- Brake question
- Reverse
- Door locks not unlocking with remote any more
- Any more detailed steps to replacing alternator?
- Please help p0301 and p0313
- Window adjusting, how to:??
- Windshield Wiper Problem
- Seat Height Lever/Arm help.
- '04 Clutch rattle
- Oil Change Interval
- Help to adjust windows on an 05
- awful groaning from rear of my mini
- Handling problems
- loud interior noise help
- Front end parts diagram?
- electrical issues with interior accessories
- Airbag light on & transmission leak
- Help with a decision about troubled new mini
- Overheating leading to master cylinder failure?
- Surely I'm not the only one who hates our oil filters
- Weird feeling clutch pedal
- Could these issues be due to a bad wiring harness? Can I trade in with these issues?
- Where to start...
- Vacuum Hose Identification!! HELP!!!
- Need help with overheating/thermostat
- Power steering issues - please help!
- tire pressure monitor
- oil filter location
- Buying a 2003 MINI Cooper S - need feedback
- Anyone know where to add freon?
- heat on; car overheats, heat off all ok
- Serp belt?
- oil around valve cover
- CVT experiences. good or bad?
- Chewie in My Clutch: Diagnosis und Fix
- Fuel system cleaning?
- One problem to the next
- Mechanic? - Palm Springs/Palm Desert
- GPS software..?
- Pressure Under Valve Cover!?!
- Power Steering Fan?
- Transmission/Clutch Problem??? Only 12K miles...Any thoughts?
- MINI Cooper steering issue
- Heater core is Wasted!!!
- 2006 Cooper S - Leaking clear watery oily Fluid engine area
- service question
- Sunroof NOT closing in high sppeds, but closes when i slow down..Any Idea?
- Need Help - P1685 code
- HID headlight problems
- Passenger Door Only Unlocks Manually
- Clutch Replacement
- A different seat heater problem
- dropped bolt
- What brand is the original rims ?
- Need help finding stupid rubber part!!!
- 4 gear - high rev - feel like should shift quickly to 5th gear
- Odd center gauge speedo buzzing and twitching
- Belt Tensioner Tool
- AT cooper wont start
- SES light - dealer has to ?
- Help, my 04 Cooper S sounds like a Diesel!
- burning rubber smell
- Sunroof rattle #236
- Seat Heater
- License Plate Lights Staying On
- Knock Knock. Who's there? Something in your right front wheel!
- Troule-shooting rear washer?
- Power steering problem!!
- Resetting maintenance interval
- weird noise in 1st gear
- MCS Complant Dept.
- Dome Light Question
- dealer software updates?
- Rotor Drag - Need Suggestions!!!!
- AC Compressor not running
- Devastating MPG in Cold Weather! Help please!
- doors won't lock... Help!
- DSC and tire pressure indicator problem
- Checking on the charger
- my belt tore twice in 2 days: need help!
- High-pitch noise when turn?
- help...leak at cv shaft
- Wrong napa filter installed... 7103
- Heater issues
- Troubleshooting low MPG - what are likely culprits?
- 2006 MCS Issues "car not going to sleep?"
- Yellow Engine Light - Full engine power no longer available
- anyone change their own oil?
- Front Seat.. pull forward?
- great idea on a nodder
- glass
- Passenger side xenon problem
- Spark Plug blown out of head - need information
- Help needed!!! Recurring Problem
- wiper blades
- Tire pressure indicator
- Help! Fast! Engine too cold to start?
- First time in Limp mode
- Hood / Boot open warning, possible fix
- can not start the car need help
- *what* did i do? car won't start.
- Please help!!
- Fuel Additive
- Glove box question!!!!
- Clutch or flywheel noise.
- Clutch squeal sollution
- Strange Electrical Problem.
- Question for a friend with a CVT!
- eBrake Handle
- Help: 30K mile Inspection - Checklist
- Sounds like I turn the key twice....
- about brakes
- Tire pressure light
- Car won't start... it's not the battery
- Maintenance Suggestions Please!
- Frozen battery and an inability to open boot.
- question about limited slip
- CEL P0036 - HELP!!!!
- Are the shifter cables adjustable??
- 15K Service???
- 2003 won't start? Dealer says it's fine????
- Red Oil Light
- ,,...Seeking book review...
- Brake click and unknown squeek
- Doors unlock but don't lock with fob/switch
- Can water get into the 5-speed transmissions?
- Reverse light
- Passenger window
- Clutch Groan?
