View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. MCSa throttle hesitation
  2. Flat spot?
  3. Question for owners of OEM LSD's
  4. Exhaust squeak....
  5. Sporadic door unlocking, relocking...
  6. Need Help With OEM Driving Lamps.
  7. Where'd the whine go?
  8. adjusting wastegate and bov
  9. Metal grinding noise @ startup
  10. Windshield Fluid Line
  11. Flapping noise while filing with gas
  12. 03 mini cooper transmission problems
  13. What's This Connector For?
  14. Weird noise "Beneath the Bonnet"
  15. leakin'
  16. help!!!
  17. Brand new supercharger from MINI
  18. Removal of Alternator help needed
  19. coolant resovoir leaking
  20. My MCS burped itself!
  21. Sloshing Sound
  22. Battery light on
  23. Engine Pinking - Help!
  24. Baton Rouge Service Experience??
  25. Stupid Airbag Light
  26. gauge power
  27. 02 MC will not start - help
  28. Anyone have this happen?
  29. Gearbox noise MAYBE?
  30. Level 1 service??
  31. Rear mushrooming or a cracked strut?
  32. Starting issue... I think I have electric Gremlins...
  33. Lazy brake light on dash.
  34. OBDII problems... need help please
  35. any supercharger wastegate problems
  36. Warranty tires????
  37. new clutch at 25k!
  38. Dealer Maintenance Question
  39. Extreme MPG
  40. Speedo/gas/temp needles vibrate at start up
  41. Radiator Hose Clamp Tool
  42. Adjust clutch to be lighter?
  43. Belt Issue
  44. testing ethanol content ...
  45. oil questions
  46. Replace power steering pump
  47. Changing oil tomorrow, what weight?
  48. Speaking of Power Steering
  49. Anyone had THIS issue?
  50. Supercharger Whine
  51. Any Lift Recommendations?
  52. Service Engine Soon light keeps coming back on
  53. Sinking clutch pedal & Cant Get it in to gear?!?!?
  54. Can new front wheel bearings be pressed in?
  55. OBD code anyone?
  56. Yipee for cool weather and Redline SI-1!
  57. crackling sound on MCSa
  58. Parking light / Turn signals
  59. How to remove air duct from box?
  60. Limited slip differential: Lifespan And DSC effect
  61. 2nd Mod complete: What's behind the airbox mod? (bmp)
  62. Clicking Sound When Breaking...
  63. Polyurethan Motor Mounts or Engine Torque Brace?
  64. oil canister flat spot
  65. Dirty chrome exhaust pipe tips
  66. Need Help - MINI Service
  67. Texas Speedwerks & LOTF Torque Dampers - help!
  68. Reoccuring issue with xenon headlights, need your help!
  69. hood/bonnet light won't go out
  70. Leaking motor mounts? Anyone else?
  71. EML light comes on & loss of power
  72. 12V Power outlets: constant on, possible?
  73. Engine Oil Analysis Service
  74. Question about Xenon Headlights
  75. Two things???
  76. Seat help, and door locks
  77. Oil Filter Housing
  78. Loose Throttle Cable?
  79. What occurs at the 10,000 mile service?
  80. Battery Dead. How long to run to recharge?
  81. Where can I find radiator grill for 02 MC?
  82. 2nd gear
  83. Help identify part that needs replacing and where to buy
  84. Help!!! did my radiator blow or what???
  85. Service Bulletins-where can I find them?
  86. help with code troubleshooting
  87. help with code troubleshooting
  88. That's a Light Clutch
  89. Crunch going to reverse
  90. Clunk when engaging gear...
  91. Squaky Clutch?
  92. Engine codes definition needed
  93. Service Bulletin Question? SI M 21 01 05
  94. Glovebox liner replaced... No more a/c vent?
  95. Downshift clunk/jerk?
  96. Headlights NOT moving anymore!?
  97. Supercharger Problems !
  98. Steering Loss/Lights Flicker--Connection?
  99. Going in for 1st Service in a couple of hours
  100. Massive Oil Leak
  101. Some new BS
  102. Broken Driver Seat?
  103. Doors Locking Themselves
  104. Busted Motor Mount
  105. Can Bad Gas Do This??
  106. Clock Light/Fuel Gauge Flicker?
  107. Where is the fresh air intake for the a/c?
  108. Intermittent Screech/Squeal at 70MPH?
  109. Turn signal gone wacky
  110. Shift rod wobble about quater of an inch with SSK
  111. Blown Transmission
  112. Help finding part or repair
  113. What to check when the power steering goes away?
  114. ****ing monkeys
  115. Valve cover leak
  116. Engine Flush?
  117. weather strip/seal wear - normal?
  118. totally dead 2003 MCS
  119. Service Warranty is Over!
  120. Loss of Power After Engine Cool Down
  121. OEM Plugs at 60K miles
  122. Xenon went purple?
  123. Questions about Xenons
  124. Do modded cars run perfect?
  125. '04 MCS - Alternator & Belt questions
  126. Could use some help from Engine guys!
  127. Can anyone tell me...?
  128. External temp. sensor broken
  129. what IS that?
