View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. tires rolling
  2. Oil in coolant problem
  3. AIRBAG LIGHT WENT ON FOR 3 MINUTES
  4. Sunroof problem closing
  5. Seat heater woes
  6. Brake Booster...possible issues.
  7. Freak'n Window
  8. Help! Window! :)
  9. JCW Carbon Fiber question
  10. Dome Lights Burned Out
  11. Is this a big problem?
  12. cooling fan
  13. cooling fan
  14. Strut mount mushrooming, no big deal?
  15. Any idea what would cause this? BC1?
  16. Is it a Broken Engine Mount? (picture included)
  17. Dealer Programming Options--takes a whole day???
  18. Wiper issues - help neede
  19. Service Engine Soon Code P0456
  20. Boot/Bonnet Warning Light
  21. Anyone Encountered This? Motor sound after engine start or shut off?
  22. Front Bushing Failure...
  23. Flywheel problem - still not fixed!
  24. Fuel Guage not registering level
  25. tinted window noise fix
  26. help - advice on manual transmission problem
  27. Wierd pump/motor/something sound when car is off
  28. Rear electric hatch problems - moisture related
  29. multiple codes on cyl 3
  30. Xenon lamps flicker when I go over bumps
  31. Misfiring
  32. Rain Sensor Install?
  33. Ruined my SUPERCHARGER!!
  34. Change hood release cables
  35. Wanted: Mini (not S) with bad engine or CVT
  36. Are we Flat Tappet engines on the S
  37. Headlamp problem
  38. Strange Electronic Problems
  39. HELP! Need new MCS engine. Can anyone help?
  40. 04' MCS w/nav. and no temp. guage?
  41. Strange Engine Issues
  42. Boot Leaking
  43. Wheel Noise Problem
  44. where can we access TSBs now?
  45. Strange new vibration
  46. door trouble on my '03 MC
  47. Annoying squeak
  48. BC1 part number?
  49. Anybody with 15% pulley have tensioner replaced
  50. Engine Issue 2003 MINI
  51. windows leak...
  52. Knocking noise coming from... the dash?!
  53. MINI problems - HELP please
  54. Even MINI techs have trouble with this one
  55. Chrome mirror caps question...
  56. Bad high speed wobble
  57. Separate rear windshield fluid pump?
  58. My engine stumbled a bit while parked... anyone know if this is something serious?
  59. Parking Light Lense
  60. OEM Clutch Question
  61. What to add to 2002 mini s?
  62. Help: Replacement Windshield – Wind Noise
  63. wipers are crap!!
  64. Power steering fluid leaking from reservoir
  65. Cheap plastic parts!
  66. cold weather shifting
  67. check light
  68. Mushrooming: Oh no, not another thread!
  69. CVT Fluid Change
  70. THE worst loose wire of all!!!
  71. Seat belt is stuck on the seat raising/lowering lever and will not release
  72. Rattling anyone?
  73. Driving Light Housing
  74. Buzz sound over left shoulder?
  75. tranny fluid
  76. Check Engine Light help
  77. best shop manual?
  78. Idle engine issues
  79. Documenting Wiper Motor Problems
  80. Back-up alarm problems?
  81. Do I need a new belt tensioner?
  82. Studder at a stop...
  83. hood wont pop
  84. Suction vs Draining Oil
  85. 92 octane
  86. This is weird
  87. shrill noise when starting in under 10 degree weather?
  88. Transmission help - out of warranty, bad bearing, replace the whole box?
  89. iPod Nano Weirdness
  90. wheel bolt torque?
  91. Top side oil changer
  92. Damn! Had a bent shift fork in my transmission!
  93. Funky sound from right rear...
  94. Low Fuel Problem - Nav Related?
  95. Replacing transmission
  96. HELP!!! Horrible Shudder in 1st and 2nd
  97. Occasional Driver's Door Lock Problem
  98. Engine Coolant
  99. Routine Maintenance
  100. MCSa Engine Tuning?
  101. Under Dash Facia
  102. Skidplate Hardware Help
  103. show of hands....
  104. brake question
  105. Manifold Pressure Sensor failure -Filter oil contamination?
  106. OK....so let's rehash this whole NGK plug thing again.
  107. drain plug specs
  108. magnetic drain plug
  109. Oil or Water Temp?
  110. Is there anyone out there who HAS NOT had MC/MCS problems?
  111. now no speedo!?...service in Roch, NY?...
  112. Cheapest place to purchase power steering pump?
  113. Can or Has anyone run E-85 in their Mini???
  114. extended maint. upgrade program
  115. Pela Oil Extractor
  116. Concerned about window regulators during icey conditions?
  117. my hatch will not open !!
  118. Shavings in gear oil
  119. I Need Help With This One - Check Filler Cap
  120. Dings and lifting of door sill Cooper S plate
  121. Cold weather performance?
  122. what am i doing wrong?
