View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Roll Squeak. Roll Squeak.
  2. Phantom Misfire?
  3. Ticking time-bomb?
  4. Trying not to panic...
  5. I Need Help!
  6. Headlight out - the first thing to go wrong with my MINI
  7. Mis-aligned Hatch
  8. Question regarding part
  9. PCV valve noise?
  10. Hanger question
  11. BPV maintainance?
  12. '04 MC sluggish when cold
  13. Parking Brake Drag
  14. 2003 MINI Cooper Water Leak
  15. Squeeky shifter
  16. Blown #2 spark plug
  17. Will running a Helix 19% void my warranty???
  18. K&N airfilter
  19. Fuel additives are that bad?
  20. Disable brake pad sensor
  21. Headlights stopped working!!!
  22. Crazy temp and rpm gauges and error lights on
  23. I want a very loud horn. I'm sick of not being noticed.
  24. fuel pump squeal....
  25. Idler pulley?
  26. Underhood noise
  27. List of Service / Check items?
  28. What is a P1684?
  29. Brake Fluid
  30. Tips on fixing a very slight mushrooming of my strut towers
  31. Xenon headlights?
  32. moaning noise..help!
  33. Headlight Washer Problem...
  34. Need help car feels strange
  35. Spark Plug Replacement
  36. Squeaky groan solved!
  37. putting in seafoam
  38. Maintenance warranty question
  39. need help with some codes
  40. Help, My oil looks like greasy mustard mucus (pictures)
  41. Vibration noise
  42. Stripped spark plug hole
  43. I'm a little "miffed" at the scheduled warranty service
  44. Right Front knocking
  45. Looking for leather door armrest part
  46. Transmission problems at 73k
  47. Heated seat stopped working
  48. Regional Techs?
  49. HID problem
  50. What if... about engine size
  51. Valves - a - Tappin' ?????
  52. air bag light@82,000
  53. Programmable options with late 2006 MCS
  54. Power steering whine?
  55. Passenger Door Lock Broken Again!
  56. Steering Wheel Vibration
  57. Tower Bar Vibes
  58. synthetic oil vs. dino oil
  59. repair manual on cdrom
  60. Please lube rear hatch hinges...
  61. where to get MCS parts?
  62. That sounds like a ___________ problem.
  63. Help with threaded stud!
  64. Frequently burning out headlamp bulbs
  65. Oil Change
  66. Dot191
  67. Another P1688 code question
  68. Coolant leak, MINI drools
  69. Weird chime question.
  70. MINI Mania code scanner question
  71. Dead Xenon
  72. Rear Hatch Struts won't work
  73. Mini's age? Hmm
  74. Shift, EML, SES then limp mode!?
  75. TSB out on Xenon headlights in 2004 MINI
  76. Help - Need Clutch Info Quickly!!!
  77. Yet another Power Window Failure / Questions
  78. oil+filter change
  79. Code 130
  80. Anyone have a Lemon MINI and get it replaced?
  81. Belt Replacement
  82. I have a VERY weird cooling problem...
  83. Hose replacement help
  84. Can hood closure be adjusted?
  85. MINI Cooper Midland Transmission Failures
  86. Recurring Code P0136
  87. autowipers
  88. Who is using a Fumoto Oil drain valve on your MINI ?
  89. Motor mount went boom
  90. Rear Brake Pad
  91. synthetic oils and the MINI
  92. (Intermittent) Loss of Power Steering
  93. Brake Issue
  94. Jack Point Gone!
  95. Squeaks And Rattles!!!!!
  96. squeaks and rattles!!!
  97. labor to replace MC 2003 Transmisson
  98. Service Engine Light Came On..Any Ideas?
  99. Reset Tire Sensor
  100. Radiator replacement..
  101. Bell tone at 37 degrees?
  102. Brakes
  103. Removing tranny
  104. newbie w/ some questions
  105. Leak around clutch
  106. Water Pump Replacement?
  107. STP Complete Fuel System Cleaner
  108. Engine Hydrolocked, what are my options? :(
  109. Quiet Smooth Engine now it is louder?
  110. 03 Cooper Clutch Shudder
  111. P0108 overboost, but only 12 psi max on gauge?
  112. Exhaust rubber hanger rattles ???? Help
  113. Power steering pump fan
  114. Will an 05 M45 Supercharger fit an 04?
  115. Intercooler Removal?
  116. Paint Problem!
  117. Has this happened? gas gauge stuck on empty
  118. Brake Job Question
  119. Shifting difficulty
  120. Can someone tell me what this tank is for?
  121. Clutch engagement going into first gear , noise,2003 MCS
  122. Strange "whirring" sound after start up.
  123. Rattling Tensioner Bar
  124. Penzoil Platinum Synthetic
  125. Stalling at 3500 rpm + service engin light. Help
  126. Something leaking under my bonnet...
  127. Muffler bracket
  128. Vibration @ certain rpm
  129. 05 Transmission Replacement????