- Remote Key Problems
- EVERYONE PLEASE READ....04 Mini...TRAGIC 48+warranty repairs!!! PLEASE HELP US
- Shifter stuck
- Trans/Motor Mount, or?????
- A noise question
- 2006 JCW Air Filter Housing
- Passenger Seat Release
- hard start:hot
- MINI balks on warranty, what's the next course of action? court?
- Windshield wiper deflector
- Strange noise when first move my MINI every morning
- Door unlock at highway speed
- Engine knock
- HELP!!! Need Expert Diagnosis! OVERHEATING!!!
- Cabrio: Windows staying up when top put down
- Transmission: Rebuild or remanufactured?
- 2 problems already :(
- Replacing rear wheel bearing?
- 06 mcs sunroof clicking
- Two Problems Already :(
- 06 MCS stalling problem
- engine noise or me being paranoid....
- Where can I order factory parts online for my 2005 MCS?
- Heated mirrors??!!??
- Drivers side mirror popped off, can't get it re-attached?
- Is this part failing?
- Help Please - Engine Stalls / SES and DSC Light
- My car is bleeding
- Advice: Windshield Trim
- Bucking Throttle vs. Cruise Control?
- HELP! I have an electrical gremlin!
- SES light came on....
- Noise!
- 3 weeks w/o my MINI now a new Transmission?
- My car won't let me out...
- Battery Cable problem
- Car shaking when starting/stopping engine
- In for service at Northwest Mini...
- Help!
- Sticky Squeaky Clutch at 32K
- Dash/Instrument Lights
- i need new brake pads
- Lubro Moly Engine Revitalization Kit
- Where can I buy directional bulbs?
- First Posting - window problems
- Turn signal issue...Yes I did a search
- Hard Shifting When Cold
- got some probs
- Window issue
- replacing a keyblade...how-to...
- Xenon light weirdness
- Leaky boot
- Reduced Engine Power???
- Weak heater
- Question to DIY: Draining the Radiator?
- Oil Change Nightmare... Buyer Beware...
- Wierd issue...sticker
- Failed SC Gears! = Overheat + Reasons to upgrade!
- Engine wants to die whenever I turn quickly??
- Hissing noise
- SAVE THE BOOT!
- Reverse Stalls... Am I Crazy or Just Driving a CVT?
- Weird interior light issues...NE1 have this?
- Vacuum leak in pedal cluster area?
- Cold starting/stalling
- Steering Wheel Badge Replacement?
- transmission 03/ independent mechanic
- Acceleration question, 02 MCS
- Flat tire and DSC won't shut down!
- Rotating tires... drivers side wheels STUCK?
- Question about 6-speed tranny fluid
- What is my Mini trying to tell me ??
- Run Flats or Regular Tires?
- Rear wiper won't run
- New Rotors @ 40K Miles?
- Help - locked gas cover, low gas!!!
- 12000 mile inspection interval question??
- Recognize this piece?
- Can't get into first gear
- looking for transmission plug (countershaft)
- Fuse Trim Removal ???
- Independent shops
- difference between U.S. and Euro transmissions
- Where's the Air Filter on the 02 MC?
- Grinding my way to 2nd gear...
- Newbie MINI Cooper S Owner with a Mystery already
- doors unlocking themselves?
- Cold temp PS pump noise?
- Grinding Noise
- Warranty Work
- THE HARD TO FIND 100amp FUSE! IT IS THERE!
- Help with Fuse Box removal/Power Steering Questions
- Dealer profit: warranty vs. non-warranty?
- Snow Tires - Need 'em?
- Problems...Please help me troubleshoot
- Heres my story of my batt issue, see what y'all think
- 6 speed throws
- HELP! Where do I get internal tranny parts?
- Blown CVT Tranny - Need help!
- fuel guage
- Help Please, Problem When Cold?
- Power steering hose leaks
- Stock Clutch?
- Moisture "steam" coming from Vents
- Fog Light out... Covered???
- Vibration when Accelerating
- Something wrong with my Mini?
- Broken shift linkage
- Am I mushrooming? pics enclosed.
- Where to buy power steering pump?
- Spare tire
- Mushrooming on the right
- Help needed with OBD codes and DSC light
- power steering pump question
- My MINI broke down near San Antonio.
- Crazy Auto Climate Control
- Help! My Mini Won't Start
- Coolant Leaking...but from where?
- Trouble Codes PO302 and PO313
- OEM Charcoal Cabin Filter
- '05 motor mount: Warranty vs self-repair