  123. Need quick answer
  124. Optima Red Cap for the MC?
  125. Harbor Freight OBD 2 tool for $49.95
  126. Foil bonnet insulation?
  127. OBD 2 Code P0442
  128. Squeeeeeeeeek !
  129. missing fuse...
  130. festival of lights.....and more!
  131. Battey Change
  132. Warranty vs Modifications
  133. Glove box door fix??
  134. oil got black really fast...
  135. Emailed and Heard From John Cooper Works in the UK
  136. Battery Problems
  137. Good independent auto shops in NJ?
  138. CVT Belt replacment
  139. Oil in Intercooler Normal?
  140. Tomioka Racing Super Slopes
  141. Manual transmission question, 06 MCS
  142. adding JCW or Helix injectors, is anything done to the ECU?
  143. Follow up to clutch/transmission problems
  144. AC and CC error codes on automatic climate control unit
  145. Oil Change Frequency Poll
  146. Cleaning under the hood
  147. Help. Clicking Noise!
  148. If I lower my window it gets dirty !
  149. Window motors: Has anyone replaced themselves?
  150. Weird noise when I release the clutch and accelerate
  151. Steering wheel click?
  152. cost of spark plug change at dealer
  153. CVT stalling?
  154. Knocking whenever I press the gas.
  155. bonnet / boot open alarm
  156. Fuel Tank Vent Valve
  157. Engine Sludge?
  158. HELP! 3rd Gear 5,000+ Noise from back.
  159. Caution! MEAN MINI!!!
  160. Resetting the ECU
  161. Oil - to change or not to change? That is the question.
  162. New K&N Air Filter
  163. oil drain plug - must be replaced?
  164. Dinan software anyone had/ have issues?
  165. Milky oil in coolant bottle!
  166. Battery Replacement Campaign-Cooper?
  167. JCW kit. Removed Parts Ownership. Aussie Newbie
  168. MCSa Not shifting smoothly....
  169. Fuel gauge busted
  170. Clutch & Flywheel
  171. Battery/Electrical Issue
  172. Warranty Question
  173. best spot for stands
  174. post storage start up procedure?
  175. Upgraded to 15% pulley - who's been reliable and who has had problems.
  176. What is this?
  177. Remove Alta crank pulley?
  178. Misfiring and other problems - bypass valve?
  179. Factory Paint Or Bonnet In Color
  180. buy stock parts online?
  181. mustang question
  182. Front Speakers going out
  183. Seat recline not working
  184. strange beep when accelerating from stop
  185. Wet_Clutch
  186. Need Help!! Stripped Oil Filter Bolt :(
  187. Why did my temperature read out flash?
  188. Delayed Engine Response
  189. Service Engine Soon Light
  190. Arg Help! Alta s/c pulley removal!
  191. Help I Can't Get Out of My Car
  192. Problems with Service at South Bay Mini (sorry, long rant)
  193. Is this mushrooming?
  194. Service in DC?
  195. If you want to know if DSC is a good idea... Let's look at some data!
  196. New Transmission Already?
  197. Inspection expectation?
  198. Which 380CC injectors to buy?
  199. Oil Change
  200. Experience adjusting the MINI's doors?
  201. '02S-Brief power cut-out
  202. disengaging auto locks
  203. #1 Piston no compression, why??
  204. Radiator fan won't turn-off
  205. Clutch replacement pricing
  206. Where to buy Redline oil???
  207. Died while on highway
  208. Ethanol
  209. Rebuilt Electric Power Steering Pumps
  210. Oil Change Indicator lying? MINI refusing to perform an in waranty oil change
  211. Knocking/clattering at idle only...
  212. Heated Passenger Seat Issue
  213. Driver door won't open!!!
  214. Windshield Wiper help
  215. 2003 Cooper S rear washer fault.
  216. Timing Chain..?
  217. Is the '07 CVT w/Steptronic Mode improved over '06, '05 and '04 versions?
  218. Looking for Rhino Ramps?
  219. injector failure?
  220. Right plug torque?
  221. Arizona MINI's - Using GC 0w30 year round?
  222. I opened a can of worms...
  223. Please Help!!! Valve Cover Grenade!!!
  224. bent strut
  225. Harmonic balancer
  226. Disabling Security Motion Alarm
  227. Dealer service - Great to POOR overnight
  228. Exhaust Leak
  229. Strange power cut at the track this weekend
  230. Elctrical coincidence?
  231. front end noise
  232. Rough idle
  233. Random Instrument Failure
  234. Wing mirror disassembly
  235. MINI logo on key
  236. 22K "first" service visit
  237. Pics of my Cold Air Intake Install!!
  238. Changing Airfilter
  239. Red Top Optima Install.
  240. Clutch/tranny/???
  241. Is MINI's radiator design different?
  242. Front Wheel Noise
  243. Going in for first service soon, any tips?
  244. Exhaust question
  245. Unidentified noise. Help!
  246. Releasing pulley tensioner without tool
  247. This is ridiculous!!!!!
  248. HELP!!! Idler pulley in southern vermont?
  249. Pully ??
  250. Has anyone had a problem like this?
