- 4 OBD codes, fuse replaced, now misfire?
- Fuel pump madness
- Code 2096 running lean, help diagnose please
- Power Flex Bushings
- temp sender location
- Electrical hell
- A/C acting up
- Source for OE body parts
- What does the DME module do...
- Good place to get replacement parts
- R53 brakes hissing
- MINI battery, dealer and warranty woes!
- A CVT problem?
- A CVT problem?
- Dash de-squeaking / disassembly writeup
- Calling all NAM for help
- Electrical / Start Problem - Please Help!
- Where is my oil going?
- DSC, SES, EML lights on!
- Engine rattle/tapping when hitting 3k RPM
- Steering rack clunk, PS hose leak, dip stick leak!
- Alternator recognition problem
- Foot on gas pedal yet nothing happens...
- Replaced my thermostat
- Misfire symptom and solution
- Who has had to replace their supercharger?
- Dome light keeps flashing while driving... why?
- Seafoam, oil change right after?
- Part # confirmation
- Hit a curb! Help!
- Cruise control inoperable - need technical help from a BMW/MINI tech
- Crap...
- Things that break after warranty ends
- Loose steering/wander feel at 42,xxx miles
- Should there be thread sealer on brake bleed screw?
- Dropping sub-frame
- HID headlight out, and solution
- Rear Main Seal sadness...
- Stiff MT shifter 2006 Cooper
- My driver door won't open
- I need help fast, overheating
- Bad coil and DCM computer
- Recalls
- Valve cover gasket HELP
- Tighten up the shifter?
- 06 R50 CVT cold start "Howl"
- Need assistance
- Removing the PS pump mounting bracket
- Cheap fix for blown PS fan
- Fuel Pressure question / random misfire
- Factory header...
- Inside door handle won't work
- How to read oil dipstick on '03 MCS?
- Brake pad sensor reset
- Looking for 03 MC "Air Filter Box"
- Intermittently loose steering?!?
- Looking for 03 MC Air Filter Clips
- Roof molding replacement question
- Can someone identify this part?
- My car wont start at all.
- New book that looks interesting
- Yay another problem! smoke from my AC/heating vents!
- Hood open light goes crazy in the rain
- Tire wear
- New engine for MINI
- Engine misfire only when floored
- Engine Control Unit
- Tranny check
- Sloppy steering that's NOT control arm bushings?
- HELP Sheared pinch bolt
- Rain and Burnt Smell? almost like clutch
- Mighty VS7 Universal Power Steering Fluid
- Windshield post coming off
- Brake pad light
- Airbag light
- Getrag vs Midland transmissions
- Broken dip-stick
- What size torx to remove rotors?
- 2002 MINI Cooper tach not working
- Flywheel diagnosis
- Idler Pulley and CS Pulley Questions
- Engine spins but it won't start! HELP
- Rear glass shattered!
- Anyone have experience w/ Aftermarket Catalytic Converters?
- ACC Ambient Temp. Sensor: SNAFU.
- Hi beam only
- After a service appointment
- Green Tire Slime
- Rear suspension noise and loose, sloppy steering?
- Leaking air thru rim
- Anyone used a BMW GT1 scanner?
- How to open the door assembly??
- Piddling hatch
- My MPG readout says 99.99
- Is my tow hook mount upside down?
- 2004 MC r50 engine bay
- MINI of Monrovia - John Slater
- Rear hatch hydraulic pistons dying?
- Don't forget to change your oil!
- Supercharger Oil Capacity
- Battery tender question
- Oil signal comes on when turning sharp???
- Parking Brake Adjust?
- Engine Clicking
- Accessory serpentine belt replacement
- Rear ticking noise when starting the car
- Running rich with cam
- Windshield washer spray pressure
- Water pump leak
- Reinstall drive axle?
- 2006 overheating
- Paint/stripes
- Rumbling noise on right front side
- Ticking Noise
- Ticking noise at idle when clutch is out
- Calling for help from MC owners with OEM Spare Tire - mine is loose
- Rumbling on my left side!
- starter heat shield
- Free ECU (DME) - Know your rights
- help-mystery part!
- Electrical to say the least
- Tranny Trouble
- Clutch slave hydraulic
- Special tools - modular front end extensions
- Rumbling noise
- Safe to install m7 STB with mushrooming?
- Failed CA smog test today
- Mysterious R53 oil leak
- cigarette lighter stuck
- Seatbelt problem
- Radiator fan and power steering fan
- Automatic Climate Heat Setting 78 Degrees!
- Burning rubber while sitting still?
