- Shouldn't an oil change be easy?
- Battery/Electrical problems
- Synthetic Oil required?
- Service Engine Soon light inquiry.
- Rear screen wash leak causes mega damage
- clutch noise when downshifting
- Is this guy a Service Indicator Nazi???
- Sueaky Steering
- Leaking oil
- Shock / Springs?
- Questions about tire rotation and other issues.
- Replacing a thermostat
- knocking sound on deceleration?
- Lousy MPG on my 06 MCSa
- Brake pads
- Thermostat housing/coolant reservoir
- Out of gas!!!???
- How to break in to a glove box
- anyone know how to troubleshoot the obd code p0444--evaporative emission system???
- Passenger Seat - Failure to Slide Fwd
- Fluid Leak?
- 2006 Mini Cooper. brake squealing noises. NORMAL??!
- anyone know how to change the brakes??
- Random power loss at WOT and engine shutdown - Cooper S
- Car not starting, 3 DTC Codes...
- Battery charging question
- To all with automatic Cooper S
- Parking Lights Wont Turn Off
- 06 MINI Cooper S & dead battery
- passenger door doesnt open from inside
- Plastic cover in rear wheel wells
- strange popping feeling when steering left
- Flooded battery box
- Have I made a mistake?
- Blue light oily fluid?
- Strange intermitent noises 05 MCS
- cooling fan problems
- Engine cylinder 4 misfire
- Xenon Headlight Failure
- cooling fan problem?
- is it possible to change the gearbox ...
- New Transmission : (
- Broken Lock
- Serpentine Belt Change
- Clutch engagement point
- What have I done??!!!
- Vibration noise from cold 1st gear starts from stop
- peculiar coolant/radiator issue
- Flywheel/clutch problem??
- Save money in Maryland
- sounds like exhaust has come apart from headers...
- Backfiring on cold start
- no brake lights ??
- Stock Driving Lights
- warranty cancelled
- Low RPM clatter, high RPM rattle. Something is loose?
- Brake fluid sensor wire
- Radiator pressure test ?
- ABS, Flat Tire Indicator, and DSC light on and won't go away
- Stumbling on acceleration (2004 MCS)
- reverse light drama
- Shredded belt, bad tensioner.
- Starting issues in 2004 cooper S - HELP!!
- Information on replacing the antenna housing.
- Help Need help, 04 Cooper S Howling noise
- Warranty…
- won't Start...
- SES Codes through On Board Computer
- Pot Hole Problem
- Some Weird Smell
- Floppy Accelerator Pedal
- Driver Side Window not going down when door opens/closes
- Headlight not working, Are these good?
- Mushrooming
- Passenger seatbelt warning light w/groceries
- Power steering pump is running constantly.
- JCW strut bar bent
- Replace Heated Mirror
- Where to buy an Oil Filter Housing
- Glove box rattle/removal
- Remote programming procedure question
- A/C Smoke
- Loose suspension / steering
- EML, Check Engine Light - looks like a Christmas tree in here!
- mysterious key problem
- EML on after GP Intercooler Install
- lights on???
- Our Possessed MINI Cooper
- New Transmission
- Power steering fan and split harness fix
- Antenna broken off
- SES and DSC lights on
- Quesiton about a few problems
- RECALLS?
- Rear brake caliper piston seal is torn
- passenger side motor mount
- Some Brake Service Questions
- Steering wheel/column "thump"
- Normal wear and tear ?
- Driver's Door Problem
- Alignment Issue
- Rear Spoiler Removal MCS
- Inside mirror day/night don't line up?
- Paint peeling from around front turn signals?
- werid front end noise/my cause
- Is it possible to fix a loose Glove Box latch?
- One brake light always on
- Sheared off a rear hanger muffler bolt
- HELP!! Can't Finish Oil Change & Can't Drive Car
- Outside Temperature Gauge Off
- installing when clutch down
- Problem with brake pedal
- Steering Noise when car is off
- Sunroof Not Working!
- Getting at the starter motor
- Any longer term solution for knocking steering? Please help, almost out of warranty
- Ripped Off !!
- Radio being fussy
- Fuel Gauge Problem
- P0108 code Overboost "I Found the problem"
- Clutch pedal...
- Speed Sensor Problem
- Front wheel bearing/hub replacement
- Brake Job
- Headlight will not shut off
- Clutch problem: vibration/whirring when pedal is depressed?
