- check engine light...
- Bluefin problems
- OBD BMW Code 05
- Persistant problems and more new parts!
- '03 MCS OEM Crank Pulley on '05 MCS?
- SES Light...P0036 code
- How to adjust front bumper?
- Car vibrates w/ AC on??
- fan groaning
- Tire light??
- 03 MCS with 42k miles still under warranty?
- What is the correct power steering fluid to use?
- Replaced water pump o-rings, still leaking antifreeze
- EML SES LIGHT HELP!
- Noisy Air Box
- Does this part belong to a MINI?
- Hot Air
- thinking about changing spark plugs.... recommendations
- Click/Tick sound upon acceleration
- CVT Fluid Change
- Rims, etc. (and my shrinking bank account)
- Power steering fan engine cooling fan help
- Paint Job Question and Pics
- Replace clutch at 12,500 miles??
- Air Bag light stays on
- a mouse noise???
- Broken Dipstick on MCS JCW
- Starter killed by dead clutch? Is the dealer lying to me?
- Rattle in my cabrio!
- New Guy Has Questions . . .
- !st Gen Airbag problems...
- Sunroof problem - loud cracking sound
- Motor mount leaking
- Seven Months, Three Breakdowns
- Fog Lamps not working
- HID headlight help
- Garage Lift?
- Replacement battery options for MCS...
- Can the dealer re program cvt full-throttle shift points?
- Water leak from rearview mirror!
- starting issue - troubleshooting hints
- How to diagnose a bent axle?
- Clutch/shifting problem
- How to recharge MINI A/C? (instructions?)
- Best place to order OEM brake pads?
- re-emerging RUST
- '06 R53: What's causing the howling noise?
- Regular Scheduled Maintenance
- Oil pan 2003 MCS
- Clicking at low speeds
- Environmental air filter
- Air Conditioner Compressor vs. Mods - Dealer Warranty Issue
- Engine Leaking Oil !!!
- The EML Light keeps appearing?
- MINI logo on steering wheel peeling off
- Manually raise window
- Strange (but very fun) problem...
- Programming key for keyless
- Burns on air filter
- Intermittant AUX port failure- anyone else?
- '04 MCS with extended warranty. Opinions Please.
- So who's the wise guy that turned out the lights???
- Stranded! Blown Clutch?
- Automatic tranny on my 2005 MCsa has self-destroyed twice in three months
- Can I reset the SES light?
- How to get rid of this stuff on the exhaust?
- squeaking brakes
- Squeaky wheel!
- Cooling Fan Running
- Need Help - Please Read :) (Air conditioning causing EML Light?)
- Troubleshoot: Supercharger
- Power Steering Fan??
- Cooling Fan
- Car won't move... clutch issue?
- Is the fuel pump audible?
- Air conditioner/overheating Help!
- Clutch question - do-it-yourself replacement job?
- power steering fan ducting
- Bootlid stuck
- ticking/tapping under bonnet
- Help! Clutch and gearbox problem!
- Help, able to hand tighten oil filter canister yet
- Oil Filter canister ?
- Front end vibration/shimmy
- Oil Filters
- power steering loss help
- O2 sensor dead at 26k?
- Several clutch questions / possible issue
- Problem with my CVT transmision 2003 mini non-s
- Random/sporadic problems
- Wrong Forum
- Creaking dashboard
- window spray not working
- Is it the power steering pump?
- need help removing rear brake caliper
- SES light & other service issues - is it just me?
- Door lock problems
- Clutch Question
- New Clutch gone bad?
- Engine Starter Saga
- DSC, ABS, Tire Pressure Warning
- Heads up: Oil Leakage and Worn Control Arm Bushings
- Headlight washer bezel broke
- Rear Brake Friction
- '03 MCS Clutch
- corroding gas cap
- Help! Mice Damage
- Brecht MINI service left a bad taste in my mouth...
- electrical gremlin?
- door locks
- Is it from the A/C ??
- I don't know if this qualifies...
- Drivers side window squeal
- Trying to rule out a vibration
- clutch gear prob
- Rear brake pad clicking & loose
- MINI MAJOR DISSAPOINTMENT!
- i busted the tweeters...
- radio problems...
- Engine Problem
- Quick Tire Question
- Cooling system- white milky fluid?!
- Xenon Headlamp Issue
- Service engine soon P0031
- HELP car won't start
- Code P1476 ??
- Oil Filter is a PITA!!
- What brand coolant ?
