deal?
- error code help
- Did the Exhaust hangers or piping change during 05 model switch?
- OBD-II Data Logging
- New flywheel, old clutch
- Show me what you have under your Bonnet!
- Pulled the trigger on Aero Kit... Now what?
- Misfire/Plugs
- 15% Pulley Removal Tool
