View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. replacing the cabin filter.....help please
  2. Powersteering Fan!
  3. alta panel filter fit
  4. Starter Heat Shield Orientation? NEED PIC!
  5. Seat belt warning chime
  6. "Sevice engine soon" High and fluctuating RPM's at idle.
  7. Electric Insulators?
  8. No power to the OBC or Starter... Can't even jump the car!
  9. Removing I/C
  10. flat tire light
  11. Removing Air Cleaner
  12. When parked, car revs up, shakes, and EML/Service Eng Soon Lights come on
  13. Fixing the air conditioning/Insurance Insanity
  14. Xenons going out, every now and then
  15. Smoke on startup
  16. Best replacment air filter
  17. Rain sensing wiper sensitivity.
  18. More engine idle questions
  19. HELP! Both windows are stuck!
  20. p1238, p1242
  21. Buzz from engine bay - need help
  22. Rear A-Pillar!!
  23. Window not working properly
  24. Remapping question
  25. Hatch stuck close.....help
  26. tapping/ticking in neutral at idle
  27. Gas tank clean up!!!
  28. Best Place to order OEM parts?
  29. '06 SIRIUS Antenna...Removal of OEM...S.O.S.
  30. What are the causes of a "hard start" when cold?
  31. Knocking/tapping sound at idle
  32. Please help- new clutch needed
  33. Optima battery for Cooper?
  34. New transmission?!!
  35. Cleaning intake ...
  36. Battery Recall?
  37. Pulley Just Woke Car Up!
  38. fabric stuff
  39. 2004 Mini engine not running right
  40. '06 remote key stopped working/programming
  41. Window Help Needed
  42. Failed CVT in the desert..
  43. Uh-Oh.... What could I have done?
  44. Stupid Shift . . .
  45. spark plug recommendation
  46. My gf 02 MCS won't start
  47. I need to Vent too (dealer problems)
  48. JCW Intake Intall questions
  49. HOT in the wrong Places
  50. Removing rear bumper?
  51. brake reservior cap size-brake bleeder.
  52. slow to start
  53. Location of gormmet through firewall
  54. Good MINI Repair place in Philly?
  55. I can finally say...
  56. A/F Gauge wiring
  57. Sun Roof Drain Tube
  58. anyone with 05s have these problems?
  59. The New E-10 gas... are you having issues with it?..
  60. DIY Changing Coolant...Anyone?
  61. Did some remodeling
  62. Geez!!! I got flashed this afternoon!!!
  63. Help Help . Check Engine Light
  64. Clutch pedal spring
  65. Clutch Howl???
  66. Removing Front Bumper?
  67. ECU problem part 2
  68. So I got the S on a Dyno today.......
  69. Anyone with Bentley Service Manual?
  70. '04 Cooper S Wiring Harness Diagram
  71. Driveshaft Parts Inquiry
  72. Idle vibrations
  73. coolant temp sensor location
  74. How to calibrate steering angle sensor?
  75. Jet Engine under the hood? Or maybe just a really loud fan?
  76. A/ clutch
  77. Supercharger/Manifold gasket leak
  78. Rust - filing a complaint with NHSTA campaign
  79. Auto AC setting - 2 degree increments?
  80. Intake plastic
  81. Hot Track Day-Indicators Lights went on
  82. Brake Sensors?
  83. Pop - Clunk Clunk!
  84. Part No. 61.13 6 914 209 - 01 ??
  85. 2003 Cooper S Overheating Problems?
  86. Abs Fuse Tsb??? Show Me!
  87. Two issues
  88. Best SC Pulley Removal Tool
  89. Air Conditioning noise
  90. Power failure while driving
  91. Pure Power Lifetime Oil Filter ?
  92. Service Engine, DSC & Battery Lights - No Power Steering - Bad Alternator???
  93. Engine won't turn on first start!
  94. Stick shifting technique
  95. Cutsom CAI Box project
  96. Clutch acting weird... What's wrong?
  97. Mystery: whirring noise beneath rear seat
  98. M7 Thermostat
  99. Clunking from driver side front.
  100. Pilar cover
  101. Using a floor jack to assist with tire rotation
  102. fog light seperating from bumper
  103. 04 CVT wont start
  104. Modding an 05 MCS Auto Transmission
  105. flywheel weights
  106. Clutch slave cylinder gone after 21k
  107. LSD and ruff rutty roads?
  108. Check Engine light
  109. Auto lock not working
  110. Couple of issues with my MC CVT ...
  111. Oil catch can, How To Make Your Own.
  112. Ses/eml
  113. Fact or Fiction: Oxygen Sensor Failure
  114. Healthy Mini again
  115. Getting to the buzz
  116. M7 Oil Catch can help
  117. Problem A-brewin in Transmision Town
  118. SES light on at 9100 miles - Any ideas?
  119. 15 Things My 2003 Needs Fixed at 49K!
  120. Vibration
  121. what do these lights mean?