- Why'd my warranty begin before I bought my MCS?
- Drive cycle
- Fried ECU... How?
- Third brakelight blow out - replacement suggestions?
- Grinding noise at start up
- Sprung a leak
- MINI Cooper CVT Help! PLEASE
- 06 MINI "automatic transmission" won't come out of M/S mode
- Lemon, MINI not treating me well. Wiring Harness. Deploying Service Member.
- Recommended actions to avoid CVT problems
- Headlight problem
- Reprogram DME after bypass valve install?
- Accelerator issue
- Do all 2006 MCS heaters suck
- Rear Hatch emblem fell off, where to get one?
- TPM light comes on on cold mornings
- Lost my 5th gear - 02 MC tranny
- Fuel filter tank seals were wrong!
- Wheel speed sensor faults
- Weird HL problem with Xenons
- Door hinge resistance gone! It won't stay open now!
- Acting English...
- Brake Master Cylinder
- Need to replace my windshield...
- Another antifreeze leak
- Grinding then overheated
- Where's the control arm bushing?
- 1st oil change - wrap-up questions
- Clutch R&R
- Chattering Clutch After Coolant Leak Repair
- Looking for service alternatives in the L.A. Area
- Sound when releasing clutch while in 1st
- Alternator issue
- Transmission not engaging 2005 MC at Start-up
- Rear Roof Rattle
- vibration when i turn the wheel after bottoming out
- Need new battery cover!
- help! violent vibration with the tranny!
- Recall for Mini S?
- Long term Angst
- HELP - Cooper S died after rain
- tachometer problem
- Rear 02 sensor took a hit, still tripping code
- Helping Identifying Mushrooming
- HELP! cable question on install
- ABS, TPM, AND DSC LIGHT!
- Supercharger Seal Retainer?
- apiller molding
- What fuse is this? + rebuilt PS pump question
- Wing mirror replacement
- Inspection II Help
- Fuel cap lock actuator + door lock issues, please help!
- Another xenon headlight problem
- coolant leak
- help with removing some interior pieces
- Headlight sprayer
- auto adjusting headlight failure due to replaced BCM?
- Rusty water pipes
- Power steering motor kaput...
- Spun #1 bearing, engine rebuilding....HELP
- CEL Reset? How the?
- How can I check the door lock sensors?
- Slave cylinder problems
- LCD display under speedo says "inspection"
- PS cooling fan ducting kit
- Alarm does'nt work, need help!!!
- Climate control problem
- Supercharger Torque Specs
- Clicking while trying to start
- Subframe dilemma
- Possible boost leak??
- Uh Oh, Vibration determined by Engine RPMS
- Driver's side window won't roll down =(
- Code P0032
- Help! washer pump not working
- How do you run climate control diagnostics and resetting
- failed rear brake light
- Images needed urgently
- How-to for replacing the Clutch master/slave cylinders?
- Mirror caps fading! Warranty?
- '05 MCS: FUSE for windshield washer pumps?
- Automatic Headlight Adjuster?
- Tach Computer Screen Going Nutty!
- What happens when your oil cooler cracks? This...
- HELP car overheated and now won't start
- OEM pad wear
- Stiff rear brakes.
- How to replace the thermostat?
- Multiple caution and warning lights...no A/C
- black plastic fender flare coming off
- Thermostat seal identification
- 03 Mini Cooper Transmission Issues
- help please - passenger wiper not moving
- Replaced bulbs in manual heater A/C control
- My MINI is loud?!
- Bad pulley, where to buy
- SZL? Wheel Speed Sensor? Christmas tree dash lights!
- ABS and DSC lights on after drive in snow
- Please help me!!!! Door dash light stays on!!!
- Engine problem
- Door rusted through paint peeling MINI won't honor 6 yr warranty
- Electrical Problem... Multiple Problems
- Lights for Heater AC controls
- 2004 MCS - $300 Scheduled Maintenance at 50k miles
- frameless windows are annoying
- Really bad VIBRATION! Not wheels... Suspension? Transmission?
- Heated seats too hot on sidewalk package
- MCS back fires and sounds rapsy
- Upper trim cracking and flaking off
- 2003 S battery seems to go dead if not driven daily
- Leak and TSBs
- New Mini Owner.... suspicious my headgasket is blown
- Tstat or PS pump fan or fan resistors?
- Blown H/K amp blasting varying tones, even if system is off?
- Youtube video. Tell me if I have a bad supercharger / waterpump?
- Transmission repair / rebuild / replace
- Third brake light/boot washer
