View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. What type of Anti-Freeze/Coolant to use?
  2. Rubber Strut mount torn- what Happens if I keep going?
  3. Valve Cover Gasket, Performance?
  4. New Owner, New Problems!
  5. ASC flashing during cruise
  6. Dealer Stumped: Thoughts?
  7. wtfBBQ windshield molding coming OFF!
  8. How difficult is it to change the valve cover gasket?
  9. no dash lights
  10. National Back Order for Bumpers?
  11. fuel cleaner
  12. Replacement of fog light
  13. Ripped off by Prestige!!
  14. Low compression in #4
  15. Window Issues
  16. What's that clicking noise?
  17. Airconditioning Question
  18. AC help? Whirring sound + weak cooling = ?
  19. Evap system leak
  20. grey plastic vaccume line under ic?
  21. is it just tire noise or something worse after rough bump...
  22. Vibration - sounds like rumble strips! 02 MCS
  23. Oil drain plug stuck... help!!
  24. Steering fan - doesn't move
  25. bad kitty?
  26. Airbag Light On - NO Fault Code!
  27. A/C Not cooling
  28. P0301 Code
  29. Power Steering Pump/Fan Issues
  30. Dinan CAI Filter Questions
  31. brake dust dirtying rims
  32. Pentosin CHF 11S
  33. Loaner Cars
  34. TICKING WHEN CAR IS OFF???????
  35. loose interior sunroof trim
  36. Heater stops working at idle, Engine overheating light comes on at idle.
  37. Rear Hatch won't open with lots of stuff stuck inside
  38. Something Fell Off!
  39. HID out!!
  40. Engine is louder inside cabin since Dual Mass Flywheel was replaced
  41. SES Code P0340 & Traction light
  42. I HATE my glovebox! Any fit-it tips?
  43. Official name for wheel well liner?
  44. Low tire light came on an on an on
  45. DEALER JUST REPLACED DUAL MASS FLYWHEEL
  46. I'm assuming this is normal...
  47. Oil Leak
  48. Door Locks won't lock with toggle or key!!
  49. ABS Light/ Tire light
  50. Broken door handle
  51. Warranty inquiry
  52. Car Shuts Off While Idling
  53. Need help from someone who has done KD Backtap or something similar...
  54. 04 cooper hesitates when stomping accelerator.
  55. Felt around the sunroof on exterior
  56. Stupid Instrument Lights!
  57. Don't wait for the Dealership to change the Intake Filter!
  58. Back Up Beep
  59. my horn is dead. where do i begin?
  60. P0105 Fault ??
  61. Check Engine Light and Tire Pressure monitoring
  62. Mini research
  63. blinking A/C light
  64. "Service Engine Soon" Light On -- Reset?
  65. Squeeky rattle noise from front of car
  66. Pulsating power
  67. Wishing for a "Sticky" on CVT's
  68. Fuel pump fuse keeps blowing!
  69. Dashlights Flicker on and off
  70. Need Clutch Help!!!
  71. Manually Lowering Window?
  72. Ticking every 3 seconds from Dashboard area
  73. Cant take off the OEM Exhaust Tips!!
  74. My Car Just Zapped. Requiring help!!! Someone.
  75. Motor mount part #
  76. Throw out bearing ?
  77. Belt tensioner is leaking
  78. Radio (cd) skipping
  79. lower end block for S and non S
  80. 02 MC Electrical Problem
  81. 2004 Base Cooper Spring loaded filter housing
  82. OBDII Software/Cable
  83. ABS Module
  84. MCS Puking foam
  85. Electrical issue
  86. windows freaking
  87. overheating 2002
  88. 3 warning lights???
  89. Right Headlight Brighter Than Left
  90. Coolant Problem- Need Advice
  91. Power Steering Pump Failing?
  92. MPG Questions
  93. parts online
  94. Noise/thumping while De-accelerating
  95. So I'm dragging a cable...
  96. Funky Dash Noise when Changing Temp on Temp Gauge
  97. Instrument Light Problems.
  98. My clutch pressure plate might be broken
  99. Moonroof Issues
  100. Dreadful Smell
  101. Extended Warranty or NOT!
  102. Use of non-MINI coolant
  103. My coolant reservoir appears empty 2005 S
  104. My 2005 S won't shut down normally when I turn off the ignition
  105. Heated Seat wont turn on
  106. No Rust on 2002.......
  107. Sudden surge!?!?!
  108. What's this leak?
  109. Dose not idle. HELP.
  110. Knocking sound on acceleration and braking - NOT motor mount
  111. Oil Pressure? or Sending Unit?
  112. Plug Wire Mix Up
  113. CVT reinitialized? Shuddering when stopping
  114. stock problems/yo yo
  115. Power Steering Went
  116. engine stutters in 1st to 2nd
  117. Crunchy steering
  118. I hate steam
  119. BMW Based extended warranty?
  120. Newbie : What should I lQQk 4
  121. MINI won't start electronics not working
  122. Noise from headers?
  123. MotorMount Issue
  124. A/C loses power, windshield wipers come on by themselves!
  125. Odd noise from the rear
  126. Radiator Troubles
  127. MINI Won't Start
  128. hot air out of dash top side defroster vents?
