View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Advice request: Serpentine belt replacement
  2. Clutch pedal suddenly grabs high
  3. Pictures fired seat belt
  4. petrol
  5. Burns quart of oil every 1000 miles
  6. DME issues
  7. Sun Roof Stuck
  8. Bad valve spring
  9. Huge play in Steering wheel
  10. Cold exhaust rattle
  11. Air conditioner only blows cold air on passenger side
  12. Open can of ATE brake fluid - can I use?
  13. A/C nonfunctioning
  14. Fog light repair
  15. Need brake diagnosis please
  16. Proper grease for the sunroof?
  17. Issues with Radio,A/C,Nav, interior lights
  18. speed ?
  19. Glove box will not open
  20. Freeway kill
  21. Rough downshifting in automatic MCS?
  22. AC not blowing cold
  23. Aircon bump
  24. Trying to clear codes on ECU using scangauge II
  25. Getrag transmission parts available???
  26. ALIGNMENT????
  27. Alta CAi issue
  28. Power Steering Fluid Flush?
  29. Can't remove headlight bulb on '05 MC. Help!
  30. What to look for
  31. Engine Code P2402 Anyone????
  32. Talk about GREAT timing!!!
  33. I'm all wet... It's raining inside my '03 MCS
  34. seatbelt squeak
  35. 2003 Cooper CEL Problem
  36. Cooper S xenon headlight problems
  37. Leather Seat problem
  38. EML / Check Engine / DSL Lights
  39. Why doesn't my back-up light work?
  40. Crush washer for oil drain plug?
  41. Accident on day 1, please help!
  42. Clutch slave cylinder bleeding snafu
  43. An other door lock problem... trunk can't lock.. how to do it manually??
  44. is there a way to manually roll up the window
  45. Any tricks to get the #%$@# oil canister off?
  46. How to remove passenger side drive axle?
  47. How to Replace Radiator Fan assembly?
  48. whinny sounds from under the hood and when ac is on
  49. Rust Perforation Waranty NIGHTMARE
  50. Lots of warning lights going on and off
  51. Passenger seat airbag switch
  52. clicking or tapping arround sun roof and rear glass
  53. EP light??
  54. Car Shakes Only Under Acceleration and Only Above 60?
  55. Looking for a good MINI mechanic in Florida for a slipping clutch....
  56. 02 MCS, has some issues, ideas?
  57. Head gasket replacement questions
  58. Front control arm bushings... how much is too much?
  59. Tire light keeps comes on uphill
  60. 04' MC passenger side brake light went out and need help replacing it.
  61. Cylinder 1 Misfire... Which is Cylinder 1?!
  62. What noise is my '06 MCSa making?!?!
  63. Need help engine won't start
  64. what kind of washer is used to connect the front side markers
  65. Coins stuck in door panel
  66. Need OBD code help
  67. 04 S Battery or Alternator
  68. Exhaust smoking...
  69. MINI HATES my gf, door shocks her
  70. Extended warranty from MINI --worth it?
  71. Tire ballance and rotation covered by maintenance plan?
  72. HELP: Spontaneous shut off!
  73. Squeaky Steering Wheel/Column
  74. Thinking clutch?
  75. Anemic performance after tune-up
  76. Need new headliner any ideas?
  77. Wet headliner
  78. oil soaked paper air filter
  79. Replacing Rear Lights, OEM Retrofit Kit
  80. Oily Air Cleaner Element
  81. EML Light after Traffic Jam?
  82. Rough idle
  83. Ok to drive with Vacuum leak?
  84. Transmission sounds
  85. Broken Control Arm Bushing... How is this affecting me?
  86. Timing Chain Breakage questions
  87. intake noise problem - no changes to stock
  88. thermostat replaced - normal temperature?
  89. Front Lower Control Arm Bushing Replacement
  90. Rain sensor troubles
  91. Mysterious oil leak?!...
  92. Does a low mileage MINI need special care
  93. Exhaust leak?
  94. Acelerator vibration
  95. DIY CV joint info and/or service manual recommendations
  96. Driver-Side Window (Mangled Cabling)
  97. Battery Keeps Draining/ECU replaced
  98. Fail start
  99. Radiator Replacement: Anyone have a "how to"?
  100. Intermittent Power Steering Failure
  101. AC is smelly
  102. DIY Do it yourself Oil Pan Gasket Replacement Instructions!
  103. Another Overheating case
  104. umm. what the #$#$ is wrong with my front suspension?
  105. Throttle COMPLETELY shut off at 2nd.
  106. Engine squel in idle
  107. Oil Mystery
  108. door lube
  109. P2096 Code Question
  110. shaft seal leak!
