- No engine oil change for more than 2 years?
- Oil mess around filler cap?
- Throwing Weird Set of Codes
- Rusting white painted wheels?
- Unknown coolant leak
- Speedometer stopped working...
- Factory LSD going bad?
- Another CVT bites the dust
- My car makes a knocking/clunking noise when cold
- A little help with MAF sensor !!!
- Fluid Leak 2005 MC
- problems after new clutch
- Cracked Sunroof Piece?
- Loud diesel sound at idle sometimes not all??
- head gasket problem
- MINI wont start!
- Wheel Speed Sensor Disaster - HELLLP!!!
- 02 MCS SES Light & Rough Idle
- Front Passenger side Knocking/Clunking when car is cold
- Head gasket help after warranty?
- check engine light
- Heater cold air only
- power windows
- Idle Vibration/Coolant Leak...
- Recommended 1rst gen MINI mechanic in Kansas City, MO
- Reassembled Engine - Zero Compression. valve Issue?
- mushy brake pedal
- 02 MCS Battery light on and Power steering doesn't work????
- Steering noises when turning slowly
- Power Steering Fluid from VW Dealer
- Dirty! =)
- Very little heat @ floor
- Center console / armrest problem
- Warranty Direct. Who has used them?
- Overheating problem. Car feels sluggish
- A whining noise after the engine is cut off
- Trip Computer Question
- Electrical issue or just cold weather?
- My MINI needs an exorcism
- Grinding Clutch Gone with a oil change??
- Popping out of 3rd
- A/C
- my temp gauge keeps going up and down
- Vacuum noise when off
- 2nd gear issues :(
- Mysterious Fluid
- Wiper Alignment Adjustment
- Brake problems I think....
- heres a problem that has me stumped
- melted pin in headlight harness, best fix?
- From Cam to Clutch
- Thermostat - OEM vs Wahler?
- '03 MCS JCW SES codes P0107 P0130 P0420 P1688 EML limp mode
- Fixing the Radiator Cooling Fan Problem on 02 MCS
- SES and code 1477
- SES light P0130 and P2096
- POR-15 on MINI rust
- Dimensions for belt tool
- Please recommend good brake pads
- Heated seats not coming on
- R53 Sunroof DOA, It just stopped working. Need Help
- Passanger Headlight Washer Not Working
- What the...
- Washer jets not working-help
- Replacement windshield markings
- Stupid DSC dash light question!
- Noises, any suggestions?
- New fix for broken tabs on MC Air Box
- Missing pinging rough idle
- MINI 5spd Midlands transmission, rebuild or replace?
- radiator fan - Carpartnation
- Front wheel bearings
- OEM SC Bypass Valve Forensic Analysis (pics)
- Pulley Removal Tool...Anyone near Temecula?
- MCSa problem/ big problem?
- Attention: Those with cars that shut off or stall for now reason...
- brake pad corrosion?
- Loose tie-rod ball joint - What to do?
- Fix for P0456?
- Recommended Clutch and Flywheel?
- Speaker not blown - just not screwed in
- Driver's window rattle
- P2404 code '05 MCC
- Sounds from inside the car :@
- New pads + rotors = thunking?
- Small - LEAK, dime size (blue-ish fluid)
- Help with radio shut off!
- Something is not right
- New Trans
- A few electrical questions
- WARNING:: OEM Plate frame causing RUST
- HELP!! Can't find "TMAP Sensor"
- Vibration - Acceleration & Coasting
- Auto Climate Control Help
- A/C pressure sensor switch question.. and other various things
- Worn control arms
- MINI goes boom...
- O2 Sensor Removal
- problems with my 04.....
- Fuel Pump
- Replacement with non-sealed battery?
- So I Tore A CV Boot
- A few areas of concern...
- Clutch Slave Bleeder Screw
- Drive Shaft or Motor Mount
- Noise when taking off
- Oil pan drain plug stripped
- Spark plug popped out - guidelines for driving it (or not)
- Front emblem coming loose
- P2300/P2303
- ASC light plus cam sensor engine light?
- Bent rear control arm?!
- Door Squeak
- 04 MCS with a leaking rack and pinion
- Trouble code?
- MINI Wings on Liftback
- Axle Carrier Bearing SOURCE
- Spring inside glove box latch gone bye-bye
- Coolant temp - bad fan??
- Having Problems Starting
- Random, resettable misfire?
- Dipstick shows nothing!
- Help needed, anyone got OEM airbox non-S/CVT you want to part with?
- ABS cutting in too early?
- My Heater is on high and it won't shut down!!!
- Removing front wiper arms
- Out-of-Warranty Motor Mount Replacement
- Radiator rust?