- Odd problem with lights any ideas?
- Is my Oil Pan missing screws?
- Car Not Starting!
- Problem with washer fluid reservoir?
- !!!2004 ENGINE BLEW UP WARNING!!!
- Recall list
- PROBLEMS: Plz Help
- Pulling small trailer (900lbs)
- key cost
- Lights not flashing when I remotely lock the doors
- Schedule Maint List
- Can't get the expantion tank cap off!
- Recommended MINI Mechanics - Nashville?
- Oil Pressure light comes on
- Key Memory - not as described in manual... or the next manual
- Replace Bowden Cable
- O4 CVT-minor and major problems-Input?
- Brake Dust... how long?
- Broken Hood Scoop
- Vibration when travelling from 2k to 3k RPM
- Need "How to" instructions for PS pump replacement
- Help - my brake lights won't turn off
- Stalling Out while Braking
- rear exhaust issues?
- evidence of mushrooming?????
- The clock lights up but doesn't display any numbers
- Both Keyless remotes don't work! Rain?
- Question for MINI techs
- P0172 (Too Rich Bank 1) Troubleshooting Help Sought
- Anything made to replace oil-filled engine damper?
- 60K What needs replacing?
- Bushing Dilemna
- Engine Cooling Fan is Cycling
- Recommended mechanics Philly area?
- Speaker problem
- Problems with A/C. anyone else?
- Louder Exhaust Noise: Failed Muffler/Cat?
- My MCS is leaking!
- A Click everytime I accelerate or slow?
- bad oil leak help
- clutch, brakes and fair price 2002 coopers
- Motor Mount removal and replacement
- double post
- TB/BPV housing rusting
- Does this sound like I need a new clutch?
- 27k miles and feeling age
- What kinds of problems do Minis have after 100K?
- Oil plan plug stripped!!!
- Overheating problems '03
- Need Double-Pull Disable Instructions
- Stuck Brake-> Heat + Smell! Help!
- A couple of problems
- anyone know how to reset onboard comp
- idle question
- Rear/Tail Lamp Problem. Please help!
- Posi-drive NOT Phillips
- repairing runflat tires
- Oil drain plug
- testing tire pressure monitor
- 06 MCS shakes/rumbles with loud noise coming from engine?
- bypass valve was stuck - any unseen damage?
- Battery light and PS pump problem
- Car locked itself while running
- P0108 Code - definitive causes?
- Crankshaft or Idler pulley problems?
- The Burning Smell
- 06 Cooper 5 Spd Whines at Maintained Acceleration
- Xenon Headlamps for 2005-2006
- Winding Sound
- Odd sound even with engine off (but power on)
- 2007 MCSC Not Starting....
- Oil filter housing stuck ON - can't change filter
- Radio won't turn off!
- Clutch Problem
- Water intake problem
- Brake pad warning light
- Radiator Fan issues turns on after car is off.
- Rattling/Grinding noise at 40 MPH
- Questions About Stuff
- Hey guys Possible P/S and Engine Rattle..
- window auto down
- Bad fuel pump?
- Help! Can't open door
- Reverse switch installation help
- Creaking sound from rear wheels
- Navigation stopped talking
- steering wheel tilt not locking
- "Check Filler cap" light comes on!
- Oil leak
- Overheat
- "cricket" squeak from right rear
- Electric Window Problem?
- BMW mechanic with a mini problem relating to steering angle sensor
- MCSa Tranny Q
- Missing anything?
- Limp Home mode and SES light @ 5K RPMs
- Power Steering issue...different than most
- 06 with a cracked windshield - what do I do now?
- Uh-oh. Oil spots on the driveway.
- No A/C, HVAC flap stuck?
- What is this code and what does it mean?
- Anyone bringing a scan tool to the Dragon?
- Odd (gurgle) sound at higher rpm's
- Transmission Fluid Change?
- Nearing 36k miles - should I purchase and extended warranty?
- service egine light, summer blend gas maybe??
- Used car blues
- MCS - Front Squeaks When Turning Wheel
- Hatch goes "Boonk" - all by itself! (FIXED!)
- piece of gravel in pulley track
- clock problem
- MINI OBD II Scanner
- Creaking/crunching noise from right rear
- Voltage ?
- Shift cable broke
- problems with oxygen sensors!
- 2003 Mini Sport advice needed
- New door = airbag light on
- "Serve Engine Soon" went on!?!?!?
- No Heat after Dash Work????
- oil cooler leak (major)
