View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. S.o.s. My S.e.s. Light Is On
  2. Time to do Inspection 1
  3. What is the 2nd Inspection comprised of???
  4. Belt Number
  5. Front upper strut bolt sheared off....crap!!
  6. Air Compressor for Mini A/C
  7. K @ N Typhoon Ram Air
  8. Yet another "noise" question. Can it be the CAT?
  9. New '06 MC at 1500 miles cut at stop light
  10. Where to get metal trash cans for combustibles?
  11. Can we wetsand our headlights?
  12. Advice needed: Grinding noises when idling...
  13. Rear brakes gone again..fronts still good?!?
  14. Noise in belt system
  15. bonnet smashed
  16. What Is This Leaky Part Under My Hood?
  17. Power Steering issues!
  18. Synthetic transmission fluid ok? (Redline, Royal Purple?)
  19. uneven front strut towers
  20. Valve Cover Gasket Leak
  21. Help diagnosing the noise.
  22. Need help with SAFC 2
  23. Software to read OBDII Codes
  24. Metal grindings in my differential - is it normal?
  25. Brake Pad Question...
  26. ABS + wheel speed sensor when DSC turned off?
  27. passenger seat puckers
  28. Almost 50,000
  29. An initial pop/snap/clunk sound when braking
  30. New sound...
  31. MCS Exhaust heat shield question
  32. Broken Paddle shifter
  33. power
  34. Kudos to the 6th gear'ers
  35. 1st gear Thunk
  36. Midlands Transmission Fails to Engage Reverse
  37. Break-in period for new tranny/clutch?
  38. CVT Lurching problem reduced with new spark plug wires
  39. Belt Tensioner Tool???
  40. How much did you pay for a %15 pulley?
  41. Warranty Work - Must Dealer Replicate Problem?
  42. Does your MINI shudder?
  43. car doesn't roll!
  44. Removing intake manifold?
  45. engine
  46. Fuse for Seat Warmers?
  47. changing the oil - MCSa '06
  48. Spark Plug jumped out of Cylinder Head
  49. Warranty Acceleration
  50. Spark Plug Ejection Button
  51. Another Warranty Question
  52. My MINI won't start...sometimes
  53. Issue with Gray Leatherette - Flaking color
  54. Am I headed for catastrophic drivetrain failure?
  55. HELP ASAP! Car's acting up...
  56. Change oil too often?
  57. where do I find TIS Bulletins?
  58. alignment issues
  59. Blown Engine!
  60. silicone intercooler boots
  61. stress crack???
  62. 05 ECU wanted
  63. Great place for oil changes in Tampa
  64. cracked upper strut mounts...
  65. AutoEnginuity - Enhanced BMW/MINI Interface
  66. Supercharger R&R
  67. Whoops! Left the sunroof open on my 02 mini
  68. Which spark plugs
  69. Alta Radiator Hoses (where do they go?)
  70. I think I lost my burble!!!
  71. Coolant Capacity
  72. Transmission rattle?
  73. Lower steering column shaft bound up
  74. Tire Pressure Help
  75. MCSa harsh downshift
  76. My car is getting louder and louder!!!
  77. Alta Intercooler Air Diverter Opinions...
  78. Top Brake/Tailight WONT TURN OFF!!
  79. Unexpected Engine Shut Off
  80. is the clutch a warranty item?
  81. Brake Caliper noise
  82. 2 Pre-Cat Bungs
  83. Hmmm... loose or broken engine mount?
  84. Window won't roll down
  85. MINI Rear Quarter Panel Construction: Dent removal
  86. Subtle build differences on '06
  87. Seat Feels Like it Slips Forward
  88. Undercarriage photo
  89. MCSa Reverse problem
  90. Help with my key?
  91. Help with a battery for an MC 2002
  92. Odd exhaust smoke
  93. Pre-Cat o2 sensor with PLX
  94. clutch rattle while in neutral with peddle released
  95. Fan motor screeching
  96. Sunroof
  97. SES light on and clock says EP. Please help!
  98. How to replace rear sidelight bulb?
  99. Weird Check Engine Light?
  100. It's about time for a new Cracked Windshield thread
  101. brake pad recommendations
  102. Mushroomed?.....please raise your hand.
  103. Engine stalling when driving slow/stopping.
  104. Rear Window Washer Fluid Leaking?
  105. OBD2 Drive Cycle Parameters
  106. Rattle : Supercharger / water pump
  107. steering to the right
  108. m7 Strut Brace Install Question
  109. mod parties in the DC/MD area?
  110. Clunk when I shift
  111. 2006 MCS - Slight Hesitation at 3000 RPM
  112. Oil Trap
  113. Headlight Power Washer Problems
  114. Sluggish S, post O2 sensor lean (p2096)
  115. Need help with pinging? I may have found the answer!
  116. A/C question.
  117. Warranty Hell ... not really.
  118. Rough Idle on start - Engine Quits - Battery or Hot Weather Damage?
  119. Hot Mini
  120. Ping heard in hot weather
  121. Power Loss on Dips (?)
  122. How to? Strut mount replacement
  123. What brand of struts are on the MINIs?
  124. Has this happened to your MINI before?
  125. Rumble/grinding sound in engine compartment
  126. Clutch 'Chatter"
  127. Strange clunking sound
  128. blew a hole in my engine!
