- P0172 - Troubleshooting help needed
- Cleaning and polishing the headlight covers
- Power steering pump Fan Ques...
- 2003 MCS burning oil?
- Hesitation in first gear
- Play in rear control arm
- New clutch doesn't feel smooth (R50)
- Coolant leak; what type of coolant do I need, and where to get it?
- Worn T/O bearing?
- Lost the coolant vent screw (Cooper S)
- Boot will not latch
- Replacing hatch hinges
- Intake Boot Clamps
- battery or starter?
- To everyone with a 07 & 08 Cooper S (engine fires)
- Should I replace thermostat?
- '05 R53 won't smog
- Squeak from Front Wheel
- The Old "Service Engine Soon" Light is On
- another power steering problem once again
- Exhaust Noise??
- E Brake problem!
- Everything dead.. Fuse, perhaps?
- Air Con Groan Howl Noise SIM 64 01 10
- '05 R53 transmission died ramdomly?
- HELP! My R52 dies every time it turns!
- Coolant leak issues
- R53 issues
- Steering pulls left and right
- New belt slipping after 2000 miles?
- Dealer does Coolant Flush And Now Airbag Light ... Arrrggh!!!
- Doh! Fender Bender. Need to buy some stuff.
- Stiff shifter, NOT the cables...
- R50 Short Throw shifter issue
- Newbie alignment question
- Help with convertible and battery
- P1125 p0222 p0123 p1229
- where is the axle nut
- Did you replace your r50 belt tensioner yourself?
- What is the secret
- Help Please Analyzing CVT Problem
- 100k maitenance what to do
- Power steering
- warm air AC, no cooling fan,no powersteering pump fan
- overheating!!!! need help
- Quote for clutch replacement on R53
- Heated Seats- Fuse blowing
- Build Sheet
- Wheel speed sensor not throwing fault codes?
- Odd air conditioner problem
- Radio Question
- Power Steering WIRE diagram?
- Build Sheet
- cup holder piece needed
- Parts listings
- R53 Clicking noise during acceleration
- Entire car shakes while Accelerating
- Uneven Headlights?
- Auto trunk lock mechanism 1/2 issue
- Is it normal to get rust on the trunk door over the parking plate? Warranty???
- Not starting
- Flushed brake fluid- what are these codes?
- Engine rattling: The death of my mini :(
- 03 motor mount
- Suspension Question...?
- Supercharger - Most Miles
- Lost spark plug #2
- Shift Linkage Cable Gone Bad?
- PSP Fan quick question?
- '06 MCS, first DSC, followed by SES light - rough idle, what's up?
- R53 Strange clicking noise during acceleration
- Engine rattle
- Engine rattle
- Brake Sensor Problem
- on my second throttle body...
- R53 still won't start...
- Gap in Axle Shaft
- Mysterious electrical gremlins - so far one day only.
- Vibration/grinding after MTF change?
- abs module replacement
- Supercharger Oil Alternatives
- Power Steering Fuse Blown..?
- brake fluid with pressure bleeder
- Power steering pump fix?
- Window Jammed
- Alternator going out 2005 cooper oem or aftermarket replacement
- hit a bump then pulled in royal farms and condensor for a/c wont turn on
- O2 Sensor Fitment Problem
- Fog Lights Not Working
- Random rough idle problem.....
- Clutch slipping....?
- Rust in the floor by the Gas pedal
- Rough Idle/start up issues
- Accident - Rear ended causing electrical issues
- Stripe Removal
- Why going back to stock?
- Window Motor Spins, Cables Solid but Don't Move
- Iridium vs. Platinum4 Spark Plugs
- 03 S died while driving, now will not start
- Frequent but random engine cut off Help!
- Removing Harmonic Balancer
- Wont start - P1688 and P1106
- Overheating while idle, fuses OK, no blockage
- Has anyone noticed noise form top???
- When the repair becomes worse than the problem...
- Amsoil european formula
- Dipstick problems?
- Bolt size for replacement ignition coil?
- Strut part numbers
- Wipers seem to have a mind of their own
- TSB's if car is out of warranty - am I responsible to pay for the repair?
- Strange problem - if A/C is ON it causes battery light, and limp mode after a minute
- Strut tower squeak/grind
- A wild stink appears!
- Another starter problem
- '05 S Key Fob
- Need help deciding on what A/C Compresser
- Crusty Barnacle Rust ?
- Installed OBX Header few codes now
- AC blower motor noise
- Coil Pack check?
- Audio problem!
- Mushrooming - Craven STDs or Mini Madness Reinforcement Plates?
- Can Anyone Tell Me how to Remove Starter?
- Help with identifying mysterious bluish fluid
- Rotating/ clicking noise from tensioner
- Model designations?
- Best Clutch?