  122. Oil Drain Plug Location??
  123. Help taking dash apart to access defrost air vents
  124. Preventative maintenance
  125. New S - Break in exhaust note change?
  126. herky jerky big whir very rough idle
  127. Supercharger differences
  128. Oil Filter Housing - Cooper & MCS
  129. Gasoline
  130. What's the most gas you've put into your mini?
  131. Rust :: door sill area of '02-'05 MINIs
  132. Xenon out - must replace both?
  133. mini cooper spontaneously goes on fire April 29, 2006
  134. Wierd Clicking Noises...
  135. Code 2096 "Post CatalystFuel Trim SystemToo Lean, Bank 1
  136. MINI Engines are budget origin?
  137. Help..please....Mini down wiring short...probably
  138. Mods and Inspection
  139. My car is wanting to die.. Please help!
  140. Small amount of oil around plugs
  141. Dipstick/checking oil
  142. I need a BIM-COM beta
  143. Help! Rain screws up remote locking?
  144. Intake Info. Needed
  145. trouble starting
  146. Uh Oh...I hope this isnt too serious!
  147. Help! Power lag on cold start
  148. parasitic draw on battery
  149. Vibration at 3k rpm
  150. 2006 MCS Automatic Owners!!!
  151. question on narrowband oxygen sensor
  152. Need Pin-out for BMW ecu
  153. HELP!!! I have a gremlin in my mini!
  154. Variations in Serpentine belt size?
  155. Colder Plugs Part #?
  156. Service Engine Soon
  157. Toledo Mini Owners
  158. HELP NEEDED - JCW Intake Install
  159. Oil Service Reccomendations
  160. Which Coolant to refill?
  161. Bleeding Clutch Slave Cylinder
  162. Coil Wiring
  163. Battery failure so suddenly??!
  164. Confused about torque specs
  165. Driver's Side Seat Part Needed
  166. Artoo passes 50,000 miles this weekend...
  167. Squeaky Mouse in the Trunk...
  168. HELP! Car at dealer, needs flywheel, more
  169. Diagnostics Tester Fault
  170. Severe loss of power
  171. 1st gear rough and low oil level
  172. Need assistance from MCS owners
  173. Odd "Clacking" noise... any ideas?
  174. What makes a cat obd2 compliant??
  175. Shift Light Install
  176. sc / crank pulley question
  177. P0693 Fault Code - know what this is?
  178. Would adding a high flow cat trip a o2 sensor?
  179. Seat Height Adjuster problem
  180. What needs to be greased?
  181. First oil change - opinions?
  182. Installed camber plates & have change in DSC behavior???
  183. Disadvantages of 15% Pulley?
  184. Experience with TMS Pulley?
  185. Radiator coolant(Mini cooper)...
  186. CAI Intake noise question...
  187. CD Player question...pls help
  188. Overheating at idle. All fuses are OKAY. Ideas?
  189. Conversion to E85 Ethanol
  190. fresh air intake
  191. Pulley question
  192. Intermittant loss of power steering...
  193. 04 MC automatic won't start
  194. MCSa Rough Startup
  195. 99 Octane Oh Boy!
  196. whinning noise...not stopping
  197. Smoked clutch affects boost gauge?
  198. Interior door handle stopped working
  199. Chirping sound at take off
  200. Leaking Brake Master Cylinder?
  201. Clean your intake!
  202. Power Steering Issues
  203. Gurgling Sound near steering wheel?
  204. Pulley question
  205. Exhaust Burble... Goes Away w/ Upgrade?
  206. P1229 - throttle potentiometer adaption fault
  207. Anyone doing compression checks?
  208. *Air Horn installation*
  209. O2 Sensors (where to buy)
  210. Air bag light on
  211. window problems
  212. Bad sound
  213. MCS Service Engine Soon light...less than 1 day old!
  214. tire pressure sensor question...
  215. Can't open boot, Help
  216. MINI weight... GTech info
  217. Insane fast blinker...
  218. Really Loud Fan Sound!!??!!
  219. **help Needed**
  220. Auto Leveling headlight not working properly
  221. Hum from RF wheel/tire
  222. Monitoring Software ....
  223. alta panel filter - which way is up?
  224. o2 sensor circuit malfunction
  225. Question regarding "specialty" tools for clutch upgrade
  226. Red Line oil viscosity?
  227. Repair Advice for last 50K Service?
  228. Power Steering failed and came back.
  229. SES light options
  230. MAP Sensor Question
  231. 2004 Mcs On Fire!
  232. Brake sensor question
  233. Brown coolant
  234. Alignment at dealer?
  235. Input shaft seal leak
  236. How to install a tag on the front of your Mini?
  237. Car Shakes while STOPPED! need help!!
  238. Pulling during shifting
  239. 2005+ How to Reset Oil Change Counter!!?
  240. Engine break-in?
  241. How 2 clean your IC???? need help
  242. Question on replacing the Fan Assembly (radiator)
  243. Help! My MINI is Sick!
  244. Costco gas - good for my MINI?
  245. Squeaking Pulley
  246. transmission linkage?
  247. Clunky '05 Getrag trany? (5 spd)
  248. Sunroof Noise
  249. Flushing/bleeding clutch
  250. Adjusting gas/brake pedals