  130. Loose switches (window, lock)... how do I fix
  131. Denso IK22
  132. OBD II Connector Not Functioning
  133. Slight hiss when I shift
  134. Help replacing window motors/regulators
  135. Thunk, underneath car, from abrupt bumps
  136. intermittent windows
  137. MC (non-s): engine idle ticking
  138. Problem with Negative Battery Connection
  139. Whoops. Xenon problem
  140. White residue, soapy feeling under the hood...
  141. P0340 Fault Code
  142. broken 05 engine mount???
  143. Another "Quirk", Another Headache :(
  144. 911 help engine ratel ?
  145. Radiator hose length?
  146. M7 SRP owners experience
  147. MINI Keys
  148. Click or Dbl Click When shifting from 1st to 2nd Gear???
  149. Newbe oil change
  150. Extended Warranty Pitfalls?
  151. Installing Cruise if you dont have it stock
  152. Alignment needed or not?
  153. clean out that rodent nest!
  154. Serious Transmission Problem - Urgent Advice !
  155. Stainless overflow tank on a Cooper?
  156. DSC, tire inflation and ABS lights on...out of nowhere.
  157. windshield wiper replacement
  158. Switch box harness plug. how do you unlatch?
  159. Bleeding the Clutch
  160. JCW Air Filter Maintenance
  161. Slight hesitation - engine map?
  162. In need of a picture of MCS exhaust mounting
  163. Super-fast blinker mode!
  164. Warranty Legal Upgrades
  165. Motor Mount Damage
  166. coolant preferences?
  167. Oil Filter canister stuck
  168. Flywheel warranty fix
  169. Lost on door panel removal.
  170. not BENEATH the bonnet, more like part of the bonnet...now I need...
  171. OBD II code
  172. Help - Warranty Claim
  173. question about wipers....
  174. Micro filter replacement
  175. New to the Mini - Do It Yourself
  176. Castrol OUT, MOBIL 1 In, encore...
  177. Poll: Mushrooming/strut mount failure data collection
  178. 100 octane...good or bad for a mcs?
  179. A/C doesn't cool down car on hot days
  180. Mechanic
  181. stock tires lose pressure
  182. Burnt Clutch Smell
  183. back pressure while accelerating
  184. Did I just lose my clutch or my transmission?
  185. M7 Strut Bar install suggestion (insulation pad surgery)
  186. Flywheel... new and improved.. I hope
  187. Dealer refuses to replace Bypass Valve under Warranty.
  188. Is a locked door stronger?
  189. Black fluid leaking!
  190. Erratic MSCa downshifting on its own.
  191. M7 Strut Reinforcement Plate Problems?
  192. Help my car sounds like rubbing when I make slow tight turns
  193. Can you buy an extended warranty anywhere?
  194. Engine details
  195. i dropped my nut
  196. Mini Cooper Cylinder Head
  197. wiring harness in battery box problems
  198. Too much Ethanol in current gas causing problems...
  199. Possible transmission problems?
  200. need some quick help - oil spilt in engine bay
  201. Need HELP with S intake manifold removal..
  202. No tailgate cable under the rear seat
  203. Most Miles/Kms on a MINI?
  204. CAI cut-out template???
  205. Excessive Power Steering Noise
  206. Installed the 2% crank pulley, what's next?
  207. Factory Reset Tool
  208. How long does a Mini Engine....?
  209. Fault Code P0563
  210. When are brakes normally serviced?
  211. I must have caught a MINI virus...
  212. spark plugs
  213. 02 mini OBD?
  214. Mini Service Manual...Best one
  215. 100 miles before 36K. Do extended warranty or not?
  216. Is the "Inspection II" required???
  217. How to tell if O2 Sensor is bad?
  218. Recommended brake pads
  219. Looking for a reliable shop near Knoxville, TN to install 2% crank pulley...
  220. 2003 MC-ECU and Engine revisions
  221. First Service Advice
  222. what does the P0030 P-CODE DO?
  223. Need Dinan advice, please...(some what long)
  224. 218 Hp.
  225. Ses light and p0444 code after pully install
  226. DSC Warning Light
  227. Gas Gauge Issue?
  228. Need Help with 05 S (interesting)
  229. Muffler Hanger Rusted and Broke
  230. Hot Ignition Key after Use?
  231. Timing chain or belt, Valve adjustment?
  232. type of oil
  233. Induction Downtube
  234. Dead Battery on the Road Question
  235. Downshifting concern
  236. Removing Cabin Air Intake Grill
  237. Oil Catch Can? Mmmmm....I'm not so sure....
  238. Calling all higher-mileage MCSa (automatics)
  239. m7 throttle body
  240. Messed up shifting
  241. How to adjust headlights
  242. "S" Hesitates When Shifting
  243. Mini Service In Seattle?
  244. Idle Issues With P0507 Code
  245. put put put... pff this sucks!
  246. Cabrio Boot Switch Problems
  247. CEL and EML light after catch can install...
  248. qualified shops near York, PA
  249. Power Steering Pump?
  250. Detroit Tuning BPV; What is it and what will it do for me?