- Headlights/fuel and speed and rpm gauge not working
- How to remove a frozen, locked door actuator: A solution!
- Worn rod bearings--need new engine?
- no break wear sensors when replacing brakes...
- Occasional Starting Problem
- Service Engine Soon Light
- airbag light, low volts, no PS at idle, and will not charge
- Passenger Front Window Motor Issues
- Brake/peddle pressure loss
- Stalled, while driving, and overheated!
- Clutch pedal problem
- Check Gas Cap "Light"
- Still Boiling HOT
- Crank damper is making ticking noise, how long will it last?
- Mushroomed towers and crack?
- boost problems
- 2002 mini battery light issues
- Squeal brake, can remove n regrease?
- MCS over heated and smoking! Help!
- Supplier for windshield wiper motor?
- Airbag Light Warranty -- What to do?
- rubber burning
- Blown Midlands
- Sunroof question...is this how it's supposed to work?
- Plastic piece inside oil filter housing...remove or don't remove. I'm confused...
- Tire pressure light reset
- another a/c system question
- harmonic balancer/vibration dampener wobble and noise
- Electrical Jitters - Gauges
- Frame/Suspension knock/Clunk when driving slow over rough roads
- Automatic transmission replacement
- Loss of battery when shut car off !
- New clamp needed for Air filter change?
- Strange noise from my supercharger(video inside)
- Oil Filter O-ring broke - a piece is missing
- SES ABS DSC and Tire reset lights tripped tonight.
- water issue?
- replaced tach gauge face, needle incorrectly pointing
- 2005 MC Convertible would not start
- Key Remote Lock Doesn't Work/Unlock DOES!
- Rear Brake Wear
- The "Usuals"
- Complex Cooling Situation
- 02 Hatch Mechanism
- Missing fuse under the hood??
- Trip computer and redline lights intermittent
- No jump from front battery post
- 02 MCS will not start :(
- Low oil pressure light flickering on and off....
- Aux Driving Lights
- Replaced Exhaust With Stock - My Story
- 3rd heater core in 6 months?
- NAME THAT PLUG, please
- Replacing '02 5 spd trans
- Head Gasket Repair Estimate
- Got in an accident, installing Fog light / turn signal question
- mini cooper s starter wireing help
- Engine failure due to loose frost plug
- video - Squeaky / High-pitched whirring from engine bay
- Help with camber and alignment issues
- Shakey start, engine bogs, exhaust rattle, poor gas mileage
- Power Steering Pump Fuse....
- Engine Oil Light Problem!!!!
- Transmission Range Sensor
- Powerflex Front Control Arm Bushings: New Design or Defective?
- Cracked Head on R53, replace with OEM or performance?
- Engine oil burns too fast
- Clutch/Shift Shimmy
- Clutch Shudder on 2011 MCS
- 6speed trans fluid replacement
- Power steering pump problem
- Serp Belt locking. Thought it was the SC, now not sure. A few questions.
- Motor/Engine Mount (All 3) Replacement
- Tail light question?!
- Help!! My 06 mcs loss power while driving
- pre 12/03 engine mounts on cooper
- Airbag warranty almost up for 2002-2003 MINIs!
- 2005 MCS - Part suggestions?
- How do I remove the passenger axle's intermediate bearing housing?
- Airbag light????
- p0302, oil sprayed in engine, won't turn over
- Just the DSC light is on
- Replaced dead battery, now errors
- MINI R53 DME swap...?
- No Codes; Random EML Light
- Stock Intake Tube Slipping Off
- A/C Compressor Noise
- Braking hard sounds horn
- potential turbo replacement
- Rubber Supercharger Gasket Change Question
- Engine Timing Procedure
- strange sound when taking off
- a/c problem - need help
- Help finding M8 x 100 to use on modular front end!
- License Plate Light Corrosion / please offer advice / Can't find Parts!?
- 2005 MCS automatic transmission HELP!!
- Help with dash removel
- Valve Lifters going out!
- Fog lights in grill not working... Why???
- blown seal?
- Head Gasket Help
- Alternate glovebox latch fix!
- Weird Non-Start Issue
- AC problems, 2002 Cooper...
- Removing Passenger Side CV Shaft Question
- Metal in bell housing area.
- Which is the AC high and low port?
- Do I need a heat shield?
- How long is it OK to drive on a torn CV boot?
- overheating
- Gas gauge reading empty after fuel pump replacement
- Harmonic Balancer blew up.
- Dead battery, no power (possible LoJack power draw issue)
- Help! Stuck in Orland, CA. 450 miles from home
- Mini Service
- Fuel Hose Replacement
- 0% Question
- Error code P2270 & P0137
- Crank Pulley vibrating too much?!?!
- Car is lagging when taking off? Or "jumping". Any ideas?
- Help with coolant leak - water pump?
- oil drain plug problem?