  111. Transmission U/G
  112. Does the radiator relate to the air conditioner?
  113. 04 manual tranny difficult to shift
  114. How do you know if CLUTCH is going?
  115. Overheating Issue
  116. 2005 Cooper S gas cap lock actuator
  117. speedometer problem
  118. New to Mini's! I Need Your Opinion!
  119. LSD Oil replacement
  120. Timing chain
  121. wheel bearing replacement
  122. Engine flat spots at 2,000 - 3,000 RPM
  123. Potential 2002 owner... concerned about tranny "groan"
  124. SES light on but no code
  125. OEM battery to Optima 34R
  126. Tranny Question.....
  127. Stuck cd
  128. Grinding noise?
  129. Help diagnose strange sound
  130. Engine Warning / Scan Code P113C
  131. Fan making noise/ ticking, Need help
  132. Mushroom fix updates?
  133. paipuky like vibration problem
  134. Xenon Headlight Issues, Please Help
  135. TPM on the 08 Cabrio
  136. antifreeze
  137. 2002 MINI Cooper S idle problem
  138. Are there GHOSTS in my MINI?
  139. Three groaning issues and a worried MINI owner
  140. Brake squeaking?
  141. Brake booster push rod free play adjustment?
  142. Wheel Sensor Location
  143. Front bearing noise
  144. DIY help please!
  145. Traction light comes on and stays on
  146. Help - oil leak!
  147. Caliper Frozen - Help
  148. Fan price
  149. Missing wiring for lights?
  150. Where's my ripcord
  151. Buying a 2005 MINI Convertible
  152. Car issues
  153. DSC, flat, ABS lights all on
  154. Cruise control light flashing
  155. DIY CVT fluid change
  156. Vibration in heavy rain
  157. Turn Signal Lamp Stuck On!
  158. Brakes in MCS - not effective w/same pedal pressure
  159. Need help, Throttle Body
  160. Replacing windshield advice for MINI owners...
  161. Radiator fan...
  162. Crank sensor O ring replacement
  163. 2002 R53 power steering reservoir replacement
  164. Lots of minor problems
  165. Random ABS Failure
  166. My first DIY oil change
  167. Window motor replacement how to?
  168. All glass removal PDF, plus some trim removal help
  169. Engine silent block?
  170. New MCS owner... a few questions.
  171. Head gasket diagnosis
  172. Belt Tensioner Problem or Belt Size Wrong?
  173. 03 mini issues with tachometer display
  174. Lurch from idle
  175. Xenon aiming sensor damaged. Need advice...
  176. Shorted Lighter Plug still dead even after replacing fuse
  177. Throttle error codes..?
  178. Is Rear Camber Adjustable on '05 MCS?
  179. Parking lamp
  180. Driver side window and door lock motor
  181. OK to drive (in rain) w/out A-pillar cover?
  182. Leaking coolant hoses - fixes?
  183. Charging system/alternator issue... replacement alternator died in 11 days!
  184. Dealer replaced radio, now no MP3 suppport!
  185. Stinkin' A/C!
  186. $500 Oil pan gasket=too much?
  187. Weird sound at start up
  188. Power steering fan stays on with motor off
  189. 2005 MINI Cooper S leaking antifreeze! Please help!
  190. Coolant expansion tank cap
  191. Tank O'Seafoam - engine's not happy...
  192. OBD2 P1109
  193. Down tubes on center stack?
  194. Passenger door lock
  195. MCS belt tensioner – is it possible to buy the little damper separately anywhere?
  196. She's come unhung
  197. MCS front battery post dead in the water
  198. How do you lube the chassis?
  199. R56 auto transmission jumps out of gear??
  200. Intermittent air conditioning
  201. 05 MCSa losing power steering and gauges with hard turns
  202. My lovely MCS 06 model. Yeah right!
  203. Fault p1476? Leakage diagnostic pump clamped tube?
  204. Triptronic 06 MCS 93K needs to be changed
  205. Strange warning light showed up on my car today...
  206. Good news about MINI service
  207. Oh no, what have I done! Stalling after start
  208. Control panel doubt
  209. Squeaky gas pedal?
  210. Experiences w/ Fidelity Warranty Services?
  211. Urgent help needed! Oil filter stuck!
  212. CEL and gas cap light after fuel filter change
  213. Downshifted and suddenly lost power & EML/SES/DSC lights on
  214. Knock/clank
  215. R53 belt failure - help?
  216. Is this a bad BPV?
  217. Brake pad wear question
  218. Limp mode throwing codes P0107 & P1688
  219. Issue w/indicator lights
  220. Hatchback electrical issue...
  221. Fuel pump/filter/sensor/indicator?
  222. Rear seat catch mechanism
  223. Door Issues
  224. Help with oil pressure & water temp gauges
  225. Third brake light on with car off
  226. Strange clutch sound
  227. Couple of concerns 06 R53
  228. Possible faulty master cylinder?
  229. Engine braking problem
  230. Key failure
  231. Hatchback door latch issue
  232. Rattling/Chattering/Gurgling when Idle - 2004 Cooper Auto non-S
  233. Charging system error - alternator replacement - 2004 Cooper (non-S)
  234. Aftermarket tranny oil
  235. Dealership won't fix brake booster. What do I do?
  236. Squeaking door when warming/cooling
  237. Squeaky Suspension
  238. CEL on 06 MCS, no one but dealer finds code, wants $1300 to replace engine harness?
  239. Gasket/seal question?
  240. DIY oil pan gasket change?
  241. AC issues
  242. What color should oil be after change
  243. Something important fell in the hole
  244. Noise after control arm bushing install
  245. 05 MCS radiator support
  246. Replacing headlight washer
  247. Diagnose this
  248. Grrr! Paint chipping!
  249. Question?
  250. Driver's door lock AND interior lighting issue - related?