- engine fan keeps blowing fuse
- Starting issue
- Intermittant Air Conditioning?
- idling at 1100-1200
- Weird sound from steering column
- Is this normal?
- annoying engine noise inside the car
- High pitch noise coming from the engine bay
- 06 Cooper 6 months old - transmission needs to be replaced
- Grill Stolen; how do I put new one on?
- At 105,000 miles, 3 windshields...
- Transmission Problem
- Wasp nest on my intercooler
- Anyone ever run out of gas?
- Check Engine & Gas Mileage
- Auto A/C question
- Strange Noise
- EML, DSC, SES !
- Warranty Coverage
- Climate control illumination woes
- Connecting Rod Torque Specs
- TPMS light keeps coming on
- Sunroof Grease
- My fuel pump won't shut off!!
- Strong smell of toasting circuit board
- Engine clicking under acceleration?
- My cracked strut mount
- Error Code... can anyone decipher for me?
- Yellow warning light related to exhaust
- 2002 Cooper, roughness/vibration on low rpm accel.
- failed / leaking motor mount??
- Cleaner Reflector HID Beam?
- Where do I go?
- Service Engine Soon - p0326
- "Service Engine Soon" Light Comes On ; Might Have the Solution
- Thread for all KNOWN stock issues?
- 05 Auto Tranny Issues... Again!
- Verryyy weird help
- Seat back wont adjust
- 02 Sensors on ebay
- Driver-Side Lock/Unlock
- ALIGNMENT... MINI PULLS, NORMAL?
- CV joints not covered under waranty?
- Electrical issues?
- Driver-side Window -- No Worky
- Oil Change Problem
- first problem - wipers
- Door Lock/Unlock Issues
- when to change O2 sensor
- Seat and Steering Wheel
- Clutch Replacement (pic)
- Central Light Cluster?
- How do you change the bulbs in the side reflectors?
- New (to me) MINI! Rubbing issues...?
- car overheats!!
- MINI not designed to take higher speeds... (pic)
- 2002 Cooper manual transmission failure
- how to reset service warning
- New problems
- My driver's seat is alive!!!
- Are all MINI/BMW batteries crap?
- Electrical/charging issue
- Engine Stopping in slow traffic, But restarts fine
- Junky STOCK Bonnet stripes
- Rod Bearing's
- White Rims.
- MINI S questions
- Hoping this is a fluke and not CVT issues
- A/C RAN OUT
- Tire Pressure/ABS/ASC Alarm
- Clutch noise - pop and power lock nonsense
- MINI Throws a code -
- Decel Issue
- Automatic gearbox issues
- ABS LIGHT, RED BRAKE LIGHT AND DSC LIGHT ALL ON
- Engine shuts off!!!
- Engine Suspension Replacement
- Cruise Control Issue
- how to replace upper engine mount
- A/C - no cold air
- My first issue with the MINI when "Cruising" on highway...
- electrical drop = dead MINI
- Clacking/Knocking in Rear
- 2002 MINI Cooper S power steering pump
- need help
- I'm Done! GOOD BYE!
- CONSTANTLY getting SES P0456
- Reverse Light Wont Work
- Oil reset and SES light reset
- Squeaking noise in 03 MC, had the brakes checked and they are OK
- Front Seat Removal
- Brake and DSC Light
- 3 lights on
- Wierd problem.
- Repairing broken door lock yourself
- AC died then alive!
- Cruise control failure
- crooked exhaust?
- Rear Wiper Washer Problem
- Where can I buy Glove Compartment
- Power Steering Questions
- who rebuilds mini's rack+pinion steering
- Several problems with my 03 Mini
- Help! flat tire
- MAP Sensor Code P032?
- Clutch covered under warrenty?
- NYS Thruway +1 Mini 0
- P1125 and P0638 error codes
- '02 MCS EML light issue
- QUESTION FOR VETERAN MINI DRIVERS
- CVT intermittantly weak in reverse...?
- The how do you describe this sound/ is this normal thread
- Wanderlust or how many quirks till you fall out of love
- How do you know when your clutch is going out?
- Brake Lights Remaining On
- transmission/clutch problems/questions
- Dead '05 MINI Cooper S
- My car is possessed! No really, serious problems..
- Inserting key in ignition unlocks passenger door
- 60k service coundown reset
- Passenger window won't go down??
- difference in sound between broken pump/fan?
- won't start
- Popping Noise?