  129. vibration when accelerating
  130. Stutter on acceleration...
  131. Key for Mini bike rack
  132. Leaking Strut?
  133. Exhaust Flex Joint problem
  134. More spark plugs woes... stripped?
  135. OBC Display with Chrono Pack
  136. any sugestions tires
  137. Spark Plug Popped Out!!!
  138. Windshield Whistling
  139. Clutch Problem, help!
  140. Rubbing noise
  141. Help, airbag light
  142. Finally I Get to Drive My MINI - Thanks Pestige MINI!
  143. '02-'03 issue with spring & check valve in oil pump area?
  144. Clutch Replacement?
  145. Reset Service Oil reminder
  146. front and rear badges
  147. Too lean code
  148. Found a hole burned in the bottom edge of drivers seat back!
  149. Warranty/Maintenance Dealio?
  150. Should we start a SubForum for High Mileage?
  151. whir-whir-whir from 40kph up
  152. Factory Driving Light RUST!
  153. Common issues with an 2003 Cooper
  154. Movement of slave cylinder!
  155. Tapping/Knocking When in Neutral
  156. ABS scan tool
  157. Cig Lighter not working.
  158. Boot buzz after pressing release button...
  159. Burble or Engine Pop?
  160. Bad battery or bad starter motor ?
  161. mini urinating
  162. Great Vacation and then...roadside assistance
  163. Magnetic Oil Drain Plug for MC 2004
  164. Does anyone have an account with ALLDATAdiy.com ?
  165. Replace serpentine belt
  166. Brake Pads...and Rotors, too?
  167. What to do when you're an idiot (Trim Damage)
  168. Oil Change Cost @ Dealer
  169. Speedo buzz then reset
  170. Over Boost Codes. :(
  171. Squeaky/Crackly Arm Rest?
  172. Horrible Day(warranty sucks)
  173. Stumble in 2nd
  174. Wiper knocking over 50mph
  175. Poor Gas mileage 05 MCSa
  176. Cooling Fan Low Speed Specification
  177. Random Noise
  178. Click?
  179. Wiper/Spray Coordination
  180. Passenger Seat Back Will Not Lock Into Upright Position
  181. another weird noise thread
  182. '03 Wiper and Washer stopped working. Any Ideas?
  183. Doors Lock and Lock and Lock
  184. Radiator fan resistor...
  185. Leak Pump Location
  186. Windshield interior
  187. Replacing brake light bulb
  188. Airbag, cruise, radio functions dead
  189. Airbag light comes on when a passenger is in the car
  190. Engine Ticking - '04 MC - Is this Normal?
  191. blocked windshield spray nozzle
  192. MCS Motor Mount
  193. Would someone tell me the sparkplug gap for an '02?
  194. EML, Service Engine Soon, Limp Mode
  195. Stress-Cracked Windshield
  196. No Front Wipers-FIXED!
  197. Hard Shifting with an 05 Cooper S
  198. My MCS Rattles like hell!!!!
  199. Remote Key Problem
  200. Speedo off?
  201. Problem discovered during first oil change
  202. Front Speakers Squealing
  203. Tire Questions???
  204. Chug Chug Dies
  205. Supercharger
  206. a/c compressor not shutting off
  207. Body Control Module
  208. Undocumented dash warning light - what is it?
  209. My bonnet wont open ??
  210. Sluggish Acceleration and Noise from Engine.
  211. Cracked Windshield Replacement
  212. Passenger door lock
  213. Squeaky Steering Wheel/Column
  214. GREASY FILM ON FRONT WHEELS
  215. Weird Sounds....
  216. flapping noise on acceleration???
  217. P1237 Again
  218. Power loss at high rpm
  219. question from a newbie
  220. Bently Scans Requested or Header and Motor Mount replacement
  221. Clutch not engaging after tranny install
  222. Dead window, no warning
  223. Leaking Fluid
  224. lost my wheel lock! now what???
  225. Minimum Rotor Thickness?
  226. Water problem...
  227. Simple Window Position Adjustment
  228. Tire Pressure Monitor
  229. Air Bag Light
  230. Help!!! Seat Belt stuck around wheelchain in cargo area
  231. Help!!! Seat Belt stuck around wheelchain in cargo area
  232. Bad Sulfur Smell... Odd Dealer Experience...
  233. HELP! HELP! HELP! Bentley Manual Scans needed!
  234. Stereo turns on, no sound from any speakers...
  235. Rubbing sound from tires at slow speeds.
  236. window regulator/motor problems...HELP!
  237. Freezing/thawing doors
  238. Bentley Manual Help Needed for Wipers
  239. P1688 On a Non S?
  240. Indirect TPMS not resetting
  241. slow coolant loss
  242. Cold Shifting (Very Cold)
  243. Valve Cover Seal breaking at 40K miles?
  244. Overheating*NEED HELP*
  245. Inside passenger side vanity mirror
  246. steering wheel vibration at high speed
  247. mini service
  248. Dull, brand new, oem, Xenon
  249. Weird Overheating
  250. Newb Service Mileage Question
