- Blown fuse?
- Throttle Hiccups >:( This shouldn't happen!!
- 2006 MCS automatic transmission issues
- P1692?
- recharge r50 a/c
- Used 05 MCS Repair priority suggestions
- Not starting...
- Stock Shock Replacements
- Hesitation/p1498 code
- Where do I begin?!
- Whaddya think? Noise issue (front end) ...
- Building my garage -- what tools do I need?
- Headlight problems
- Fault Code P2420
- R53 stock lower air box (silencer) Question
- Valve cover gasket leak + odd issue...
- Coolant expansion tank leak? I think?
- AC not working, Radiator fan is working
- Is my alternator dead?
- Cel
- "Vehicle electronics failed" according to the manual legend
- strange oil leak
- A/C blows hot for 5 seconds
- OBC Display Issue, loose wire?
- R53 Throwout Bearing-Alternatives to plastic junk?
- Flat tire indicator light flashing but no flat tire?
- Need help deciphering ODB codes on 06 MCS!
- Which Crank shaft Pulley and Thermostat ++ long
- opinion on buying tranny's from wrecked mini's (on ebay)
- How to Route Spark Plug Wires
- how to check high speed fan operation?
- Rear Wiper stopped working
- Need help!
- Different lock problem than normal?
- DSC/Service Engine Light and Bad Stumbling
- Body Plugs
- Part number for heater core insulation kit in driver's footwell
- Growling sounds from under vehicle when accelerate hard
- Battery light coming on when flooring the gas/accelerater Pedal
- P1688 and the SC BPV
- Radiator Fan keeps running after car is off
- Hit a Curb: dealer says replace control arm and steering rack?
- Sunroof drains
- What could it be?
- Boot door won't open
- Which radiator fan?
- ATI Damper Deal-$245.90
- (STUCK) Car not cranking, need some suggestions (PICS)
- DIY MTF Replacement
- Check Engine Light - Post Cat Sensor
- Navigation rubber button - sticky or melting
- 2002 MC Reocurring DTC 1485 Code
- P2096 Mark of the beast
- Key fob not working, not a battery issue
- Power Steering Fan
- Keyless entry problems
- headlight leveling sensor touching e-brake
- brake warning lite-can I drive?
- Front end noise solved after two years
- Baby's first visit to the dealer - EEK! - Lesson's learned
- Urgent help required!
- Front bumper light question
- Recurring Code 2906?
- A/C stituation
- Replacement of R53 Intake Manifold Gasket - Parts Needed? ist
- Transmission fluid
- Help snapped bolt in cylinder head
- power steering pump stuff
- Deciphering Diagnostic Codes
- Odd obdII code
- anti-freeze in oil
- 02 MCS about 3 min after turning on A/C SES and DSC lights come on
- lower timeing chain cover removal
- Supercharger grinding-listen
- P1776 & P0700 Codes
- a/c question - is there a relief valve?
- Timing chain tensioner?
- How does YOUR sunroof close?
- loud clunking noise when turning on the automatic climate A/C
- Need Help, car won't turn over
- HELP! snapped serpentine belt,multiple codes, rough idle, reads boost at idle??
- Failed timing chain tensioner
- EML light and Service engine soon light
- Seat forward tilt adjustment issue
- HELP! Another A/C P/S Post...
- 2002 MC throwing DTC P1485 codes... there are no P1485 codes for Mini
- Beat the rust! (rear door)
- Steering wheel buttons not working
- Need a Good A/C Shop In Brooklyn or Queens New York
- Neither a/c compressor nor power steering pump fan will kick on
- Coolant Leak - Possibilities?
- Oil drain bolt- BMW cross number?
- Mini r52 2006 starts fine but after 2 or 3 seconds shuts off.
- Trunk Latch
- 2003 Cooper S wont start.
- A/C compressor install tricks (FTW)
- crank position sensor o-ring gasket - how to?
- a/c system - which o-ring is the culprit?
- 04 cooper issues
- 05 cutting out in hot weather
- fuel gauge issues
- Headlights staying on.
- Anyone have USAA Extended Vehicle Protection Warranty?
- Need Help Engine Troubles
- She's a boiling mad!!!!!
- Replacing Cam Shaft Position Sensor
- Power Steering Delete?
- Mid RPM Lag?
- a/c problem - need advice
- Battery Light w/ no power steering
- strange cigarette lighter issue
- R53 - Driver's door won't open inside or out!
- Brake light + side turn signal light problem
- Strut question....
- Deeza Chassis Parts Not Good for MINIs
- Quick o2 Help
- Please help, my R53 hates me...
- horn fuse keeps blowing!!
- Help identify leaky boot on axle.
- Play in inner CV joint
- Power Window Problems
- anyone have oil cooler info?
- A couple elusive problems
- Anyone have wiring diagram for Clutch Switch?
