View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Brake light issue??
  2. MINI Stopped while driving on highway!
  3. 2006 S clutch rattle
  4. Which 02 sensor to replace
  5. 2006 cooper s engine rattle
  6. Oil Pressure Sender?
  7. Bad Noise - Upper Engine
  8. Front Wiper Motor going out. (I think)
  9. Replacing the steering angle sensor???
  10. My dead MINI
  11. Odometer flickering
  12. Front end squeak
  13. mini next will it cover this
  14. Power Steering
  15. Replacing Clutch Hydrolic Lines...Advice?
  16. All Left Side Markers Stuck On
  17. "Misfire Cylinder 3" code...
  18. Running Lean
  19. Tie rod end removal?
  20. Service Warranty...what a joke!
  21. clutch troubles
  22. Boot Sensor bad?
  23. Squishy brakes, failed tech inspection
  24. getting bummed
  25. Measuring Water temp?
  26. no power to wheels!!!!
  27. Diagnostic Scan Tool
  28. 08343 - undocumented code -- HELP
  29. "clunk" and "tunk" from the engine/suspension?
  30. Fuse 37 keeps popping.
  31. Xenon Headlight woes
  32. 2007 Cooper Standard shift "Will NOT Start" Problem solved - Bulliten
  33. I stopped all dash rattles & squeaks!!!
  34. Low tire pressure light
  35. Speedo reads 5-15mph STOPPED!
  36. BMW Technical Information System
  37. Keep or sell?
  38. CVT?
  39. Wheel alignment/wheel balancing issue?
  40. power steering pump location
  41. MCS Fault Code P0704?
  42. Please Help! Problems Related??? Hissing, sputtering and dying!
  43. ABS/DSC/Flat Tire Monitor warning lamps (glitch?) question
  44. P0326 Knock Sensor Questions
  45. check engine light... possibly the PVC valve?
  46. What the heck is this tube??
  47. help nam please r53 wont start
  48. The mysterious "ding"
  49. fan always turnes on after driving
  50. HELP! Need Brake Booster Repair Instructions!
  51. Bunch of lights came on...
  52. 50,000 Mile Tune Up in Orange County
  53. Reverse light burning fuses. help!
  54. Battery Replacement?
  55. busted PDC on convertible
  56. hail damage-roof
  57. Spark Plug Dilemma
  58. Did I get a lemon?
  59. Rear wiper leak
  60. Power steering acting up
  61. Help! Mini is bleeding.
  62. Dashboard top vent - wasting my cold air!
  63. Driver side door won't close !
  64. Top shock mount
  65. Belt tensioner pulley is garbage.
  66. Air conditioning Problem
  67. Is non-mini coolant safe to use?
  68. transmission problems 70K ... is this common?
  69. san diego area mini repairs... know of any?
  70. Alta driving lights and lower radiator???
  71. Issues with 1FastMini... Resolved
  72. Power Steering pump
  73. Good place to purchase Brake Booster?
  74. Noise from engine bay at high speeds?
  75. drivers door lock... problems....
  76. Dash backlighting not working
  77. Oil leaking from motor mount - easy to replace?
  78. EML light
  79. 2nd Gen Mini, but need 1st Gen advice
  80. 03 MCS Cranks but Won't Start After Sitting for a Week
  81. Warranty for $4,076.00!!??!!
  82. How to reprogram remote???
  83. fixed my 02 mini's electrical issue
  84. #1 injector not getting power. NEED HELP ASAP
  85. Removing PS pump
  86. My 2002 MCS just died
  87. what did i break? airbag light stuck on!
  88. New MCS Owner (yesterday) Tranny Blew :(
  89. Vibration in front...
  90. Light trifecta: ABS, DSC, tire pressure
  91. Weird Wiper Behaviour?
  92. HVAC panel, half illuminated
  93. Airy brake pedal?
  94. Separating P.S. fan and Radiator fan circuit
  95. replacing starter on 04 mcs... help asap please!
  96. '05 R50 CVT fluid change questions
  97. How to replace power window relay?
  98. Crankcase Vent Valve
  99. AC or Electrical Problem
  100. 3year,36k
  101. Multiple overheats
  102. clutch release: sticky - slave cylinder at risk?
  103. Tire / Rim SqueeeeeeeK
  104. head gasket blow after repair fan wont work??
  105. Boot not closing
  106. Is the break light mod safe?
  107. relay for starter?
  108. Water on Drivers Floor
  109. Used 2005 MCSC still under warranty for a few months
  110. Anyone have a "How to install an 02 Sensor" on a MC ?
  111. And just as I thought..
  112. Engine Noise A/C?
  113. P/W RELAY REPLACEMENT???
  114. Lost all power at gas station, jumped and now fine
  115. 6000RPMs, Limping, Check Engine, EML, DCS lights.
  116. R53 Power Window Problem
  117. Radiator fan wont shut off! Please HELP!!!
  118. Parking Distance Control (PDC) sensors
  119. Broke my headlight (pics inside). Need part numbers.
  120. How to remove dash or dash pad (rattle fix?)
  121. Air Conditioning Baffle problem
  122. cel
  123. Coolant gurgles at 2000 rpm Please help!
  124. Electrical help needed
  125. Matching interior paint
  126. suspension noise...please help!