- Gages and lights going berzerk
- Right hand axle support bearing
- $2000 for "warranty" work? I'm done with Coopers...
- MINI R50 with no OBC will not display temp, engine bogs down
- Changed oil - small amount of oil below car in morning
- Need to replace radiator..what options do I have?
- Gearbox options on 2003 Cooper (R50)
- Trunk Wont Stay Closed! What gives?!
- Power Door Lock Question
- How to replace right inner CV boot?
- Clicking Noise Under Dash, Clutch Relatied
- Brake Replacement 9 months after replacing?
- '02 MCS 6sp Shifter problem
- "Groaning" in low speed turns?
- Boot/trunk sensor
- How to find / determine bad wheel bearing?
- How far can I go after brake pad light comes on?
- Exhaust Flange Bolt
- Stock interior color name?
- Duration of brake rotors
- Buzing from the Dash
- replaced fuel filter - car will not start HELP
- Removing console around ebrake?
- Ray Latulipe
- Need black roof rack caps
- Location of Instrument Cluster Control Module
- Tranny rattling in neutral?
- That little plastic key
- salvage yard s/c or have mine remanufactured
- Possible bad pulley tensioner... video inside
- Replacement Supercharger
- Heater not blowing heat
- Battery condition affecting idle?
- Melted wire bundle - driver side headlight
- What is the maximum capacity for oem fuel injectors
- Replacement Windshield Rattles
- how do I remove the window?
- VERY hot hood near left light-WORRIED. HELP.
- Broken off a strut mount stud
- Alta intake breaks
- changed oil now engine light comes on
- Terrible Story
- Expensive trip home....
- heated seat question
- Weird electronics?
- Sunroof issues
- Broken headlight Clip
- The infamous Airbag Light
- Not as snappy as it once was...
- ELECTRICAL PROBLEM PLZZZ HELP ME!!!!!
- Radio works intermittently
- Knocking!!! Now what?
- Shifter getting harder to shift
- Which 3rd Party Extended Warranty will cover CVT auto trans?
- AC no work =( help!!!
- HELP! Glove box door on my 05 S will not OPEN
- MINI Cooper massive amount of trouble codes
- I need advice, MINI won't start after replacing several things
- Won't shift into 2nd, 4th or 6th
- couple of Q's (coolant & PS fluid)
- code p0130 in 04 MCS
- Heater Core Replacement
- My temp shows in C, not F! Why? How?
- Blowin HKs
- Cross reference parts list
- Can an RSB Install Impact Rear Wheel Alignment?
- 02 oxygen sensor questions
- oil change / Inspection I & II confusion
- HELP! Got a Cooper block?
- Need help for my 2006 base Cooper!!!
- Mushrooming / Strut Mount Warped?
- Oil Leak
- O2 Oxygen Sensor Help please
- Steering is creeking
- Corrosion on #2 ignition coil lead
- Green Fluid Leak
- ECU wire-short, MINI help?
- Sunroof problems
- Muffler hanging bracket rusted and broke!
- Clicking sound from steering
- Electrical gremlin?
- NEED HELP WITH THIS ISSUE PLEASE
- My '06 JCW S continues to get 14.5 MPG after a trip to the dealer. Help!
- Increased engine noise after service
- Problems using factory warranty on used car?
- another door lock problem HELP!
- Abs randomly engaging
- DSC/Tire every time?
- AC compressor clutch sticks...
- Door Closing issue.
- '05 S w/DSC Brake Master Cylinder not available?
- pop sound/backfire in 2nd Gear
- Rust-to-be areas?
- Intermitant Static from Speakers/Radio on but no sound
- how bad the power steering has to be to get an warranty
- I think my power steering pump finally died.
- Xenon question...easy
- Weird stuff going on during start-up
- Anybody try to repair fan housing resistor?
- Problem with aircon and minor problem when starting up the car
- 04 Cooper S ballast question
- Clicking at idle
- Electronic Window Malfunction?
- engine wont acelerate
- Loose Gas Cap P0456
- CD player controls not responding...
- Wheel problem
- Help Please - Reset LEW Procedure?
- Alignment results
- Water in battery compartment
- Boot Bungle Bingo?
- Driver's seat reposition problem
- Need help diagnosing a possible power steering issue
- Strange warning light
- ABS and Battery yellow light on when stopping
- dealer says supercharger bearing? I say idler pulley
- Dead Mini
- Urgent: Low RPM oil pressure again
- Exhaust Diagnosis, Please
- reclining seat syndrom, help!
- Put car in reverse does not move (sporadic)
- Top frame rattle