- Oil Oil Everywhere Pin Pointing Help
- R50 Starting Issue
- Need help identifying this vaccum line and what it goes too
- whats this gunk on my valves?
- valve cover need help!
- Help! intake breather tube/valve cover install
- CV joint noise yes or no?
- 02 sensor & SES light issue
- 2005 MCS - Loose Steering Wheel - Help!!!!
- Where to buy side mirror housing cover?
- Belt tensioner DIY
- R-53 Clutch Problem
- X6011 Connector R50 W10 Automatic
- Moldy / musty smell from inside doors
- Help! Possessed MINI!
- OBD Codes for 2006 R5x?
- I Think I Need - Wheel hub with bearing, front 2 03/2002 - 07/2006 31226756889
- 3 yellow warning lights all at once- what do they mean?
- Knock Sensor and Bad Gas
- Dead R50 After airbag!!!
- Loud interior vent fan
- Xenon headlight out... how to analyze which part is bad?
- Door sill plate help needed
- Need your input on a friend of mine r50
- AC issue
- Lock on one door not responding to fob
- My windows whine!
- Question about damper (SC tensioner shock)
- Clutch starts making wheezy noise then pedal drops- in 4 hours!
- issues with body shop
- "Pop" noise when accelerating
- Overheating Mini,no solution.HELP!!!!!!!!!!!!!!!
- Horn takes a bit of effort to honk...is this normal?
- Help with a/c...
- power steering fluid appearance
- Electrical wackiness
- Oil ... everywhere
- Anyone Else Had their Vibration Damper Come Apart?
- Name that noise
- Starter Failing?
- How do I get the leak diagnostic pump off?
- Need help locating trim items....
- P0037 code.. Bad o2 sensor?
- 2002 Tranny/Drive Train Questions?
- clutch noise (same as loose belt) whenever clutch is pressed to the floor?
- Trans Failure '05 Mini - 5 Speed
- Fixxxed triple light of doom[speed sensor] but...
- Another A/C problem.
- strange indicator lights.. help?
- 03 MCS still runs when key is turned off
- A/C noise
- Power steering pump fan - repairable?
- 06MCS Throw-out bearing covered under extended maintenance plan?
- replaced my battery....now car goes no where fast.
- Power Steering Help! (after replacement)
- Speed Sensor related to recent pulley install?
- My fix for the armrest
- '03 MCS Engine Miss
- Question regarding alternator output readings
- Mini Won't Turn over, battery is charged
- New Creaking Sound From Rear
- 2003 Mini Cooper fan won't turn off
- Mini Fan Low Temp not working
- Having trany problems..HELP...
- Creaky clutch pedal or cable or something?
- 2006 Cooper S SRS Light
- Power steering Heat failure
- Low Fuel Pressure
- Turn Signal Turns High Beam On Each Time I Signal for a Turn
- outside temp. indicator,chime quit
- Passenger seat occupancy sensor SRS light? No more!!!!
- Rotor Bolt
- Off-centered Exhaust Tips
- axle won't pop back in!?!
- You're not gonna believe this...
- Key Fob Problems :(
- Mini Servicing in Vancouver. Does this sound reasonable?
- Need help please
- Strut mount replacement tips
- Coolant Overflow leaking?
- battery, starter, or worse?
- rpm specific engine power loss
- Heater Core
- fuel pressure
- R50 5 spd a/c on, idle bottoms out when compressor kicks on
- special tool for timing chsin on R53 cooper s?
- Heater Core
- Couple wind/road noise questions regarding door seal and sunroof seal.
- Hatch panel (not boot) full of water after hard rain!
- Oil Leak.
- 03 MCS Headlight Bulb
- strange wheel noise...
- Head or head gaskets?
- HELP! my transmission died
- Rear license place light wiring
- PS Fan Fuse Location....
- Ok, so I found the problem with the A/C
- Banging noise
- '03 xenon switch to halogen
- Strange tapping feeling
- Broken Center Exhaust Support
- Oil Gushing....HELP!?
- Strange whistle when AC is running
- Creaking clutch pedal noise
- Adding 05+ fan shield to 04 R53
- Key Fob programming
- SES light on after replacing motor mount
- Camshaft Position Sensor - Problem!
- i need a new transmission
- R53 Limp mode + engine light at 6k revs
- Strange tapping sound
- Driver Seat Won't Lock
- My transmission is leaking uncontrollably -_-
- My First Trifecta! ABS/DSC/Tire pressure
- PLEASE help me fix my mini!!
- Transmission Problems :(
- license plate bulb corrosion
- Replaced Supercharger Tonight!!! DIY
- Well I think my PS Pump is failing...always on
- Random Beeping Noise
- 1st Gen JCW Suspension R53 And GP
- need a DIY for replacing front lower balljoints
- What is this noise...transmission?
- Tach. computer readout not working.
- Does ANYONE out there fix/rebuild transmissions for MINI's? (2006 Cooper S Automatic)
- need help transmision oil