  127. car will not start , clutch related problem !
  128. How long can I drive on a busted motor mount?
  129. Headlight, Power Lock and Airbag - Fuses or repair?
  130. No Fault Codes on OBDII??
  131. Overheating
  132. Voltmeter Readings - Bad Alternator?
  133. Fuel System Readiness Monitor "Incomplete" ?
  134. Check Engine Light - Solved!
  135. What is this?
  136. Passenger side window won't work.
  137. Xenons stopped leveling
  138. hood scoop melting after 5k miles...
  139. aftermarket cooling fan assembly
  140. Clutch Slave Cylinder?
  141. So I Demolished A Motor Mount
  142. How to remove rubber boot from spark plug well?
  143. Clanking Noise
  144. Fog Lamp Glass Broken
  145. Flywheel recall
  146. need to buy 05 cabrio glove compartment
  147. Discovered fuel leak when filling
  148. Engine ticking when clutch depressed
  149. Having issues with front lip spoiler/grille
  150. High RPM at cruising speeds - Clutch Problem?
  151. Irvine Mini dealership / South Orange County, CA
  152. Need some Help ID'ing a Part
  153. P1072, system running rich, 2nd time
  154. online RePaIr MaNuAl!!!
  155. Help with left hand drive shaft removal
  156. Good mechanic in Pittsburgh area?
  157. no start, wacky temeperature gage
  158. where to buy a rebuilt brake caliper?
  159. There's a noise and I want to see if anyone has had it before
  160. Power steering pump fan making noise
  161. Strange noise with engine revs
  162. Leatherette cracking already?!
  163. Steering wheel vibrations
  164. AC system blockage?
  165. In a Bind - Lost a Screw
  166. SES Code P2404
  167. E10 code? huh?
  168. Service in East Lansing, MI
  169. DSC light, SES and misfire on cyl #4...
  170. Black Drainage From Exhaust of MCS
  171. Bay area OBDII code reader? Service engine soon light on
  172. Lift-off or launch position!
  173. Positive battery post clamp issues with new Duralast
  174. AC Problem
  175. My AM radio reception stinks!!!
  176. Whistle sound after turning off car
  177. Need help and wiring diagram for pre 2003 engine cooling
  178. Odd buzzing from behind/under the engine
  179. !!-How do you remove a Wiper Relay?
  180. Low Mileage vs. Regular OBC Service
  181. Rear Seat Belt Reels Locked
  182. Driver's Seat stuck forward - 06 MCS
  183. A Starter Success Story
  184. sounds like breaks, stealer said dule-mass flywheel
  185. Help! shift indicator -tachometer -speedometer issue
  186. Shift Indicator - Tachometer - Speedometer issue
  187. help! trunk will not open!
  188. Front suspension overhaul
  189. Drivers door latch dead
  190. Dipstick Photo or diagram
  191. Car is having issues!
  192. Failed Motor Mount?
  193. extended warranty?---parts 4 sale
  194. Rear Caliper seized or is it parking break?
  195. Can Car Wash Rails Change Camber
  196. High pitched whine
  197. Excruciating screech a safety issue
  198. Shock of shocks: Midlands tranny problem
  199. AC is not getting cold and hissing sound
  200. Hi beam indicator light not working
  201. Diagnosing a bad control arm bushing?
  202. New Rotors @ 30K?
  203. Doing 30,000 maintenance myself
  204. Uneven front brake wear (HELP!)
  205. Battery Voltage
  206. noise when starting /smell while running. Help Please!!
  207. Motorized Mirror "Sticks"
  208. Warranty Question
  209. Arghh.. Another thing to worry about. Parts # needed please
  210. Optima Battery Rebate
  211. No cold air from AC
  212. Clicking Brakes!
  213. Car stalls immediately after start.
  214. Help with my brakes
  215. Running the car on dead battery
  216. Best Extended warranty for covering CVT's
  217. Handbrake Boot Tear Problem/Way to Hide and Fix
  218. Radiator, repair or replace
  219. They just towed my MINI - I actually cried
  220. glass washer water tank...
  221. 1-2mm gap between window and weather strip
  222. Another rust issue: Hatch hinges
  223. Dead Car.
  224. Seat ignited on fire
  225. amber warning light on speedo
  226. Left Side Marker Replaced SEVERAL Times!
  227. My transmission is mooing.
  228. Rust On the lower edge of the door
  229. 07 Automatic Transmission Problem
  230. DSC, ABS and BRAKE lights on
  231. Oil filter?
  232. How powersteering system works?
  233. ASC+T Indicator Light staying on
  234. Railroasd tracks-> car died!
  235. Mysterious Window Dipping
  236. 2004 MCS over heating
  237. replacing front parking light
  238. Name This Part
  239. I Love Mini Of Manhattan
  240. Heads-Up On The Carpet Floormats
  241. Door Rust in Rear Hatch
  242. replacing driver's sun visor
  243. Strange Noise from Drivers side Back
  244. Hood alignment
  245. 3 CV Joints in a Month: Larger Issues??
  246. 2003 Navigation
  247. Water coming out of hatchback?
  248. Power Steering pump fan fuse?
  249. Where is the code reader plug?
  250. AC Odor problem