  130. Brown Milky coolant issue again
  131. Popping sound after shutting off engine?
  132. turn signal sound
  133. Taking driver door apart
  134. Air Filter Change on '06 S with JCW Factory Kit
  135. Draining radiator 0n 02 S
  136. TSB's
  137. New (downgrade) Formula Mobil 1
  138. Front Tire: Back and Forth Movement: What's the cause
  139. Idle problem?
  140. My car has no coolant!!!
  141. Friggin Oil Drain Plug Stripped Pan
  142. 05 MCS - SES light on, DSC light on - Misfire
  143. Anyone been able to get rid of squeaking in arm rest?
  144. 2005 5 speed Trany
  145. Mini Cooper Transmissons
  146. what does this mean?
  147. ? about the Heater
  148. Noise after engine shut off
  149. Finally changed brands of gasoline, (Shell to Phillips 66) and now I have
  150. Cat back exhaust
  151. Strange rattle and motor mount problem
  152. Cleaning Alta Intake
  153. Control arm bushing replacement
  154. window down?
  155. Sun Roof Rattle '05 Cooper S
  156. warranty question
  157. Bonnet not openning anyone?
  158. How much brake life do I have left?
  159. paint flaking on bumper...
  160. Slight rattle at idle
  161. The worse deal
  162. Does ANYBODY have a Dinan CAI?
  163. Strange Tubing fell from below glove box
  164. 05 MCS winter tire ?
  165. How do you know if bypass valve is working?
  166. sale!!!
  167. FWD or RWD?
  168. Question:Need Help
  169. Bad gas at Sunoco
  170. two issues i'm having with my '04 Cooper S
  171. Lift-off! We Have Lift-off!!
  172. Attention all CVT OWNERS!
  173. Original Battery on 2002 MCS
  174. Bottom Out
  175. Big Problem!
  176. window cracked
  177. CV Joint Question
  178. When should I get belted?
  179. cooper s rebuild
  180. Heated Seats
  181. Oil Change Reset ???
  182. Nothing really works in my Mini
  183. Blinker/speedometer/seatbelt lights malfunction!!!
  184. The bonnet itself
  185. Catch Can ain't catchin' nothin' - why?
  186. rough idle related to emission controls???
  187. remanufactured clutch
  188. 02 MCS problems
  189. Unichip or GIAC or JCW software upgrade my findings
  190. Service Engine Light ?
  191. Crank pulley owners
  192. anyone?
  193. How long should I expect a clutch to last?
  194. Auto locks
  195. who's done a tear down?
  196. Under The engine/car?
  197. No Power! SEC and EMI light coming on while driveing
  198. Inaccurate Speedometer
  199. Ticking when stopped
  200. pcv?
  201. Dripping Oil Slowly
  202. breakin' up
  203. Bonnet Light
  204. battey/jump start HELP!!!!
  205. Anybody had a tensioner go out?
  206. Belt Snapping and Excessive Wear
  207. OBD codes C1e5c & U0050
  208. Stiff Clutch
  209. clutch slip?
  210. Pops and Bangs
  211. cold start stumble
  212. Oversensitive DSC ??
  213. torque wrench
  214. 2003 MCSm warranty question?
  215. Crap!
  216. Booom!
  217. sway bar question
  218. 02 Cooper trans woes/cheapest dealer
  219. LSD and DSC light?
  220. Lots of Warranty Repair on 06 JCW
  221. Lots of Warranty Repair on 06 JCW
  222. Question for 2006 CooperS owners
  223. Dealer ECU Flash
  224. A Stupid Woman Question
  225. Keeping DSC off as default
  226. My MINI died on the highway
  227. Water pump hoses leaking
  228. New 2006 Cooper jumpy at very low speed/throttle
  229. lift points
  230. Heater Problems
  231. lifting
  232. DCS, TPS, and ABS light are all on..why?
  233. re-run
  234. Just a little note.
  235. 2ND OIL CHANGE @ 2916 miles....
  236. oil path
  237. Drain & Fill Plugs on tranny?
  238. rear hatch rattle
  239. Mobil 1 vs Castrol Syntex. Opinions?
  240. Err...brake pad warning light just came on...
  241. Rust???
  242. Very Odd Noise
  243. Xenon Flicker
  244. Anyone else having this problem? ALTA CAI
  245. Need help with vacuum/boost leak...
  246. Code 1477.... who knows why? calling Dr. O and friends
  247. Rodents and Spark Plug Wires
  248. Pulley Installed - Belt looks off by a 1mm
  249. clutch and clutch plate
  250. MINI code reader