  129. Our Mini Seems To Have Hydrolocked!
  130. Brown coolant?
  131. Which Optima's will fit a MCS?
  132. clutch squeal
  133. Push Button Start
  134. DSC and ASC
  135. odd noise?!?
  136. 02 cooper engine light.
  137. The Great Power Steering Pump Failure/Problems Thread
  138. Throttle body anyone?
  139. Los Angeles - Transmission help
  140. Car wasn't starting at first.. and then..
  141. Best Mechanic and install Thread
  142. Mini Window Problem
  143. ABS, DSC lights ???
  144. battery dimensions for the mcs
  145. Noise From A/c Fan
  146. Noise From A/C Fan
  147. Hot Disk Brake Problem
  148. Full Throttle Shut-down!!!
  149. Another Xenon Question
  150. Need a belt
  151. A/C Drain tube?
  152. 06 Rumbling
  153. Octane additives - anyone in CA using some?
  154. SES / DSC - Limp Home - on a Manual
  155. plug wires and maint. intervales
  156. question about Inspection II
  157. strange clunking noises
  158. How Many Filters....
  159. Oil Consumption
  160. '05 MCS A/C noises normal?
  161. Air conditioning question
  162. bad stuff happening to my mini please help
  163. Fuel System Questions
  164. Dinan Strut Tower Bar
  165. What kind of Transmission fluid??
  166. Have you had this problem? Limp Mode / Bypass Valve
  167. WOLO "Bad Boy" horn install?
  168. Spontaneous engine bay fires!
  169. Split Strut Mount @ 5600 Miles
  170. Sunroof suddenly squeaky
  171. Average Speed Calculator is wrong
  172. Belt tension...how to lock
  173. Engine Oil loss...
  174. Out of warranty oil change - Tampa area
  175. Sparkplug Tubes
  176. What the heck... MINI won't start.
  177. colored strips on intercooler?
  178. under bonnet insalation-sound proofing
  179. mcs hood scoop
  180. LAG or what?
  181. Air Conditioning At Start Up
  182. How do you know when your struts are bad?
  183. Intermittent Clutch pedal stuck to floor
  184. Dead battery or something else?
  185. 2 Questions, 1 with steptronic, 1 reg auto wipers
  186. i cant get out of my MINI!
  187. shift knob removal
  188. OBD Connector Location
  189. Performance hot vs cold
  190. speedbleeder sizes
  191. Stumbling at speed under low load
  192. Redline MTL or MT90 for trans
  193. Optima Tuning High Performance Module
  194. Squeaking
  195. Power Loss (for the second time)
  196. powertrain trouble?!
  197. Diesel or a Mini?
  198. service engine light
  199. Pulley Puller...
  200. Help....clanking noise
  201. First oil change confusion
  202. Am I missing something?
  203. Need help installing Crank and SC Pulley...
  204. AC compressor fuse where?
  205. EMERGZENCY - Did I just do something REAL stupid?
  206. Oil pressure after oil change
  207. grabby clutch?
  208. What could be involved in a bad shifter bushing?
  209. boost is wierd
  210. Pulley install in Nashville?
  211. cylinder head porting guide
  212. Knocking noise
  213. Max boost readings in Hg
  214. Involuntary "software" reset
  215. Calling those w/scan tools
  216. map sensor plug 03 cooper S
  217. Can the 'burble' be buried?
  218. MCSa over revving...
  219. Cooling Fan Constantly On
  220. MCS vs MC - Does one have more issues than the other??
  221. Electrical Hiccups? Please help...
  222. Question about the MCS Supercharger
  223. JCW intake install help needed
  224. Question about clutch
  225. Greasy film in coolant reservoir!?
  226. Quick 60k service Q:
  227. oil catch can?
  228. Weird noise
  229. Coolant change problem
  230. Diagnostic/reset tools and my problem??
  231. What is a used supercharger worth?
  232. 18-19 miles per gallon with easy driving
  233. Something moving inside my passenger seat
  234. Change my oil before my first service?
  235. Torque Setting Garage Quick Reference
  236. Hood scoop removal instructions
  237. Dilectric grease
  238. Hot weather here..So are my
  239. Anyone else with no AC in an 05?
  240. Warranty Fixes on 03 MCS!
  241. Pitman arm removal tool for SC Pulley
  242. OEM parts
  243. Exhaust port size
  244. Transmissions troubles....help
  245. Wierd brake bleeding experience
  246. Wierd brake bleeding experience
  247. Brakes
  248. So, whats Next? help me decide.
  249. Different Windshield Issue
  250. Pinhole leak at top left corner of radiator (facing car)
